Results 1 to 9 of 9
Thread: Teensyduino 1.14 Release Candidate #2 Available
    Administrator Paul's Avatar
    Oct 2012
    390
    Here is a 2nd release candidate for Teensyduino 1.14:
    Old beta download links removed. Please use the latest version:
    Please give this a try and report any bugs. Try to include a sample program that reproduces the problem!
    24,079
    Changes since 1.14-rc1:
    Support for Arduino 1.0.5.
    Optimize Serial.readBytes(), both Teensy 2.0 and 3.0.
    Optimize Serial.available() on Teensy 3.0.
    Added IntervalTimer destructor.
    Added String c_str() function.
    Removed ArdOSC library.
    DmxSimple library support for Teensy 2.0 and 3.0 (previously only Teensy++ 2.0 worked)
    Fixed FastSPI compile problem on Teensy 2.0 and Teensy++ 2.0.
    Update MIDI library to version 3.2.
    Fixed error highlighting when using Teensy 3.0.
    Improved recompile speed when Arduino is installed in a location with space in the pathname.
    Improved automatic initialization of the Teensy 3.0 RTC, when a 32.768 kHz crystal is present.
    Wow!
    USB Serial really has been vastly improved.
    Might be a late request - Can you expand AnalogWrite to the pins on the reverse side that's supported by the K20 [Teensy3] pretty please? [With sugar on top?]
    Edit : https://plus.google.com/114506261366...ts/9KRfnJNv1QL <--- Using the new USB Serial to write a GIF to a 1.8" TFT
    24,079
    Quote Originally Posted by Madox View Post
    For 1.14, at this late stage I'm only including bug fixes. But this might be possible for 1.15....
    Please post this as a new topic on the suggestions forum and we'll chat there about the details.
    On that video, are you use Serial.readBytes() or Serial.available() & Serial.read()? If you have a lot of spare time (yeah, who does) it's be really awesome to see a video with a before vs after using 1.13 and 1.14. I'm planning to publish an article in a couple weeks with benchmarks, so if you make such a video I would certainly link to it as an example.
    Serial available then serial read... I wish I could have a 128x160 buffer... (I might try with a 128 byte readbytes too..)
    I have the old Teensy installation from before so should be quick to load it up, will do so in around 14 hours
    24,079
    If you liked this speedup, you'll *really* like the readBytes() speedup! The normal available/read is only about 2X faster. But readBytes() increased by about 12X, which leaves lots of CPU time free for your code, even during sustained receiving at the maximum rate limited by the USB full speed.
    Nice! No hurry on that. I'm imagining publishing a nice benchmarks article in about 2 weeks.
    Horrible (and short) video :-
    https://plus.google.com/114506261366...ts/dNj2sRjQ93o
    Using Serial.read()
    Ard 1.0.3 - Teensyduino <=1.13 = 12 fps ~= 490kB/s
    Ard 1.0.5 - Teensyduino =1.14 RC2 = 16 fps ~=655kBs
    Using Serial.readBytes() with 64 byte buffer
    Ard 1.0.5 - Teensyduino =1.14 RC2 = 22 fps ~= 900kB/s
    I'm writing out a full frame buffer of 128x160*2 bytes out using pyserial.
    Teensy receives the buffer and writes it to SPI to drive the display.
    https://plus.google.com/114506261366...ts/Y2wDW9AZF8P
    Picture of the rig
    Using two identical Carambola2's with same image and same test script to drive the Teensys which are programmed with different versions of Teensyduino
    https://plus.google.com/u/0/11450626...ts/K8dqEn62heu
    Slightly better video comparison.
    24fps ~= 983kB/s
