DESCRIPTION:
This file is used to measure pulse modulated fluorescence (PMF) using a saturating pulse and a measuring pulse. The measuring pulse LED (for example, Rebel Luxeon Orange) can itself produce some infra-red
fluorescence which is detected by the detector. This signal causes the detector response to be higher than expected which causes bias in the results. So, in order to account for this added infra-red, we
perform a calibration. The calibration is a short set of pulses which occur at the beginning of the program from an infra-red LED (810nm). The detector response from these flashes indicates how "reflective"
the sample is to infra-red light in the range produced by our measuring LED. We can create a calibration curve by measuring a very reflective sample (like tin foil) and a very non-reflective sample (like
black electrical tape) with both the calibrating LED and the measuring LED. This curve tells us when we see detector response X for the calibrating LED, that correspond to a baseline response of Y for the
measuring LED. Once we have this calibration curve, when we measure an actual sample (like a plant leaf) we automatically calculate and remove the reflected IR produced by the measuring pulse. Vioala!
The LED on/off cycles are taken care of by using interval timers. One timer turns the measuring pulse on (and takes a measurement using analogRead()), one timer turns it off, and one timer controls the length
of the whole run.
To run this file, please make sure you have the following libraries installed: <SdFat.h>, <SdFatUtil.h>, <Time.h>, <Wire.h>, <DS1307RTC.h>, <PITimer.h>
Using Arduino 1.0.3 w/ Teensyduino installed downloaded from http://www.pjrc.com/teensy/td_download.html .
// NOTES FOR USER
// When changing protocols, makes sure to change the name of the saved file (ie data-I.csv) so you know what it is.
// Max file name size is 12 TOTAL characters (8 characters + .csv extension). Program does not distinguish between upper and lower case
// Files have a basename (like ALGAE), and then for each subroutine an extension is added (like ALGAE-I) to indicate from which subroutine the data came.
// When you create a new experiment, you save the data (ALGAE-I) in a folder. If you want stop and restart but save data to the same file, you may append that file.
// Otherwise, you can create a new data file (like ALGAE-I) file an a different folder, which will be named 01GAE, 02GAE, 03GAE and so on.
// Calibration is performed to create an accurate reflectance in the sample using a 850nm LED. You can find a full explanation of the calibration at https://opendesignengine.net/documents/14
// A new calibration should be performed when sample conditions have changed (a new sample is used, the same sample is used in a different position)
// The previous calibration value is saved in the SD card, so if no calibration is performed the most recently saved calibration value will be used!
// See KEY VARIABLES USED IN THE PROTOCOL below to change the measurement pulse cycles, pulse lengths, saturation pulses, etc.
// Note that the output values minimum and maximum are dependent on the analog resolution. From them, you can calculate the actual current through the detector.
// ... So - at 10 bit resolution, min = 0, max = 10^2 = 1023; 16 bit resolution, min = 0, max = 16^2 = 65535; etc.
// ... To calculate actual voltage on the analog pin: 3.3*((measured value) / (max value based on analog resolution)).
// If you want to dig in and change values in this file, search for "NOTE!". These areas provide key information that you will need to make changes.
// Pin A10 and A11 are 16 bit enabed with some added coding in C - the other pins cannot achieve 16 bit resolution.
// Real Time clock - includes sync to real time clock in ASCII 10 digit format and printed time with each sample (ie T144334434)
// NOTES:
// Chris needs to add an experiment start time stamp for setTime() at beginning of program
// time format: %m/%d/%Y %H:%M:%S
// SPECS USING THIS METHOD:
// Timing of Measuring pulse and Saturation pulse is within 500ns. Peak to Peak variability, ON and OFF length variability all is <1us. Total measurement variability = 0 to +2us (regardless of how many cycles)
// SD CARD ENABLE AND SET
#include <SdFat.h>
#include <SdFatUtil.h> // use functions to print strings from flash memory
#include <Time.h> // enable real time clock library
#include <DS1307RTC.h> // a basic DS1307 library that returns time as a atime_t
#include <PITimer.h>
const uint8_t SD_CHIP_SELECT = SS;
SdFat sd;
#define error(s) sd.errorHalt_P(PSTR(s)) // store error strings in flash to save RAM
// KEY VARIABLES USED IN THE PROTOCOL
int measurements = 8; // # of measurements per pulse (min 1 measurement per 6us pulselengthon)
unsigned long pulselengthon = 50; // pulse length in us... minimum = 6us
float cyclelength = .01; // in seconds... minimum = pulselengthon + 7.5us
unsigned long starttimer0, starttimer1, starttimer2;
float runlength = 2; // in seconds... minimum = cyclelength
char filename[13] = "ALGAE"; // Base filename used for data files and directories on the SD Card
const char* basicfluorending = "-I.CSV"; // filename ending for the basicfluor subroutine - just make sure it's no more than 6 digits total including the .CSV
int saturatingcycleon = 50; //The cycle number in which the saturating light turns on (set = 0 for no saturating light)
int saturatingcycleoff = 125; //The cycle number in which the saturating light turns off
// KEY CALIBRATION VARIABLES
unsigned long calpulsecycles = 50; // Number of times the "pulselengthon" and "pulselengthoff" cycle during calibration (on/off is 1 cycle)
// data for measuring and saturating pulses --> to calculate total time=pulsecycles*(pulselengthon + pulselengthoff)
unsigned long calpulselengthon = 30; // Pulse LED on length for calibration in uS (minimum = 5us based on a single ~4us analogRead - +5us for each additional analogRead measurement in the pulse).
unsigned long calpulselengthoff = 49970; // Pulse LED off length for calibration in uS (minimum = 20us + any additional operations which you may want to call during that time).
float reference = 1.2; // The reference (AREF) supplied to the ADC - currently set to INTERNAL = 1.2V
int analogresolution = 16; // Set the resolution of the analog to digital converter (max 16 bit, 13 bit usable)
int measuringlight1 = 3; // Teensy pin for measuring light
int saturatinglight1 = 4; // Teensy pin for saturating light
int calibratinglight1 = 2; // Teensy pin for calibrating light
int detector1 = A10; // Teensy analog pin for detector
// INTERNAL VARIABLES, COUNTERS, ETC.
unsigned long start1,start1orig,end1, calstart1orig, calend1, start5, start6, start7, end5;
unsigned long pulselengthoncheck, pulselengthoffcheck, pulsecyclescheck, totaltimecheck, caltotaltimecheck;
float data1f, data2f, data3f, data4f, irtinvalue, irtapevalue, rebeltapevalue, rebeltinvalue, irsamplevalue, rebelsamplevalue, baselineir, dataaverage, caldataaverage1, caldataaverage2, rebelslope, irslope, baseline = 0;
char filenamedir[13];
char filenamelocal[13];
int data1=0, data2=0, data3=0, data4=0, data5=0, data6=0, data7=0, data8=0, data9=0, data10=0, caldata1, caldata2, caldata3, caldata4, analogresolutionvalue;
int i = 0; // Used as a counter
int j = 0; // Used as a counter
int k = 0; // Used as a counter
int z = 0; // Used as a counter
int* caldatatape;
int* caldatatin;
int* caldatasample;
int* datasample;
int* rebeldatasample;
int val = 0;
int cal = 0;
int cal2 = 0;
int cal3 = 0;
int val2 = 0;
int flag = 0;
int flag2 = 0;
int keypress = 0;
SdFile file;
SdFile sub1;
SdBaseFile* dir = &sub1;
delay(3000); // give operator time to turn on the serial monitor and the capacitor to charge
Serial.begin(38400); // set baud rate for serial communication
// SET INTERRUPT TIMER FOR LED CONTROL AND DETECTOR MEASUREMENTS
PITimer0.period(cyclelength); // Distance between pulses. Set in Seconds.
PITimer1.period(cyclelength); // set == to PITimer0
PITimer2.period(runlength);
// SET SYSTEM TIME IN ASCII "T" PLUS 10 DIGITS
setSyncProvider(Teensy3Clock.get);
while (!Serial); // Wait for Arduino Serial Monitor to open
if(timeStatus()!= timeSet)
Serial.println("Unable to sync with the RTC");
Serial.println("RTC has set the system time"); // NOTE! Chris enter experiment start time stamp here
// for (i=0;i<15;i++) {
Serial.println("Please type in T followed by 10 digit ASCII time (eg 'T1231231231')");
Serial.println("(if you make a mistake, restart teensy and reenter)");
// Serial.println(Serial.available());
while (Serial.available()<11) {
// c = Serial.read();
// Serial.print(Serial.available());
// Serial.print(",");
// Serial.println(Serial.peek());
// delay(500);
atime_t t = processSyncMessage();
Serial.print("'T' plus ASCII 10 digit time: ");
Serial.println(t);
Serial.print("Serial buffer size: ");
setTime(t);
Serial.print("UTC time: ");
SerialPrintClock();
// delay(3000);
// digitalClockDisplay();
Serial.println("");
pinMode(measuringlight1, OUTPUT); // set pin to output
pinMode(saturatinglight1, OUTPUT); // set pin to output
pinMode(calibratinglight1, OUTPUT); // set pin to output
analogReadAveraging(1); // set analog averaging to 1 (ie ADC takes only one signal, takes ~3u
pinMode(detector1, EXTERNAL);
analogReadRes(analogresolution);
analogresolutionvalue = pow(2,analogresolution); // calculate the max analogread value of the resolution setting
if (!sd.begin(SD_CHIP_SELECT, SPI_FULL_SPEED)) sd.initErrorHalt(); // Set SD Card to full speed ahead!
//PRINT SD CARD MEMORY INFORMATION
PgmPrint("Free RAM: ");
Serial.println(FreeRam());
PgmPrint("Volume is FAT");
Serial.println(sd.vol()->fatType(), DEC);
// list file in root with date and size
PgmPrintln("Files found in root:");
sd.ls(LS_DATE | LS_SIZE);
// Recursive list of all directories
PgmPrintln("Files found in all dirs:");
sd.ls(LS_R);
// PRINT OTHER INFORMATION
printout();
//CREATE NEW DIRECTORY OR DATA FILE, OR APPEND EXISTING
//If the primary file name does not yet exist as a file or folder, then create the folder and store all subsequent files (ie file-m.csv, file.c.csv...) in that folder
//... if the primary file name does already exist as a file or folder, then create a new folder with that name and store subsequent files in it.
strcpy(filenamedir, filename);
Serial.println(sd.exists(filenamedir));
if (sd.exists(filenamedir) == 1) {
Serial.print("Press 1 to append the existing data files in directory ");
Serial.print(filenamedir);
Serial.println(" or press 2 to create a new directory.");
while (cal3 != 1 && cal3 !=2) {
cal3 = Serial.read()-48; // for some crazy reason, inputting 0 in the Serial Monitor yields 48 on the Teensy itself, so this just shifts everything by 48 so that when you input X, it's saved in Teensy as X.
if (cal3 == 2) {
for (j = 0; j<100; j++) {
filenamedir[0] = j/10 + '0';
filenamedir[1] = j%10 + '0';
if (sd.exists(filenamedir) == 0) {
Serial.print("OK - creating a new directory called: ");
Serial.println(filenamedir);
SdFile sub1;
sub1.makeDir(sd.vwd(), filenamedir); // Creating new folder
Serial.print(". Data files are saved in that directory as ");
Serial.print(filename);
Serial.println(" plus -(subroutine extension letter).CSV for each subroutine.");
else if (cal3 == 1) {
filenamedir[0] = (j-1)/10 + '0';
filenamedir[1] = (j-1)%10 + '0';
Serial.print("Ok - appending most recently used files located in directory ");
else if (sd.exists(filenamedir) == 0) {
Serial.print("OK - creating a new directory called ");
// MAIN PROGRAM
Serial.println("Would you like to run a calibration? -- type 1 for yes or 2 for no");
while (cal == 0 | flag == 0) {
cal = Serial.read()-48; //
if (cal == 1) {
delay(50);
Serial.println("Ok - calibrating and then running normal protocal");
Serial.println("Place the shiny side of the calibration piece face up in the photosynq, and close the lid.");
Serial.println("When you're done, press any key to continue");
Serial.flush();
while (Serial.read() <= 0) {
Serial.println("Thanks - calibrating...");
calibrationrebel(); // order matters here - make sure that calibrationrebel() is BEFORE calibrationtin()!
calibrationtin();
Serial.println("Now place the black side of the calibration piece face up in the photosynq, and close the lid.");
Serial.flush();
calibrationrebel(); // order matters here - make sure that calibrationrebel() is BEFORE calibrationtape()!
calibrationtape();
Serial.println("Calibration finished!");
cal = 2;
if (cal == 2) {
delay(50);
Serial.println("Proceeding with normal measurement protocol");
Serial.println("Place the sample in front of the light guide and press any key to continue");
Serial.flush();
Serial.println("Thanks - running protocol...");
while (1) {
calibrationsample(); // order matters here - calibrationsample() must be BEFORE basicflour()
basicfluor();
calculations();
Serial.println("");
Serial.println("Press any key to take another measurement, or press reset button to calibrate or start a new file");
else if (cal > 2) {
delay(50);
Serial.println("That's not a 1 or a 2! Please enter either 1 for yes, or 2 for no");
cal = 0;
void calibrationrebel() {
// CALIBRATION REBEL
// Short pulses for calibration using the measuring LED (rebel orange)
rebeldatasample = (int*)malloc(calpulsecycles*sizeof(int)); // create the array of proper size to save one value for all each ON/OFF cycle
noInterrupts();
start1orig = micros();
start1 = micros();
for (i=0;i<calpulsecycles;i++) {
digitalWriteFast(measuringlight1, HIGH);
data1 = analogRead(detector1);
start1=start1+calpulselengthon;
while (micros()<start1) {
start1=start1+calpulselengthoff;
digitalWriteFast(measuringlight1, LOW);
rebeldatasample[i] = data1;
end1 = micros();
interrupts();
free(rebeldatasample); // release the memory allocated for the data
rebelsamplevalue += rebeldatasample[i]; // totals all of the analogReads taken
delay(50);
rebelsamplevalue = (float) rebelsamplevalue; // create a float for rebelsamplevalue so it can be saved later
rebelsamplevalue = (rebelsamplevalue / calpulsecycles);
Serial.print("Rebel sample value: ");
Serial.println(rebelsamplevalue);
Serial.println("");
for (i=0;i<calpulsecycles;i++) { // Print the results!
Serial.print(rebeldatasample[i]);
Serial.print(", ");
Serial.print(" ");
Serial.println("");
Serial.print("see the data here: ");
Serial.println(data1);
void calibrationtin() {
// CALIBRATION TIN
// Flash calibrating light to determine how reflective the sample is to ~850nm light with the tin foil as the sample (low reflectance). This has been tested with Luxeon Rebel Orange as measuring pulse.
caldatatin = (int*)malloc(calpulsecycles*sizeof(int)); // create the array of proper size to save one value for all each ON/OFF cycle
noInterrupts(); // turn off interrupts to reduce interference from other calls
start1 = micros();
digitalWriteFast(calibratinglight1, HIGH);
caldata1 = analogRead(detector1);
digitalWriteFast(calibratinglight1, LOW);
caldatatin[i] = caldata1;
interrupts();
irtinvalue += caldatatin[i]; // totals all of the analogReads taken
Serial.println(irtinvalue);
irtinvalue = (float) irtinvalue;
irtinvalue = (irtinvalue / calpulsecycles); // Divide by the total number of samples to get the average reading during the calibration - NOTE! The divisor here needs to be equal to the number of analogReads performed above!!!!
rebeltinvalue = rebelsamplevalue;
rebelsamplevalue = (int) rebelsamplevalue; // reset rebelsamplevalue to integer for future operations
Serial.print(caldatatin[i]);
Serial.print(", ");
Serial.print(" ");
Serial.println(" ");
Serial.print("the baseline high reflectace value from calibration: ");
Serial.println(irtinvalue, 7);
Serial.print("The last 4 data points from the calibration: ");
Serial.println(caldata1);
void calibrationtape() {
// CALIBRATION TAPE
// Flash calibrating light to determine how reflective the sample is to ~850nm light with the black tape as the sample (low reflectance). This has been tested with Luxeon Rebel Orange as measuring pulse.
caldatatape = (int*)malloc(calpulsecycles*sizeof(int)); // create the array of proper size to save one value for all each ON/OFF cycle
start1 = micros();
caldatatape[i] = caldata1;
interrupts();
irtapevalue += caldatatape[i]; // totals all of the analogReads taken
Serial.println(irtapevalue);
irtapevalue = (float) irtapevalue;
irtapevalue = (irtapevalue / calpulsecycles);
rebeltapevalue = rebelsamplevalue;
Serial.print(caldatatape[i]);
Serial.print(", ");
Serial.print(" ");
Serial.print("the baseline low reflectace value from calibration: ");
Serial.println(irtapevalue, 7);
//CALCULATE AND SAVE CALIBRATION DATA TO SD CARD
rebelslope = rebeltinvalue - rebeltapevalue;
irslope = irtinvalue - irtapevalue;
file.open("RTAPE.CSV", O_CREAT | O_WRITE);
file.seekSet(0);
file.print(rebeltapevalue, 8);
file.close();
file.open("RTIN.CSV", O_CREAT | O_WRITE);
file.seekSet(0);
file.print(rebeltinvalue, 8);
file.close();
file.open("ITAPE.CSV", O_CREAT | O_WRITE);
file.seekSet(0);
file.print(irtapevalue, 8);
file.close();
file.open("ITIN.CSV", O_CREAT | O_WRITE);
file.seekSet(0);
file.print(irtinvalue, 8);
file.close();
file.open("RSLOP.CSV", O_CREAT | O_WRITE);
file.seekSet(0);
file.print(rebelslope, 8);
file.close();
file.open("ISLOP.CSV", O_CREAT | O_WRITE);
file.seekSet(0);
file.print(irslope, 8);
file.close();
Serial.print("IR slope: ");
Serial.println(irslope, 8);
Serial.print("rebel slope: ");
Serial.println(rebelslope, 8);
Serial.print("ir tin value: ");
Serial.println(irtinvalue, 8);
Serial.print("ir tape value: ");
Serial.println(irtapevalue, 8);
Serial.print("rebel tin value: ");
Serial.println(rebeltinvalue, 8);
Serial.print("rebel tape value: ");
Serial.println(rebeltapevalue, 8);
void calibrationsample() {
// CALIBRATION SAMPLE
// Flash calibrating light to determine how reflective the sample is to ~850nm light with the actual sample in place. This has been tested with Luxeon Rebel Orange as measuring pulse.
caldatasample = (int*)malloc(calpulsecycles*sizeof(int)); // create the array of proper size to save one value for all each ON/OFF cycle
calstart1orig = micros();
start1 = micros();
caldatasample[i] = caldata1;
calend1 = micros();
interrupts();
irsamplevalue += caldatasample[i]; // totals all of the analogReads taken
// Serial.println(irsamplevalue);
irsamplevalue = (float) irsamplevalue;
irsamplevalue = (irsamplevalue / calpulsecycles);
Serial.print(caldatasample[i]);
Serial.print(", ");
Serial.print(" ");
Serial.print("the baseline sample reflectace value from calibration: ");
Serial.println(irsamplevalue, 7);
// RETRIEVE STORED TIN AND TAPE CALIBRATION VALUES AND CALCULATE BASELINE VALUE
int c;
char local[12];
Serial.println("Calibration values pulled from SD Card");
file.open("ISLOP.CSV", O_READ);
i = 0; // reset counter just in case
while ((c = file.read()) > 0) {
local[i] = (char) c;
i++;
irslope = strtod(local, NULL);
file.close();
file.open("RSLOP.CSV", O_READ);
i++;
rebelslope = strtod(local, NULL);
file.close();
file.open("ITIN.CSV", O_READ);
i++;
irtinvalue = strtod(local, NULL);
file.close();
file.open("ITAPE.CSV", O_READ);
i++;
irtapevalue = strtod(local, NULL);
file.close();
file.open("RTIN.CSV", O_READ);
i++;
rebeltinvalue = strtod(local, NULL);
file.close();
file.open("RTAPE.CSV", O_READ);
i++;
rebeltapevalue = strtod(local, NULL);
file.close();
sub1.close();
// CALCULATE BASELINE VALUE
baseline = (rebelslope*(irsamplevalue-irtinvalue)/(irslope-rebeltinvalue));
void basicfluor() {
// Flash the LED in a cycle with defined ON and OFF times, and take analogRead measurements as fast as possible on the ON cycle
strcpy(filenamelocal,filename); // set the local filename variable with the extension for this subroutine.
strcat(filenamelocal, basicfluorending); // add the variable's extension defined in header
sub1.open(filenamedir, O_READ);
file.open(dir, filenamelocal, O_CREAT | O_WRITE | O_APPEND);
strcpy(filenamelocal,filename); // reset the localfilename variable;
// SAVE CURRENT TIME TO SD CARD
printTime();
Serial.print("THIS IS THE BASELINE: ");
Serial.println(baseline);
datasample = (int*)malloc((runlength/cyclelength)*sizeof(int)); // create the array of proper size to save one value for all each ON/OFF cycle
starttimer0 = micros()+100; // This is some arbitrary reasonable value to give the Arduino time before starting
starttimer1 = starttimer0+pulselengthon;
while (micros()<starttimer0) {
PITimer0.start(pulseon); // LED on. Takes about 1us to call "start" function in PITimer plus 5us per analogRead()
while (micros()<starttimer1) {
PITimer1.start(pulseoff); // LED off.
PITimer2.start(stoptimers); // turn off timers after runlength time
// WAIT FOR TIMERS TO END (give it runlength plus a 10ms to be safe)
delay(runlength*1000+10);
z = 0; // reset counter z
file.println("");
file.close(); // close out the file
sub1.close(); // close out the director (you MUST do this - if you don't, the file won't save the data!)
// USER PRINTOUT OF MAIN PARAMETERS
void printout() {
Serial.println("");
Serial.print("Pulse cycles during calibration ");
Serial.println(calpulsecycles); // Number of times the "pulselengthon" and "pulselengthoff" cycle (on/off is 1 cycle) (maximum = 1000 until we can store the read data in an SD card or address the interrupts issue)
Serial.print("Time when saturation pulse turns on ");
Serial.println(saturatingcycleon*cyclelength); //The cycle number in which the saturating light turns on (set = 0 for no saturating light)
Serial.print("Time when saturation pulse turns off ");
Serial.println(saturatingcycleoff*cyclelength); //The cycle number in which the saturating light turns off
Serial.print("Length of a single measuring pulse in us ");
Serial.println(pulselengthon); // Pulse LED on length in uS (minimum = 5us based on a single ~4us analogRead - +5us for each additional analogRead measurement in the pulse).
Serial.print("Length of the wait time between pulses pulse in us ");
Serial.println(cyclelength-((float)pulselengthon/1000000)); // Pulse LED on length in uS (minimum = 5us based on a single ~4us analogRead - +5us for each additional analogRead measurement in the pulse).
Serial.print("Base data file name ");
Serial.println(filename);
Serial.println("");
Serial.print("Teensy pin for measuring light ");
Serial.println(measuringlight1);
Serial.print("Teensy pin for saturating light ");
Serial.println(saturatinglight1);
Serial.print("Teensy pin for calibration light ");
Serial.println(calibratinglight1);
Serial.print("Teensy pin for detector ");
Serial.println(detector1);
Serial.println("");
// USER PRINTOUT OF TEST RESULTS
void calculations() {
Serial.println("DATA - RAW ANALOG VALUES IN uV");
for (i=0;i<(runlength/cyclelength);i++) {
datasample[i] = 1000000*((reference*datasample[i])/(analogresolutionvalue*measurements));
for (i=0;i<(runlength/cyclelength);i++) { // Print the results!
Serial.print(datasample[i], 8);
Serial.print(",");
Serial.println("");
Serial.println("ALL DATA IN CURRENT DIRECTORY - BASELINE ADJUSTED VALUES");
int16_t c;
Serial.print("file directory: ");
Serial.print("file name: ");
Serial.println(filenamelocal);
file.open(dir, filenamelocal, O_READ);
while ((c = file.read()) > 0) Serial.write((char)c); // copy data to the serial port
totaltimecheck = end1 - start1orig;
caltotaltimecheck = calend1 - calstart1orig;
Serial.println("");
Serial.print("Size of the baseline: ");
Serial.println(baseline, 8);
Serial.println("");
Serial.println("GENERAL INFORMATION");
Serial.println("");
Serial.print("total run length (measuring pulses): ");
Serial.println(totaltimecheck);
Serial.print("expected run length(measuring pulses): ");
Serial.println(runlength);
Serial.print("total run length (calibration pulses): ");
Serial.println(caltotaltimecheck);
Serial.println("");
Serial.println("CALIBRATION DATA");
Serial.println("");
Serial.print("The baseline from the sample is: ");
Serial.print("The calibration value using the reflective side for the calibration LED and measuring LED are: ");
Serial.print(rebeltinvalue);
Serial.print("and ");
Serial.print("The calibration value using the black side for the calibration LED and measuring LED are: ");
Serial.print(rebeltapevalue);
delay(50);
/* code to process time sync messages from the serial port */
#define TIME_MSG_LEN 11 // time sync to PC is HEADER followed by unix atime_t as ten ascii digits
#define TIME_HEADER 'T' // Header tag for serial time sync message
atime_t processSyncMessage() {
// return the time if a valid sync message is received on the serial port.
while(Serial.available() >= TIME_MSG_LEN ){ // time message consists of a header and ten ascii digits
char c = Serial.read() ;
Serial.print(c);
if(c == TIME_HEADER ) {
atime_t pctime = 0;
for(int i=0; i < TIME_MSG_LEN -1; i++){
c = Serial.read();
if( c >= '0' && c <= '9'){
pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
return pctime;
Serial.println("this is pc time");
Serial.println(pctime);
return 0;
i=0; // reset i
// PRINT CURRENT TIME TO DISPLAY IN SERIAL PORT
void SerialPrintClock(){
Serial.print(month());
Serial.print("/");
Serial.print(day());
Serial.print("/");
Serial.print(year());
Serial.print(" ");
Serial.print(hour());
serialprintDigits(minute());
serialprintDigits(second());
void serialprintDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
void fileprintDigits(int digits){
file.print(":");
if(digits < 10)
file.print('0');
file.print(minute());
void printTime () {
file.print(month());
file.print("/");
file.print(day());
file.print("/");
file.print(year());
file.print(" ");
file.print(hour());
file.print(":");
if(minute() < 10)
file.print('0');
file.print(":");
if(second() < 10)
file.print('0');
file.print(second());
file.print(",");
void pulseon() {
// Serial.print(z);
if (z==saturatingcycleon-1) { // turn on saturating light at beginning of measuring light
digitalWriteFast(saturatinglight1, HIGH);
i = 0;
void pulseoff() {
// NOTE! for very short OFF cycles, just store the data in the datasample[], and write to
// the SD card at the end. If OFF cycle is long enough (50us or more), then you can write
// directly to the SD card. The advantage is you are limited to ~1500 data points for
// datasample[] before it becomes too big for the memory to hold.
if (z==saturatingcycleoff-1) { // turn off saturating light at end of measuring light pulse
digitalWriteFast(saturatinglight1, LOW);
datasample[z] = data1;
Serial.println(datasample[z]);
file.print(datasample[z]);
file.print(",");
data1 = 0; // reset data1 for the next round
z=z+1;
void stoptimers() { // Stop timers, close file and directory on SD card, free memory from datasample[], turn off lights, reset counter variables, move to next row in .csv file,
PITimer0.stop();
PITimer1.stop();
PITimer2.stop();
end1 = micros();
free(datasample); // release the memory allocated for the data
z=0; // reset counters
i=0;
Serial.print("Total run time is ~: ");
Serial.println(end1-starttimer0);
void loop(){
