Results 1 to 4 of 4
Thread: Teensy 3.0 is not recognised
    May 2013
    5
    Hi there!
    I got my first Teensy and really like the specs and the size.
    But iīve problems to get it recognised by the teensy loader.
    Iīve installed Arduino 1.0.4, Teensyduino 1.14 (Teensy 0.7).
    I tried 4 USB cables and tried all the steps in the troubleshoot section.
    I only want to try to programm the BasicTest from OctoWS2811.
    When i received the board the blink program ran, but if i pushed the button the LED still blinked further.
    Once i could load the BasicTest onto it after 50 tries, but now it didnīt worked for 100 tries...
    And itīs the same with the Push Button, the programm still runs if i press it.
    Have a mid 2012 MacBook Pro with OS X 10.8.3.
    Do youīve any more tipps i could try?
    iīve an oscillospe and a logic analyser.
    Thx for your help and greetings from germany.
    ben
Name:	Screen Shot 2013-05-13 at 1.36.47 PM.png
    28,460
    Quote Originally Posted by +5V View Post
    It's definitely supposed to stop blinking when you press the button! Maybe the button was damaged during shipping?
    The good news is the rest of the board appears to be working properly, based on the info you posted.
    You can "press" the button by shorting the PROG and GND pins, on the right hand side of the board (opposite the USB). It's ok to use a wire or paperclip to short them (or solder a pushbutton to those 2 pins if you like). Touch the wire to GND first (in case your body has any electrostatic charge) and then momentarily touch it to the PROG pin. The button just connects those 2 wires, so touching a wire between those pins does the same thing.
    Normally while using Arduino, you can just click the Upload button. It will search for your Teensy and send a request to reboot. As long as it's still running (hasn't crashed with interrupts disabled or locked up due to a bad memory access), the board should reboot automatically without needing to press the button. This process usually works very well on Mac and Linux (usually only Windows that has driver issues).
    That screenshot shows the serial number is "7018". Maybe this board has been successfully reprogrammed at least once? The code we're programming onto the boards here is from an older version of Teensyduino which didn't report the actual serial number. All serial numbers from the older version are "12345". Macs often show it as "12341" (why Apple change the last digit to a 1 is a mystery to me).
    May 2013
    5
    I measured the button, seems to work fine and the wire method didnīt helped at all.
    Yes like i said i was once able to program the Teensy with the BasicTest OctoWS2811 code except some small changes(in bold). wanted only control the first one meter stripe.
    but it worked after trying to program it 50 times.
    int microsec = 200000 / leds.numPixels(); // change them all in 0.2 seconds //normaly 2000000 aka 2seconds
    // uncomment for voltage controlled speed
    // millisec = analogRead(A9) / 40;
    colorWipe(RED, microsec);
    colorWipe(GREEN, microsec);
    colorWipe(BLUE, microsec);
    colorWipe(YELLOW, microsec);
    colorWipe(PINK, microsec);
    colorWipe(ORANGE, microsec);
    colorWipe(WHITE, microsec);
    void colorWipe(int color, int wait)
    for (int i=0; i < 60; i++) { //normally leds.numPixels()
    leds.setPixel(i, color);
    leds.show();
    delayMicroseconds(wait);
    maybe there is something wrong with the MINI54TAN or a broken wire on the board to the MINI54TAN?
    damn i ordered only one at this time, so i could see better if something is wrong with my setup or itīs only the board.
    but ordered two new ones just now.
    thx for the fast reply!
    ben
    May 2013
    5
    i really dont know whatīs going on, but i got it two time now recognised from the teensy loader but then i got the following errors:
    download error, because erasing seems to fail
    unable to reboot, when trying to reboot
    but itīs recognised the whole time.
    what could that be?
