Teens3 Makefile
swarfrat
I'm trying to get my program building via Makefile. I've stripped it down to this amalgamation of modified sample code.#include <unistd.h>
#include "mk20dx128.h"
#include "usb_serial.h"
#include "core_pins.h"
extern "C" int main(void)
	// To use Teensy 3.0 without Arduino, simply put your code here.
	// For example:
	pinMode(13, OUTPUT);
	while (1) {
		digitalWriteFast(13, HIGH);
		digitalWriteFast(13, LOW);
Makefile
TARGET = main
OPTIONS = -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH
ARDUINO_SDK  = /usr/local/arduino/
PLATFORM     = $(ARDUINO_SDK)/hardware/teensy/cores/teensy3
TOOLSPATH    = $(ARDUINO_SDK)/hardware/tools
LIBRARYPATH  = $(ARDUINO_SDK)/libraries
COMPILERPATH = $(TOOLSPATH)/arm-none-eabi/bin
CPPFLAGS = -Wall -g -Os -mcpu=cortex-m4 -mthumb -nostdlib -MMD $(OPTIONS) -I. -I$(PLATFORM)
CXXFLAGS = -std=gnu++0x -felide-constructors -fno-exceptions -fno-rtti
CFLAGS =
LDFLAGS = -Os -Wl,--gc-sections -mcpu=cortex-m4 -mthumb -T$(PLATFORM)/mk20dx128.ld
LIBS = -lm
CC = $(abspath $(COMPILERPATH))/arm-none-eabi-gcc
CXX = $(abspath $(COMPILERPATH))/arm-none-eabi-g++
OBJCOPY = $(abspath $(COMPILERPATH))/arm-none-eabi-objcopy
SIZE = $(abspath $(COMPILERPATH))/arm-none-eabi-size
C_FILES := $(wildcard *.c)
CPP_FILES := $(wildcard *.cpp)
OBJS := $(C_FILES:.c=.o) $(CPP_FILES:.cpp=.o)
all: $(TARGET).hex
$(TARGET).elf: $(OBJS)
	$(CC) $(LDFLAGS) -o $@ $(OBJS) $(PLATFORM)/mk20dx128.ld
%.hex: %.elf
	$(SIZE) $<
	$(OBJCOPY) -O ihex -R .eeprom $< $@
	$(abspath $(TOOLSPATH))/teensy_post_compile -file=$(basename $@) -path=$(shell pwd) -tools=$(abspath $(TOOLSPATH))
	-$(abspath $(TOOLSPATH))/teensy_reboot
-include $(OBJS:.o=.d)
clean:
	rm -f *.o *.d $(TARGET).elf $(TARGET).hex
Which results in:
/usr/local/arduino/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -Os -Wl,--gc-sections -mcpu=cortex-m4 -mthumb -T/usr/local/arduino//hardware/teensy/cores/teensy3/mk20dx128.ld -o main.elf  main.o /usr/local/arduino//hardware/teensy/cores/teensy3/mk20dx128.ld
/usr/local/arduino-1.0.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-none-eabi/bin/ld:/usr/local/arduino//hardware/teensy/cores/teensy3/mk20dx128.ld:3: warning: redeclaration of memory region `FLASH'
/usr/local/arduino-1.0.4/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-none-eabi/bin/ld:/usr/local/arduino//hardware/teensy/cores/teensy3/mk20dx128.ld:4: warning: redeclaration of memory region `RAM'
/usr/local/arduino//hardware/teensy/cores/teensy3/mk20dx128.ld:11 cannot move location counter backwards (from 000004d8 to 00000000)
collect2: error: ld returned 1 exit status
make: *** [main.elf] Error 1
I'm assuming mk20dx128.ld to be a library build from hardware/tools/teensy3 source, and that it shouldn't be recompiled each and every time I build my project. Is that accurate? I've been able (after ripping out more of the windows make kludges) to get it to compile, but it doesn't run anything, and the hex filie is way smaller in relation to the elf file than I would normally expect. Anyone have Teensy3 stuff building for Linux/Makefile setup?
No, it's actually a linker script file. Think of it like command line parameters for the linker to tell it how to build the executable, except in a file instead of a giant list on the command line.
Maybe this is due to removing mk20dx128.c, which contains the necessary vector table and startup code?
Does the example makefile work if you simply use it without modifications?
It works, but only in the installed directory (in this case /usr/local/arduino-1.04/hardware/teensy/cores/teensy3). Thanks - that's helpful. I see now (with a bit o sleep and that clue I had missed) that this here isn't even the issue I'd been grappling with, but rather a simple path/build issue. I was trying to get my test case back to ALMOST as simple as the example, back to the first step that didn't work, and obscured the issue I was trying to debug in the process. But the last comment about vector table/startup I believe is still pertinent to the original issue.
BTW - I can't find it now, but there is a version of teensy_loader_cli.c floating around the site with mk20dx128 support. But neither -w nor -r seem to work. It can't find the reboot vector, even if running sample code. Isn't -r supposed to kick the rebooter over if it's not already running the bootloader?
I started with an Arduino Makefile and bent it to work with Teensy3.
Enjoy :D
ifndef ARDUINODIR
ARDUINODIR := $(firstword $(wildcard ~/opt/arduino /usr/share/arduino))
endif
# default arduino version
ARDUINOCONST ?= 103
# default hardware
ifndef BOARD
BOARD := teensy3
endif
# obtain board parameters from the arduino boards.txt file
BOARDSFILE := $(ARDUINODIR)/hardware/teensy/boards.txt
readboard = $(shell sed -ne "s/$(BOARD).$(1)=\(.*\)/\1/p" $(BOARDSFILE))
BOARD_BUILD_MCU := $(call readboard,build.mcu)
BOARD_BUILD_CPU := $(call readboard,build.cpu)
BOARD_BUILD_OPTION1 := $(call readboard,build.option1)
BOARD_BUILD_OPTION2 := $(call readboard,build.option2)
BOARD_BUILD_OPTION3 := $(call readboard,build.option3)
BOARD_BUILD_CPPOPTION1 := $(call readboard,build.cppoption1)
BOARD_BUILD_CPPOPTION2 := $(call readboard,build.cppoption2)
BOARD_BUILD_CPPOPTION3 := $(call readboard,build.cppoption3)
BOARD_BUILD_LINKOPTION1 := $(call readboard,build.linkoption1)
BOARD_BUILD_LINKSCRIPT := $(call readboard,build.linkscript)
BOARD_BUILD_FCPU := $(call readboard,menu.speed.96.build.f_cpu)
BOARD_BUILD_CORE := $(call readboard,build.core)
BOARD_BUILD_ARCH := $(call readboard,build.architecture)
BOARD_BUILD_CMD_GCC := $(call readboard,build.command.gcc)
BOARD_BUILD_CMD_GPP := $(call readboard,build.command.g++)
BOARD_BUILD_CMD_AR := $(call readboard,build.command.ar)
BOARD_BUILD_CMD_OBJCOPY := $(call readboard,build.command.objcopy)
BOARD_BUILD_CMD_OBJDUMP := $(call readboard,build.command.objdump)
BOARD_BUILD_CMD_SIZE := $(call readboard,build.command.size)
BOARD_UPLOAD_SPEED := $(call readboard,upload.speed)
BOARD_UPLOAD_PROTOCOL := $(call readboard,upload.protocol)
# default path for tools
TOOLSPATH ?= $(subst :, , $(PATH)) $(ARDUINODIR)/hardware/tools \
	$(ARDUINODIR)/hardware/tools/$(BOARD_BUILD_ARCH)/bin
# auto mode?
INOFILE := $(wildcard *.ino)
# automatically determine sources and targeet
TARGET := $(basename $(INOFILE))
SOURCES := $(INOFILE) \
	$(wildcard *.c *.cc *.cpp *.C) \
	$(wildcard $(addprefix util/, *.c *.cc *.cpp *.C)) \
	$(wildcard $(addprefix utility/, *.c *.cc *.cpp *.C))
# automatically determine included libraries
LIBRARIES := $(filter $(notdir $(wildcard $(addsuffix /*, $(LIBRARYPATH)))), \
	$(shell sed -ne "s/^ *\# *include *[<\"]\(.*\)\.h[>\"]/\1/p" $(SOURCES)))
# software
findsoftware = $(firstword $(wildcard $(addsuffix /$(1), $(TOOLSPATH))))
CC := $(call findsoftware,$(BOARD_BUILD_CMD_GCC))
CXX := $(call findsoftware,$(BOARD_BUILD_CMD_GPP))
LD := $(call findsoftware,$(BOARD_BUILD_CMD_LD))
AR := $(call findsoftware,$(BOARD_BUILD_CMD_AR))
OBJCOPY := $(call findsoftware,$(BOARD_BUILD_CMD_OBJCOPY))
OBJDUMP := $(call findsoftware,$(BOARD_BUILD_CMD_OBJDUMP))
OBJSIZE := $(call findsoftware,$(BOARD_BUILD_CMD_OBJSIZE))
# directories
COREDIR := $(ARDUINODIR)/hardware/teensy/cores/$(BOARD_BUILD_CORE)
# files
TARGET := $(if $(TARGET),$(TARGET),a.out)
OBJECTS := $(addsuffix .o, $(basename $(SOURCES)))
DEPFILES := $(patsubst %, .dep/%.dep, $(SOURCES))
ARDUINOLIB := .lib/arduino.a
ARDUINOLIBOBJS := $(foreach dir, $(COREDIR) $(LIBRARYDIRS), \
	$(patsubst %, .lib/%.o, $(wildcard $(addprefix $(dir)/, *.c *.cpp))))
# flags
CPPFLAGS += -Os -Wall -ffunction-sections -fdata-sections
CPPFLAGS += -funsigned-char -fshort-enums
CPPFLAGS += -mcpu=$(BOARD_BUILD_CPU) $(LINKOPTION1)
CPPFLAGS += $(BOARD_BUILD_OPTION1) $(BOARD_BUILD_OPTION2) $(BOARD_BUILD_OPTION3)
CPPFLAGS += -DF_CPU=$(BOARD_BUILD_FCPU) -DARDUINO=$(ARDUINOCONST)
CPPFLAGS += -DUSB_SERIAL -DLAYOUT_US_ENGLISH
CPPFLAGS += -I. -I $(COREDIR) -I $(ARDUINODIR)/hardware/teensy/cores/$(BOARD_BUILD_CORE)
CXXFLAGS += -std=gnu++0x -fno-exceptions -felide-constructors
CXXFLAGS += $(BOARD_BUILD_CPPOPTION1) $(BOARD_BUILD_CPPOPTION2) $(BOARD_BUILD_CPPOPTION3)
CPPDEPFLAGS = -MMD -MP -MF .dep/$<.dep
CPPINOFLAGS := -x c++ -include $(COREDIR)/Arduino.h
LINKFLAGS += -Os -Wl,--gc-sections
LINKFLAGS += -mcpu=$(BOARD_BUILD_CPU) $(BOARD_BUILD_LINKOPTION1) -T$(COREDIR)/$(BOARD_BUILD_LINKSCRIPT)
# include dependencies
ifneq "$(MAKECMDGOALS)" "clean"
-include $(DEPFILES)
endif
# default rule
.DEFAULT_GOAL := all
# targets
.PHONY:	all target flash clean boards monitor size
all: target
target: $(TARGET).hex
flash: target
	@echo "Uploading to board..."
	../loader/loader -mmcu=$(BOARD_BUILD_MCU) -w -v $(TARGET).hex
clean:
	rm -f $(OBJECTS)
	rm -f $(TARGET).elf $(TARGET).hex $(ARDUINOLIB) *~
	rm -rf .lib .dep
boards:
	@echo "Available values for BOARD:"
	@sed -nEe '/^#/d; /^[^.]+\.name=/p' $(BOARDSFILE) | \
		sed -Ee 's/([^.]+)\.name=(.*)/\1            \2/' \
			-e 's/(.{12}) *(.*)/\1 \2/'
monitor:
	picocom -c /dev/ttyACM0
	echo && $(OBJSIZE) --format=avr --mcu=$(BOARD_BUILD_MCU) $(TARGET).elf
# building the target
$(TARGET).hex: $(TARGET).elf
$(TARGET).elf: $(ARDUINOLIB) $(OBJECTS)
	$(CC) $(LINKFLAGS) $(OBJECTS) $(ARDUINOLIB) -lm -o $@
%.o: %.c
	mkdir -p .dep/$(dir $<)
	$(COMPILE.c) $(CPPDEPFLAGS) -o $@ $<
%.o: %.cpp
	$(COMPILE.cpp) $(CPPDEPFLAGS) -o $@ $<
%.o: %.cc
%.o: %.C
%.o: %.ino
	$(COMPILE.cpp) $(CPPDEPFLAGS) -o $@ $(CPPINOFLAGS) $<
# building the arduino library
$(ARDUINOLIB): $(ARDUINOLIBOBJS)
	$(AR) rcs $@ $?
.lib/%.c.o: %.c
	mkdir -p $(dir $@)
	$(COMPILE.c) -o $@ $<
.lib/%.cpp.o: %.cpp
	mkdir -p $(dir $@)
	$(COMPILE.cpp) -o $@ $<
.lib/%.cc.o: %.cc
	mkdir -p $(dir $@)
.lib/%.C.o: %.C
	mkdir -p $(dir $@)
I'm having trouble getting my program to compile with the makefile
Here's my version:
ifndef ARDUINODIR
ARDUINODIR := $(firstword $(wildcard ~/arduino17))
endif
ARDUINOCONST ?= 105
# default hardware
ifndef BOARD
BOARD := teensy3
endif
# obtain preferences from the IDE's preferences.txt
PREFERENCESFILE := $(firstword $(wildcard \
	$(HOME)/.arduino/preferences.txt $(HOME)/Library/Arduino/preferences.txt))
ifneq "$(PREFERENCESFILE)" ""
readpreferencesparam = $(shell sed -ne "s/$(1)=\(.*\)/\1/p" $(PREFERENCESFILE))
SKETCHBOOKDIR := $(call readpreferencesparam,sketchbook.path)
endif
# default path to find libraries
LIBRARYPATH ?= $(SKETCHBOOKDIR)/libraries $(ARDUINODIR)/libraries
# auto mode?
# automatically determine sources and target
# software
# directories
LIBRARYDIRS := $(foreach lib, $(LIBRARIES), \
	$(firstword $(wildcard $(addsuffix /$(lib), $(LIBRARYPATH)))))
LIBRARYDIRS += $(addsuffix /utility, $(LIBRARYDIRS))
# files
# flags
endif
# default rule
# targets
all: target
flash: target
clean:
	rm -f $(OBJECTS)
	rm -rf .lib .dep
boards:
monitor:
%.o: %.c
%.o: %.cpp
%.o: %.cc
%.o: %.C
%.o: %.ino
	$(AR) rcs $@ $?
.lib/%.c.o: %.c
	mkdir -p $(dir $@)
.lib/%.cpp.o: %.cpp
	mkdir -p $(dir $@)
.lib/%.cc.o: %.cc
	mkdir -p $(dir $@)
.lib/%.C.o: %.C
	mkdir -p $(dir $@)
and when I try to compile using make I get:
jimm@deb-main:~/sketchbook/TeensyNet_WIZ_LCD$ make clean
rm -f TeensyNet_WIZ_LCD.o
rm -f TeensyNet_WIZ_LCD.elf TeensyNet_WIZ_LCD.hex .lib/arduino.a *~
rm -rf .lib .dep
mkdir -p .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/analog.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/analog.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/eeprom.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/eeprom.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/keylayouts.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/keylayouts.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/math_helper.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/math_helper.c
In file included from /home/jimm/arduino17/hardware/teensy/cores/teensy3/math_helper.h:33:0,
                 from /home/jimm/arduino17/hardware/teensy/cores/teensy3/math_helper.c:39:
/home/jimm/arduino17/hardware/teensy/cores/teensy3/arm_math.h: In function 'arm_pid_q15':
/home/jimm/arduino17/hardware/teensy/cores/teensy3/arm_math.h:5329:5: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/mk20dx128.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/mk20dx128.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/nonstd.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/nonstd.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/pins_teensy.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/pins_teensy.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/serial1.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/serial1.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/serial2.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/serial2.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/serial3.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/serial3.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/touch.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/touch.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_desc.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_desc.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_dev.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_dev.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_joystick.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_joystick.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_keyboard.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_keyboard.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_mem.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_mem.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_midi.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_midi.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_mouse.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_mouse.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_rawhid.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_rawhid.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_seremu.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_seremu.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_serial.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_serial.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc  -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/yield.c.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/yield.c
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/AudioStream.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/AudioStream.cpp
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/avr_emulation.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/avr_emulation.cpp
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/HardwareSerial1.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/HardwareSerial1.cpp
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/HardwareSerial2.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/HardwareSerial2.cpp
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/HardwareSerial3.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/HardwareSerial3.cpp
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/IntervalTimer.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/IntervalTimer.cpp
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/IPAddress.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/IPAddress.cpp
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/main.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/main.cpp
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/Print.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/Print.cpp
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/Stream.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/Stream.cpp
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/Tone.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/Tone.cpp
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_flightsim.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_flightsim.cpp
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_inst.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/usb_inst.cpp
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/WMath.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/WMath.cpp
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/hardware/teensy/cores/teensy3/WString.cpp.o /home/jimm/arduino17/hardware/teensy/cores/teensy3/WString.cpp
mkdir -p .lib//home/jimm/sketchbook/libraries/PID_v1/
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/sketchbook/libraries/PID_v1/PID_v1.cpp.o /home/jimm/sketchbook/libraries/PID_v1/PID_v1.cpp
mkdir -p .lib//home/jimm/arduino17/libraries/EEPROM/
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/libraries/EEPROM/EEPROM.cpp.o /home/jimm/arduino17/libraries/EEPROM/EEPROM.cpp
mkdir -p .lib//home/jimm/arduino17/libraries/OneWire/
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/libraries/OneWire/OneWire.cpp.o /home/jimm/arduino17/libraries/OneWire/OneWire.cpp
/home/jimm/arduino17/libraries/OneWire/OneWire.cpp: In member function 'uint8_t OneWire::reset()':
/home/jimm/arduino17/libraries/OneWire/OneWire.cpp:139:14: warning: unused variable 'mask' [-Wunused-variable]
/home/jimm/arduino17/libraries/OneWire/OneWire.cpp: In member function 'void OneWire::write_bit(uint8_t)':
/home/jimm/arduino17/libraries/OneWire/OneWire.cpp:173:14: warning: unused variable 'mask' [-Wunused-variable]
/home/jimm/arduino17/libraries/OneWire/OneWire.cpp: In member function 'uint8_t OneWire::read_bit()':
/home/jimm/arduino17/libraries/OneWire/OneWire.cpp:201:14: warning: unused variable 'mask' [-Wunused-variable]
mkdir -p .lib//home/jimm/arduino17/libraries/SPI/
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/libraries/SPI/SPI.cpp.o /home/jimm/arduino17/libraries/SPI/SPI.cpp
mkdir -p .lib//home/jimm/arduino17/libraries/Ethernet/
/home/jimm/arduino17/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -std=gnu++0x -fno-exceptions -felide-constructors  -fno-rtti   -Os -Wall -ffunction-sections -fdata-sections -funsigned-char -fshort-enums -mcpu=cortex-m4  -mthumb -nostdlib -D__MK20DX128__ -DF_CPU=96000000 -DARDUINO=105 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I. -I /home/jimm/arduino17/hardware/teensy/cores/teensy3 -I /home/jimm/arduino17/hardware/teensy/cores/teensy3  -c -o .lib//home/jimm/arduino17/libraries/Ethernet/Dhcp.cpp.o /home/jimm/arduino17/libraries/Ethernet/Dhcp.cpp
In file included from /home/jimm/arduino17/libraries/Ethernet/Dhcp.cpp:4:0:
/home/jimm/arduino17/libraries/Ethernet/utility/w5100.h:14:17: fatal error: SPI.h: No such file or directory
compilation terminated.
make: *** [.lib//home/jimm/arduino17/libraries/Ethernet/Dhcp.cpp.o] Error 1
The code compile fine with the IDE, so I'm obviously missing something, any help?
Same error
