/* USB Serial Example for Teensy USB Development Board
* http://www.pjrc.com/teensy/usb_serial.html
* Copyright (c) 2008 PJRC.COM, LLC
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE.
#include "usb_common.h"
#include "usb_private.h"
* Endpoint Buffer Configuration
static const uint8_t PROGMEM endpoint_config_table[] = {
1, EP_TYPE_INTERRUPT_IN, EP_SIZE(DEBUG_TX_SIZE) | DEBUG_TX_BUFFER,
1, EP_TYPE_INTERRUPT_OUT, EP_SIZE(DEBUG_RX_SIZE) | DEBUG_RX_BUFFER,
1, EP_TYPE_INTERRUPT_IN, EP_SIZE(KEYBOARD_SIZE) | KEYBOARD_BUFFER,
1, EP_TYPE_INTERRUPT_IN, EP_SIZE(MOUSE_SIZE) | MOUSE_BUFFER,
#ifdef JOYSTICK_INTERFACE
1, EP_TYPE_INTERRUPT_IN, EP_SIZE(JOYSTICK_SIZE) | JOYSTICK_BUFFER,
0
* Descriptor Data
// Descriptors are the data that your computer reads when it auto-detects
// this USB device (called "enumeration" in USB lingo). The most commonly
// changed items are editable at the top of this file. Changing things
// in here should only be done by those who've read chapter 9 of the USB
// spec and relevant portions of any USB class specifications!
static const uint8_t PROGMEM device_descriptor[] = {
18, // bLength
1, // bDescriptorType
0x00, 0x02, // bcdUSB
0, // bDeviceClass
0, // bDeviceSubClass
0, // bDeviceProtocol
ENDPOINT0_SIZE, // bMaxPacketSize0
LSB(VENDOR_ID), MSB(VENDOR_ID), // idVendor
LSB(PRODUCT_ID), MSB(PRODUCT_ID), // idProduct
0x05, 0x01, // bcdDevice
0, // iManufacturer
1, // iProduct
0, // iSerialNumber
1 // bNumConfigurations
// Keyboard Protocol 1, HID 1.11 spec, Appendix B, page 59-60
static const uint8_t PROGMEM keyboard_hid_report_desc[] = {
0x05, 0x01, // Usage Page (Generic Desktop),
0x09, 0x06, // Usage (Keyboard),
0xA1, 0x01, // Collection (Application),
0x75, 0x01, // Report Size (1),
0x95, 0x08, // Report Count (8),
0x05, 0x07, // Usage Page (Key Codes),
0x19, 0xE0, // Usage Minimum (224),
0x29, 0xE7, // Usage Maximum (231),
0x15, 0x00, // Logical Minimum (0),
0x25, 0x01, // Logical Maximum (1),
0x81, 0x02, // Input (Data, Variable, Absolute), ;Modifier byte
0x05, 0x0C, // Usage Page (Consumer),
0x09, 0xE9, // Usage (Volume Increment),
0x09, 0xEA, // Usage (Volume Decrement),
0x09, 0xE2, // Usage (Mute),
0x09, 0xCD, // Usage (Play/Pause),
0x09, 0xB5, // Usage (Scan Next Track),
0x09, 0xB6, // Usage (Scan Previous Track),
0x09, 0xB7, // Usage (Stop),
0x09, 0xB8, // Usage (Eject),
0x81, 0x02, // Input (Data, Variable, Absolute), ;Media keys
0x95, 0x05, // Report Count (5),
0x05, 0x08, // Usage Page (LEDs),
0x19, 0x01, // Usage Minimum (1),
0x29, 0x05, // Usage Maximum (5),
0x91, 0x02, // Output (Data, Variable, Absolute), ;LED report
0x95, 0x01, // Report Count (1),
0x75, 0x03, // Report Size (3),
0x91, 0x03, // Output (Constant), ;LED report padding
0x95, 0x06, // Report Count (6),
0x75, 0x08, // Report Size (8),
0x25, 0x7F, // Logical Maximum(104),
0x19, 0x00, // Usage Minimum (0),
0x29, 0x7F, // Usage Maximum (104),
0x81, 0x00, // Input (Data, Array), ;Normal keys
0xc0 // End Collection
// Mouse Protocol 1, HID 1.11 spec, Appendix B, page 59-60, with wheel extension
static const uint8_t PROGMEM mouse_hid_report_desc[] = {
0x09, 0x02, // Usage (Mouse)
0x05, 0x09, // Usage Page (Button)
0x19, 0x01, // Usage Minimum (Button #1)
0x29, 0x03, // Usage Maximum (Button #3)
0x95, 0x03, // Report Count (3)
0x75, 0x05, // Report Size (5)
0x81, 0x03, // Input (Constant)
0x09, 0x30, // Usage (X)
0x09, 0x31, // Usage (Y)
0x15, 0x81, // Logical Minimum (-127)
0x25, 0x7F, // Logical Maximum (127)
0x95, 0x02, // Report Count (2),
0x81, 0x06, // Input (Data, Variable, Relative)
0x09, 0x38, // Usage (Wheel)
0xC0 // End Collection
static const uint8_t PROGMEM joystick_hid_report_desc[] = {
0x09, 0x04, // Usage (Joystick)
0x95, 0x20, // Report Count (32)
0x29, 0x20, // Usage Maximum (Button #32)
0x81, 0x02, // Input (variable,absolute)
0x25, 0x07, // Logical Maximum (7)
0x35, 0x00, // Physical Minimum (0)
0x46, 0x3B, 0x01, // Physical Maximum (315)
0x75, 0x04, // Report Size (4)
0x65, 0x14, // Unit (20)
0x09, 0x39, // Usage (Hat switch)
0x81, 0x42, // Input (variable,absolute,null_state)
0x09, 0x01, // Usage (Pointer)
0xA1, 0x00, // Collection ()
0x26, 0xFF, 0x03, // Logical Maximum (1023)
0x75, 0x0A, // Report Size (10)
0x95, 0x04, // Report Count (4)
0x09, 0x32, // Usage (Z)
0x09, 0x35, // Usage (Rz)
0xC0, // End Collection
0x09, 0x36, // Usage (Slider)
static const uint8_t PROGMEM debug_hid_report_desc[] = {
0x06, 0xC9, 0xFF, // Usage Page 0xFFC9 (vendor defined)
0x09, 0x04, // Usage 0x04
0xA1, 0x5C, // Collection 0x5C
0x75, 0x08, // report size = 8 bits (global)
0x15, 0x00, // logical minimum = 0 (global)
0x26, 0xFF, 0x00, // logical maximum = 255 (global)
0x95, DEBUG_TX_SIZE, // report count (global)
0x09, 0x75, // usage (local)
0x95, DEBUG_RX_SIZE, // report count (global)
0x09, 0x76, // usage (local)
0x95, 0x04, // report count (global)
0xB1, 0x02, // Feature
0xC0 // end collection
#define KEYBOARD_HID_DESC_OFFSET ( 9 + 9 )
#define CONFIG1_DESC_SIZE ( 9 + 9+9+7 )
#define MOUSE_HID_DESC_OFFSET
#define DEBUG_HID_DESC_OFFSET
#define JOYSTICK_HID_DESC_OFFSET
#else
static const uint8_t PROGMEM config1_descriptor[CONFIG1_DESC_SIZE] = {
// configuration descriptor, USB spec 9.6.3, page 264-266, Table 9-10
9, // bLength;
2, // bDescriptorType;
LSB(CONFIG1_DESC_SIZE), // wTotalLength
MSB(CONFIG1_DESC_SIZE),
NUM_INTERFACE, // bNumInterfaces
1, // bConfigurationValue
0, // iConfiguration
0xC0, // bmAttributes
50, // bMaxPower
// interface descriptor, USB spec 9.6.5, page 267-269, Table 9-12
9, // bLength
4, // bDescriptorType
KEYBOARD_INTERFACE, // bInterfaceNumber
0, // bAlternateSetting
1, // bNumEndpoints
0x03, // bInterfaceClass (0x03 = HID)
0x01, // bInterfaceSubClass (0x01 = Boot)
0x01, // bInterfaceProtocol (0x01 = Keyboard)
0, // iInterface
// HID interface descriptor, HID 1.11 spec, section 6.2.1
9, // bLength
0x21, // bDescriptorType
0x11, 0x01, // bcdHID
0, // bCountryCode
1, // bNumDescriptors
0x22, // bDescriptorType
sizeof(keyboard_hid_report_desc), // wDescriptorLength
0,
// endpoint descriptor, USB spec 9.6.6, page 269-271, Table 9-13
7, // bLength
5, // bDescriptorType
KEYBOARD_ENDPOINT | 0x80, // bEndpointAddress
0x03, // bmAttributes (0x03=intr)
KEYBOARD_SIZE, 0, // wMaxPacketSize
KEYBOARD_INTERVAL, // bInterval
// If you're desperate for a little extra code memory, these strings
// can be completely removed if iManufacturer, iProduct, iSerialNumber
// in the device desciptor are changed to zeros.
struct usb_string_descriptor_struct {
uint8_t bLength;
uint8_t bDescriptorType;
int16_t wString[];
static const struct usb_string_descriptor_struct PROGMEM string0 = {
4,
3,
{0x0409}
static const struct usb_string_descriptor_struct PROGMEM string1 = {
sizeof(STR_PRODUCT),
3,
STR_PRODUCT
// This table defines which descriptor data is sent for each specific
// request from the host (in wValue and wIndex).
static const struct descriptor_list_struct {
uint16_t wValue;
uint16_t wIndex;
const uint8_t *addr;
uint8_t length;
} PROGMEM descriptor_list[] = {
{0x0100, 0x0000, device_descriptor, sizeof(device_descriptor)},
{0x0200, 0x0000, config1_descriptor, sizeof(config1_descriptor)},
{0x2200, KEYBOARD_INTERFACE, keyboard_hid_report_desc, sizeof(keyboard_hid_report_desc)},
{0x2100, KEYBOARD_INTERFACE, config1_descriptor+KEYBOARD_HID_DESC_OFFSET, 9},
{0x0300, 0x0000, (const uint8_t *)&string0, 4},
{0x0301, 0x0409, (const uint8_t *)&string1, sizeof(STR_PRODUCT)},
#define NUM_DESC_LIST (sizeof(descriptor_list)/sizeof(struct descriptor_list_struct))
* Variables - these are the only non-stack RAM usage
// zero when we are not configured, non-zero when enumerated
volatile uint8_t usb_configuration USBSTATE;
volatile uint8_t usb_suspended USBSTATE;
// the time remaining before we transmit any partially full
// packet, or send a zero length packet.
volatile uint8_t debug_flush_timer USBSTATE;
// byte0: which modifier keys are currently pressed
// 1=left ctrl, 2=left shift, 4=left alt, 8=left gui
// 16=right ctrl, 32=right shift, 64=right alt, 128=right gui
// byte1: media keys (TODO: document these)
// bytes2-7: which keys are currently pressed, up to 6 keys may be down at once
uint8_t keyboard_report_data[8] USBSTATE;
// protocol setting from the host. We use exactly the same report
// either way, so this variable only stores the setting since we
// are required to be able to report which setting is in use.
static uint8_t keyboard_protocol USBSTATE;
// the idle configuration, how often we send the report to the
// host (ms * 4) even when it hasn't changed
static uint8_t keyboard_idle_config USBSTATE;
// count until idle timeout
uint8_t keyboard_idle_count USBSTATE;
// 1=num lock, 2=caps lock, 4=scroll lock, 8=compose, 16=kana
volatile uint8_t keyboard_leds USBSTATE;
// which buttons are currently pressed
uint8_t mouse_buttons USBSTATE;
static uint8_t mouse_protocol USBSTATE;
// joystick data
uint8_t joystick_report_data[12] USBSTATE;
* Public Functions - these are the API intended for the user
// initialize USB serial
void usb_init(void)
uint8_t u;
u = USBCON;
if ((u & (1<<USBE)) && !(u & (1<<FRZCLK))) return;
HW_CONFIG();
USB_FREEZE(); // enable USB
PLL_CONFIG(); // config PLL
while (!(PLLCSR & (1<<PLOCK))) ; // wait for PLL lock
USB_CONFIG(); // start USB clock
UDCON = 0; // enable attach resistor
usb_configuration = 0;
usb_suspended = 0;
debug_flush_timer = 0;
keyboard_report_data[0] = 0;
keyboard_report_data[1] = 0;
keyboard_report_data[2] = 0;
keyboard_report_data[3] = 0;
keyboard_report_data[4] = 0;
keyboard_report_data[5] = 0;
keyboard_report_data[6] = 0;
keyboard_report_data[7] = 0;
keyboard_protocol = 1;
keyboard_idle_config = 125;
keyboard_idle_count = 0;
keyboard_leds = 0;
mouse_buttons = 0;
mouse_protocol = 1;
joystick_report_data[0] = 0;
joystick_report_data[1] = 0;
joystick_report_data[2] = 0;
joystick_report_data[3] = 0;
joystick_report_data[4] = 0x0F;
joystick_report_data[5] = 0x20;
joystick_report_data[6] = 0x80;
joystick_report_data[7] = 0x00;
joystick_report_data[8] = 0x02;
joystick_report_data[9] = 0x08;
joystick_report_data[10] = 0x20;
joystick_report_data[11] = 0x80;
UDINT = 0;
UDIEN = (1<<EORSTE)|(1<<SOFE);
//sei(); // init() in wiring.c does this
void usb_shutdown(void)
UDIEN = 0; // disable interrupts
UDCON = 1; // disconnect attach resistor
USBCON = 0; // shut off USB periperal
PLLCSR = 0; // shut off PLL
usb_suspended = 1;
// Public API functions moved to usb_api.cpp
* Private Functions - not intended for general user consumption....
// USB Device Interrupt - handle all device-level events
// the transmit buffer flushing is triggered by the start of frame
ISR(USB_GEN_vect)
uint8_t intbits, t, i;
static uint8_t div4=0;
intbits = UDINT;
UDINT = 0;
if (intbits & (1<<EORSTI)) {
UENUM = 0;
UECONX = 1;
UECFG0X = EP_TYPE_CONTROL;
UECFG1X = EP_SIZE(ENDPOINT0_SIZE) | EP_SINGLE_BUFFER;
UEIENX = (1<<RXSTPE);
if ((intbits & (1<<SOFI)) && usb_configuration) {
t = debug_flush_timer;
if (t) {
debug_flush_timer = -- t;
if (!t) {
UENUM = DEBUG_TX_ENDPOINT;
while ((UEINTX & (1<<RWAL))) {
UEDATX = 0;
UEINTX = 0x3A;
if (keyboard_idle_config && (++div4 & 3) == 0) {
UENUM = KEYBOARD_ENDPOINT;
if (UEINTX & (1<<RWAL)) {
keyboard_idle_count++;
if (keyboard_idle_count == keyboard_idle_config) {
//len = keyboard_protocol ? sizeof(keyboard_keys) : 8;
for (i=0; i < 8; i++) {
UEDATX = keyboard_report_data[i];
UEINTX = 0x3A;
if (intbits & (1<<SUSPI)) {
// USB Suspend (inactivity for 3ms)
UDIEN = (1<<WAKEUPE);
usb_suspended = 1;
#if (F_CPU >= 8000000L)
// WAKEUPI does not work with USB clock freeze
// when CPU is running less than 8 MHz.
// Is this a hardware bug?
USB_FREEZE(); // shut off USB
// to properly meet the USB spec, current must
// reduce to less than 2.5 mA, which means using
// powerdown mode, but that breaks the Arduino
// user's paradigm....
if (usb_suspended && (intbits & (1<<WAKEUPI))) {
// USB Resume (pretty much any activity)
PLL_CONFIG();
USB_CONFIG();
UDIEN = (1<<EORSTE)|(1<<SOFE)|(1<<SUSPE);
usb_suspended = 0;
return;
// Misc functions to wait for ready and send/receive packets
static inline void usb_wait_in_ready(void)
while (!(UEINTX & (1<<TXINI))) ;
static inline void usb_send_in(void)
UEINTX = ~(1<<TXINI);
static inline void usb_wait_receive_out(void)
while (!(UEINTX & (1<<RXOUTI))) ;
static inline void usb_ack_out(void)
UEINTX = ~(1<<RXOUTI);
// USB Endpoint Interrupt - endpoint 0 is handled here. The
// other endpoints are manipulated by the user-callable
// functions, and the start-of-frame interrupt.
ISR(USB_COM_vect)
uint8_t intbits;
const uint8_t *list;
const uint8_t *cfg;
uint8_t i, n, len, en;
uint8_t bmRequestType;
uint8_t bRequest;
uint16_t wValue;
uint16_t wIndex;
uint16_t wLength;
uint16_t desc_val;
const uint8_t *desc_addr;
uint8_t desc_length;
UENUM = 0;
intbits = UEINTX;
if (intbits & (1<<RXSTPI)) {
bmRequestType = UEDATX;
bRequest = UEDATX;
read_word_lsbfirst(wValue, UEDATX);
read_word_lsbfirst(wIndex, UEDATX);
read_word_lsbfirst(wLength, UEDATX);
UEINTX = ~((1<<RXSTPI) | (1<<RXOUTI) | (1<<TXINI));
if (bRequest == GET_DESCRIPTOR) {
list = (const uint8_t *)descriptor_list;
for (i=0; ; i++) {
if (i >= NUM_DESC_LIST) {
UECONX = (1<<STALLRQ)|(1<<EPEN); //stall
return;
pgm_read_word_postinc(desc_val, list);
if (desc_val != wValue) {
list += sizeof(struct descriptor_list_struct)-2;
continue;
if (desc_val != wIndex) {
list += sizeof(struct descriptor_list_struct)-4;
continue;
pgm_read_word_postinc(desc_addr, list);
desc_length = pgm_read_byte(list);
len = (wLength < 256) ? wLength : 255;
if (len > desc_length) len = desc_length;
list = desc_addr;
do {
// wait for host ready for IN packet
do {
i = UEINTX;
} while (!(i & ((1<<TXINI)|(1<<RXOUTI))));
if (i & (1<<RXOUTI)) return; // abort
// send IN packet
n = len < ENDPOINT0_SIZE ? len : ENDPOINT0_SIZE;
for (i = n; i; i--) {
pgm_read_byte_postinc(UEDATX, list);
len -= n;
usb_send_in();
} while (len || n == ENDPOINT0_SIZE);
return;
if (bRequest == SET_ADDRESS) {
usb_send_in();
usb_wait_in_ready();
UDADDR = wValue | (1<<ADDEN);
return;
if (bRequest == SET_CONFIGURATION && bmRequestType == 0) {
usb_configuration = wValue;
usb_send_in();
cfg = endpoint_config_table;
for (i=1; i<NUM_ENDPOINTS; i++) {
UENUM = i;
pgm_read_byte_postinc(en, cfg);
UECONX = en;
if (en) {
pgm_read_byte_postinc(UECFG0X, cfg);
pgm_read_byte_postinc(UECFG1X, cfg);
UERST = 0x1E;
UERST = 0;
return;
if (bRequest == GET_CONFIGURATION && bmRequestType == 0x80) {
UEDATX = usb_configuration;
usb_send_in();
return;
if (bRequest == GET_STATUS) {
i = 0;
if (bmRequestType == 0x82) {
UENUM = wIndex;
if (UECONX & (1<<STALLRQ)) i = 1;
UENUM = 0;
UEDATX = i;
UEDATX = 0;
usb_send_in();
return;
if ((bRequest == CLEAR_FEATURE || bRequest == SET_FEATURE)
&& bmRequestType == 0x02 && wValue == 0) {
i = wIndex & 0x7F;
if (i >= 1 && i <= NUM_ENDPOINTS) {
usb_send_in();
UENUM = i;
if (bRequest == SET_FEATURE) {
UECONX = (1<<STALLRQC)|(1<<RSTDT)|(1<<EPEN);
UERST = (1 << i);
UERST = 0;
return;
if (wIndex == KEYBOARD_INTERFACE) {
if (bmRequestType == 0xA1) {
if (bRequest == HID_GET_REPORT) {
usb_send_in();
return;
if (bRequest == HID_GET_IDLE) {
UEDATX = keyboard_idle_config;
usb_send_in();
return;
if (bRequest == HID_GET_PROTOCOL) {
UEDATX = keyboard_protocol;
usb_send_in();
return;
if (bmRequestType == 0x21) {
if (bRequest == HID_SET_REPORT) {
usb_wait_receive_out();
keyboard_leds = UEDATX;
usb_ack_out();
usb_send_in();
return;
if (bRequest == HID_SET_IDLE) {
keyboard_idle_config = (wValue >> 8);
//usb_wait_in_ready();
usb_send_in();
return;
if (bRequest == HID_SET_PROTOCOL) {
keyboard_protocol = wValue;
usb_send_in();
return;
if (wIndex == MOUSE_INTERFACE) {
UEDATX = mouse_buttons;
UEDATX = 0;
UEDATX = 0;
UEDATX = 0;
usb_send_in();
return;
UEDATX = mouse_protocol;
usb_send_in();
return;
mouse_protocol = wValue;
usb_send_in();
return;
if (wIndex == JOYSTICK_INTERFACE) {
for (i=0; i<12; i++) {
UEDATX = joystick_report_data[i];
usb_send_in();
return;
if (wIndex == DEBUG_INTERFACE) {
if (bRequest == HID_GET_REPORT && bmRequestType == 0xA1) {
len = wLength;
do {
do {
i = UEINTX;
// send IN packet
UEDATX = 0;
len -= n;
usb_send_in();
return;
if (bRequest == HID_SET_REPORT && bmRequestType == 0x21) {
if (wValue == 0x0300 && wLength == 0x0004) {
uint8_t b1, b2, b3, b4;
b1 = UEDATX;
b2 = UEDATX;
b3 = UEDATX;
b4 = UEDATX;
usb_ack_out();
usb_send_in();
if (b1 == 0xA9 && b2 == 0x45 && b3 == 0xC2 && b4 == 0x6B)
_reboot_Teensyduino_();
if (b1 == 0x8B && b2 == 0xC5 && b3 == 0x1D && b4 == 0x70)
_restart_Teensyduino_();
if (bRequest == 0xC9 && bmRequestType == 0x40) {
usb_send_in();
UECONX = (1<<STALLRQ) | (1<<EPEN); // stall
