nyarlathotep
I accidentally touched a 4.5V line to the USB housing on my pinned Teensy 3.0, releasing the magic smoke. It runs fine if powered by the VCC and GND pins, but cannot draw power from USB for programming. I've successfully programmed it by placing an alligator clip on the USB housing that runs to GND though.
The Teensy 3.0 schematic one running through a ferrite bead. Is that because the USB cable sheath picks up noise? Or is the ferrite bead attached to some second ground wire inside the cable?
Have I likely burned out the ferrite bead or just some wire? Should I solder another ferrite bead going from the USB housing to the GND pin? Along with maybe an extra Bourns resettable 500mA fuse?
Or should I just solder a wire from the USB cable housing to GND? As I said, this works for programming it and reading the IR code responses, not sure if bypassing the ferrite bead has other consequences.
