Results 1 to 6 of 6
Thread: Teensy Game Controller
    Apr 2013
    4
    Question Teensy Game Controller
    I am currently working on a project and interested in using the teensy to create a game controller for disabled gamers. i was wondering if the teensy be used to create a game controller similar to an xbox controller for pc (including all the buttons, analogs, ect). if so how can i program the separate analog thumb sticks so that one controls looking and one control's movement. and hwo can i program the bottons ( a link to an existing project would also help). the analog sticks are the most important part of my inquiry. Thanks in advance.
    22,123
    You should probably start with the Joystick example. In Arduino, open it with File > Examples > Teensy > USB_Joystick > Complete.
    It already has code using analogRead(). For the joystick part you mentioned in 2 threads earlier today
    http://forum.pjrc.com/threads/23592-...ysticks-Teensy
    http://forum.pjrc.com/threads/23591-...ysticks-Teensy
    just connect the pot for each axis to an analog pin.
    Each pot as 3 wires. Connect the center wire to the analog input pin. Connect the other 2 wires to GND (AGND if using Teensy 3.0) and 5V (if using Teensy 2.0) or 3.3V (if using Teensy 3.0). If you use a voltmeter, you can see the voltage change on the middle pin as the joystick moves. Likewise, analogRead() will measure the voltage and give you a number.
    Start with that joystick example and get it working with your PC, then modify to suit your needs.
    Apr 2013
    4
    Thanks Paul. your reply and time has been very helpful. you probably noticed that i'm a noob with all this, but i am willing to learn.
    I created a joystick controller using 3 axis and a few buttons. It has automatic calibration, and dead zone detection.
    https://github.com/dc740/Game-port-t...tick-converter
    I used Teensyduino, so you can use it on Teensy 2.0 or Teensy 3.0.
    22,123
    Do you have any photo of this project? If so, I could post it to the Teensy Projects page.
    The teensy is not visible, so I didn't take a picture, but it's this controller with a USB connector instead of the game port connector.
Name:	6466576_4_644x461_joystick-genius-maxfighter-f16-electronice-si-electrocasnice.jpg
    like:
    but with several extra features.
Tags for this Thread
