Results 1 to 15 of 15
Thread: MIDI HID combo
    Jun 2013
    296
    MIDI HID combo
    It's it possible for a teensy to operate as a midi device and raw HID device at the same time?
    20,169
    Yes, it is possible, but you'll need to edit the code because this combination isn't already made.
    Teensy 3.0 has a much easier way to configure the USB interfaces (still by editing code), so it might be an easier path than using 2.0.
    I have this working on teensy 3 here. Main program here. As Paul said, it's just a matter of editing code.
    -c
    Jun 2013
    296
    I'm going to do if for Teensy 2.0 but I'm sure you code will help loads. Thanks for sharing.
    Rob
    Jun 2013
    296
    Alright.... I've completed Step1:
    I added the following lines to the boards.txt file:
    teensy2.menu.usb.hidMidi.name=Raw HID + MIDI
    teensy2.menu.usb.hidMidi.build.define0=-DUSB_RAWHID_MIDI
    teensy2.menu.usb.hidMidi.fake_serial=teensy_gatewa y
    Where should I go next?
    Jun 2013
    296
    And I've completed step2:
    I added the following lines to teensy/usb_private.h:
    #elif defined(USB_RAWHID_MIDI)
    #include "../usb_rawhid_midi/usb_private.h"
    ...I think I'm on the right track now...
    Jun 2013
    296
    Step 3 was very obvious, I created a copy of the usb_rawhid folder and renamed it to usb_rawhid_midi.
    Now I could use a little guidance...
    Jun 2013
    296
    Step 4: I started editing the USB_private.h in my usb_rawhid_midi folder. Does this look right?
    #define RAWHID_INTERFACE 0
    #define RAWHID_TX_ENDPOINT 3
    #define RAWHID_TX_BUFFER EP_DOUBLE_BUFFER
    #define RAWHID_TX_SIZE 64 //64
    #define RAWHID_RX_ENDPOINT 4
    #define RAWHID_RX_BUFFER EP_DOUBLE_BUFFER
    #define RAWHID_RX_SIZE 64
    // COPIED IN FROM THE MIDI usb_private.h
    #define MIDI_INTERFACE 1 //CHANGED FROM 0
    #define MIDI_TX_ENDPOINT 3
    #define MIDI_TX_SIZE 64
    #define MIDI_TX_BUFFER EP_DOUBLE_BUFFER
    #define MIDI_RX_ENDPOINT 4
    #define MIDI_RX_SIZE 64
    #define MIDI_RX_BUFFER EP_DOUBLE_BUFFER
    #define DEBUG_INTERFACE 3 //CHANGED FROM 2
    #define DEBUG_TX_ENDPOINT 1
    #define DEBUG_TX_SIZE 64
    #define DEBUG_TX_BUFFER EP_DOUBLE_BUFFER
    #define DEBUG_RX_ENDPOINT 2
    #define DEBUG_RX_SIZE 32
    #define DEBUG_RX_BUFFER EP_DOUBLE_BUFFER
    #define NUM_ENDPOINTS 8 //CHANGED FROM 5
    #define NUM_INTERFACE 3 //CHANGED FROM 2
    20,169
    Looks like you've got both MIDI and RAWHID using the same endpoints, which obviously can not work. Change one of them to endpoints 5 and 6.
    Also, it looks like NUM_ENDPOINTS is 8, when it should be only 7.
    In usb.c, you'll need to edit the endpoint config table. If you've got 6 non-zero endpoints (endpoint 0 is special and configured separately), the table must have 6 lines. Here's the table from usb_midi/usb.c:
    static const uint8_t PROGMEM endpoint_config_table[] = {
            1, EP_TYPE_INTERRUPT_IN,  EP_SIZE(DEBUG_TX_SIZE) | DEBUG_TX_BUFFER,
            1, EP_TYPE_INTERRUPT_OUT, EP_SIZE(DEBUG_RX_SIZE) | DEBUG_RX_BUFFER,
            1, EP_TYPE_BULK_IN,       EP_SIZE(MIDI_TX_SIZE) | MIDI_TX_BUFFER,
            1, EP_TYPE_BULK_OUT,      EP_SIZE(MIDI_RX_SIZE) | MIDI_RX_BUFFER
    These are in order, starting at endpoint 1. Just copy the 2 lines from RawHID's endpoint_config_table[]. Be sure to get all 6 lines in the right order, so they match up to the endpoint numbers you defined in usb_private.h.
    Then you're ready to start copying stuff into the descriptor data arrays, which is what tells your PC the type of device.
    Jun 2013
    296
    Thanks for your help, Paul. I'm probably going to need more of it to finish this up.
    Here's my Endpoint Buffer Configuration:
    //FROM usb_private.h
    #define MIDI_INTERFACE		0
    #define MIDI_TX_ENDPOINT	1
    #define MIDI_RX_ENDPOINT	2
    #define RAWHID_INTERFACE	1
    #define DEBUG_INTERFACE		2
    #define DEBUG_TX_ENDPOINT	5
    #define DEBUG_RX_ENDPOINT	6
    #define NUM_ENDPOINTS		7
    //from usb.c
    	1, EP_TYPE_BULK_OUT,      EP_SIZE(MIDI_RX_SIZE) | MIDI_RX_BUFFER,
    	1, EP_TYPE_INTERRUPT_IN,  EP_SIZE(RAWHID_TX_SIZE) | RAWHID_TX_BUFFER,
    	1, EP_TYPE_INTERRUPT_OUT, EP_SIZE(RAWHID_RX_SIZE) | RAWHID_RX_BUFFER,
    	0
    I notice there's a trailing 0 in the Endpoint Config Table. It was there in the rawhid config table. Should I be leaving that in there?
    That's the easy part, right? I've already opened up the api files and merged the the MIDI and RAWHID functions together, so that's done, just hose nasty descriptor bit left.
    Some questions? Does the Device Descriptor need to change? I notice that the one for MIDI and RAWHID are very slightly different, namely the value for bcdDevice.
    Also, I notice there is no report descriptor for MIDI, that's correct? And lastly, what do I need to do in the Config1 Descriptor?
    Cheers,
    Rob
    20,169
    Quote Originally Posted by yeahtuna View Post
    If you're using Windows or Mac, you'll probably need to increase bcdDevice each time you make a change. Windows especially caches into in the Windows Registry and even though it reads all this info from the device, it will trust the old info in the registry if the bcd device number is the same.
    That's right, only HID uses report desciptors. But MIDI has a bunch of extra descriptor stuff like the report descriptors, except it's embedded within the config descriptor instead of its own special type of descriptor that's requested separately.
    Yes, lots of stuff. All 3 interfaces and every endpoint they use must be in the big config descriptor.
    Aside from just copying stuff into that array, there are some offsets that need to be computed. You'll see #defines for them as lots of integers added together, which are the sizes of the little chunks that make up the big config descriptor.
    The USB-IF (www.usb.org) publishes a "command verifier" tool. It's Windows only, and be warned, it messes with your USB stack so back up your data before running it, or if you have a spare PC, run it on that. If you get stuff wrong in the descriptors, that test tool is the best way to figure out what's wrong.
    Jun 2013
    296
    Hi Paul, I've copied all the stuff in and tried to calculate the offsets, but I must be going wrong somewhere because the device does not install properly. If you have some time do you think you could quickly look over my usb.c file and see if anything jumps out at you, in particular with the offsets.
    Regards,
    Rob.
    /* USB Serial Example for Teensy USB Development Board
     * http://www.pjrc.com/teensy/usb_serial.html
     * Copyright (c) 2008 PJRC.COM, LLC
     * The above copyright notice and this permission notice shall be included in
     * all copies or substantial portions of the Software.
     * THE SOFTWARE.
    #include "usb_common.h"
    #include "usb_private.h"
     *  Endpoint Buffer Configuration
    	0
     *  Descriptor Data
    // Descriptors are the data that your computer reads when it auto-detects
    // this USB device (called "enumeration" in USB lingo).  The most commonly
    // changed items are editable at the top of this file.  Changing things
    // in here should only be done by those who've read chapter 9 of the USB
    // spec and relevant portions of any USB class specifications!
    static const uint8_t PROGMEM device_descriptor[] = {
    	18,					// bLength
    	1,					// bDescriptorType
    	0x00, 0x02,				// bcdUSB
    	0,					// bDeviceClass
    	0,					// bDeviceSubClass
    	0,					// bDeviceProtocol
    	ENDPOINT0_SIZE,				// bMaxPacketSize0
    	LSB(VENDOR_ID), MSB(VENDOR_ID),		// idVendor
    	LSB(PRODUCT_ID), MSB(PRODUCT_ID),	// idProduct
    	0x02, 0x01,				// bcdDevice
    	0,					// iManufacturer
    	1,					// iProduct
    	0,					// iSerialNumber
    	1					// bNumConfigurations
    static const uint8_t PROGMEM debug_hid_report_desc[] = {
            0x06, 0xC9, 0xFF,                       // Usage Page 0xFFC9 (vendor defined)
            0x09, 0x04,                             // Usage 0x04
            0xA1, 0x5C,                             // Collection 0x5C
            0x75, 0x08,                             // report size = 8 bits (global)
            0x15, 0x00,                             // logical minimum = 0 (global)
            0x26, 0xFF, 0x00,                       // logical maximum = 255 (global)
            0x95, DEBUG_TX_SIZE,                    // report count (global)
            0x09, 0x75,                             // usage (local)
            0x81, 0x02,                             // Input
            0x95, DEBUG_RX_SIZE,                    // report count (global)
            0x09, 0x76,                             // usage (local)
            0x91, 0x02,                             // Output
            0x95, 0x04,                             // report count (global)
            0xB1, 0x02,                             // Feature
            0xC0                                    // end collection
    static uint8_t PROGMEM rawhid_hid_report_desc[] = {
            0x06, LSB(RAWHID_USAGE_PAGE), MSB(RAWHID_USAGE_PAGE),
            0x0A, LSB(RAWHID_USAGE), MSB(RAWHID_USAGE),
            0xA1, 0x01,                             // Collection 0x01
            0x95, RAWHID_TX_SIZE,                   // report count
            0x09, 0x01,                             // usage
            0x81, 0x02,                             // Input (array)
            0x95, RAWHID_RX_SIZE,                   // report count
            0x09, 0x02,                             // usage
            0x91, 0x02,                             // Output (array)
    #define MIDI_SIZE 74
    #define RAWHID_SIZE 32
    #define DEBUG_SIZE 32
    // FROM RAWHID -- #define RAWHID_HID_DESC_OFFSET		( 9 + 9 )
    // FROM MIDI   -- #define DEBUG_HID_DESC_OFFSET		( 9 + 74 + 9 )
    // In the midi core, DEBUG is the second interface, in my core rawhid is the second interface, so I assume their offset should be the same
    #define RAWHID_HID_DESC_OFFSET		( 9 + MIDI_SIZE + 9 )
    //#define RAWHID DEBUG_HID_DESC_OFFSET		( 9 + 9+9+7+7 + 9 )
    // From this, I assume the size of the RAWHID = 9+9+7+7 = 32
    #define DEBUG_HID_DESC_OFFSET		( 9 + MIDI_SIZE + RAWHID_SIZE + 9 )
    //#define CONFIG1_DESC_SIZE		( 9 + 9+9+7+7 + 9+9+7+7)
    //and from this I assume that the size of the debug is also 32
    #define CONFIG1_DESC_SIZE		( 9 + MIDI_SIZE + RAWHID_SIZE + DEBUG_SIZE)
    static const uint8_t PROGMEM config1_descriptor[CONFIG1_DESC_SIZE] = {
    	// configuration descriptor, USB spec 9.6.3, page 264-266, Table 9-10
    	9, 					// bLength;
    	2,					// bDescriptorType;
    	LSB(CONFIG1_DESC_SIZE),			// wTotalLength
    	MSB(CONFIG1_DESC_SIZE),
    	NUM_INTERFACE,				// bNumInterfaces
    	1,					// bConfigurationValue
    	0,					// iConfiguration
    	0xC0,					// bmAttributes
    	50,					// bMaxPower
    /// MIDI STUFF --------------------------------------
            // Standard MS Interface Descriptor,
            9,                                      // bLength
            4,                                      // bDescriptorType
            MIDI_INTERFACE,                         // bInterfaceNumber
            0,                                      // bAlternateSetting
            2,                                      // bNumEndpoints
            0x01,                                   // bInterfaceClass (0x01 = Audio)
            0x03,                                   // bInterfaceSubClass (0x03 = MIDI)
            0x00,                                   // bInterfaceProtocol (unused for MIDI)
            0,                                      // iInterface
    	// MIDI MS Interface Header, USB MIDI 6.1.2.1, page 21, Table 6-2
    	7,					// bLength
    	0x24,					// bDescriptorType = CS_INTERFACE
    	0x01,					// bDescriptorSubtype = MS_HEADER
    	0x00, 0x01,				// bcdMSC = revision 01.00
    	0x41, 0x00,				// wTotalLength
    	// MIDI IN Jack Descriptor, B.4.3, Table B-7 (embedded), page 40
    	6,					// bLength
    	0x02,					// bDescriptorSubtype = MIDI_IN_JACK
    	0x01,					// bJackType = EMBEDDED
    	1,					// bJackID, ID = 1
    	0,					// iJack
    	// MIDI IN Jack Descriptor, B.4.3, Table B-8 (external), page 40
    	6,					// bLength
    	0x02,					// bJackType = EXTERNAL
    	2,					// bJackID, ID = 2
    	0,					// iJack
    	// MIDI OUT Jack Descriptor, B.4.4, Table B-9, page 41
    	9,
    	0x03,					// bDescriptorSubtype = MIDI_OUT_JACK
    	3,					// bJackID, ID = 3
    	1,					// bNrInputPins = 1 pin
    	2,					// BaSourceID(1) = 2
    	1,					// BaSourcePin(1) = first pin
    	0,					// iJack
    	// MIDI OUT Jack Descriptor, B.4.4, Table B-10, page 41
    	9,
    	4,					// bJackID, ID = 4
    	1,					// BaSourceID(1) = 1
    	0,					// iJack
            // Standard Bulk OUT Endpoint Descriptor, B.5.1, Table B-11, pae 42
            9,                                      // bLength
            5,                                      // bDescriptorType = ENDPOINT
            MIDI_RX_ENDPOINT,                       // bEndpointAddress
            0x02,                                   // bmAttributes (0x02=bulk)
            MIDI_RX_SIZE, 0,                        // wMaxPacketSize
            0,                                      // bInterval
    	0,					// bRefresh
    	0,					// bSynchAddress
    	// Class-specific MS Bulk OUT Endpoint Descriptor, B.5.2, Table B-12, page 42
    	5,					// bLength
    	0x25,					// bDescriptorSubtype = CS_ENDPOINT
    	0x01,					// bJackType = MS_GENERAL
    	1,					// bNumEmbMIDIJack = 1 jack
    	1,					// BaAssocJackID(1) = jack ID #1
            // Standard Bulk IN Endpoint Descriptor, B.5.1, Table B-11, pae 42
            9,                                      // bLength
            MIDI_TX_ENDPOINT | 0x80,                // bEndpointAddress
            MIDI_TX_SIZE, 0,                        // wMaxPacketSize
            0,                                      // bInterval
    	0,					// bRefresh
    	0,					// bSynchAddress
    	// Class-specific MS Bulk IN Endpoint Descriptor, B.5.2, Table B-12, page 42
    	5,					// bLength
    	3,					// BaAssocJackID(1) = jack ID #3
    // RAW HID STUFF ------------------------------------------------------------------------
            // interface descriptor, USB spec 9.6.5, page 267-269, Table 9-12
            9,                                      // bLength
            RAWHID_INTERFACE,                       // bInterfaceNumber
            2,                                      // bNumEndpoints
            0x03,                                   // bInterfaceClass (0x03 = HID)
            0x00,                                   // bInterfaceSubClass (0x01 = Boot)
            0x00,                                   // bInterfaceProtocol (0x01 = Keyboard)
            2,                                      // iInterface
            // HID interface descriptor, HID 1.11 spec, section 6.2.1
            9,                                      // bLength
            0x21,                                   // bDescriptorType
            0x11, 0x01,                             // bcdHID
            0,                                      // bCountryCode
            1,                                      // bNumDescriptors
            0x22,                                   // bDescriptorType
            sizeof(rawhid_hid_report_desc),         // wDescriptorLength
            0,
            // endpoint descriptor, USB spec 9.6.6, page 269-271, Table 9-13
            7,                                      // bLength
            RAWHID_TX_ENDPOINT | 0x80,              // bEndpointAddress
            0x03,                                   // bmAttributes (0x03=intr)
            RAWHID_TX_SIZE, 0,                      // wMaxPacketSize
            RAWHID_TX_INTERVAL,                     // bInterval
            7,                                      // bLength
            RAWHID_RX_ENDPOINT,                     // bEndpointAddress
            RAWHID_RX_SIZE, 0,                      // wMaxPacketSize
            RAWHID_RX_INTERVAL,                     // bInterval
            9,                                      // bLength
            DEBUG_INTERFACE,                        // bInterfaceNumber
            2,                                      // bNumEndpoints
            3,                                      // iInterface
            9,                                      // bLength
            0,                                      // bCountryCode
            sizeof(debug_hid_report_desc),          // wDescriptorLength
            0,
            7,                                      // bLength
            DEBUG_TX_ENDPOINT | 0x80,               // bEndpointAddress
            DEBUG_TX_SIZE, 0,                       // wMaxPacketSize
            DEBUG_TX_INTERVAL,                      // bInterval
            7,                                      // bLength
            DEBUG_RX_ENDPOINT,                      // bEndpointAddress
            DEBUG_RX_SIZE, 0,                       // wMaxPacketSize
            DEBUG_RX_INTERVAL                       // bInterval
    // If you're desperate for a little extra code memory, these strings
    // can be completely removed if iManufacturer, iProduct, iSerialNumber
    // in the device desciptor are changed to zeros.
    struct usb_string_descriptor_struct {
    	uint8_t bLength;
    	uint8_t bDescriptorType;
    	int16_t wString[];
    static const struct usb_string_descriptor_struct PROGMEM string0 = {
    	4,
    	3,
    	{0x0409}
    static const struct usb_string_descriptor_struct PROGMEM string1 = {
    	sizeof(STR_PRODUCT),
    	3,
    	STR_PRODUCT
    static const struct usb_string_descriptor_struct PROGMEM string2 = {
    	sizeof(STR_RAWHID),
    	3,
    	STR_RAWHID
    static const struct usb_string_descriptor_struct PROGMEM string3 = {
    	sizeof(STR_DEBUG),
    	3,
    	STR_DEBUG
    // This table defines which descriptor data is sent for each specific
    // request from the host (in wValue and wIndex).
    static const struct descriptor_list_struct {
    	uint16_t	wValue;
    	uint16_t	wIndex;
    	const uint8_t	*addr;
    	uint8_t		length;
    } PROGMEM descriptor_list[] = {
    	{0x0100, 0x0000, device_descriptor, sizeof(device_descriptor)},
    	{0x0200, 0x0000, config1_descriptor, sizeof(config1_descriptor)},
            {0x2200, RAWHID_INTERFACE, rawhid_hid_report_desc, sizeof(rawhid_hid_report_desc)},
            {0x2100, RAWHID_INTERFACE, config1_descriptor+RAWHID_HID_DESC_OFFSET, 9},
            {0x2200, DEBUG_INTERFACE, debug_hid_report_desc, sizeof(debug_hid_report_desc)},
            {0x2100, DEBUG_INTERFACE, config1_descriptor+DEBUG_HID_DESC_OFFSET, 9},
    	{0x0300, 0x0000, (const uint8_t *)&string0, 4},
    	{0x0301, 0x0409, (const uint8_t *)&string1, sizeof(STR_PRODUCT)},
    	{0x0302, 0x0409, (const uint8_t *)&string2, sizeof(STR_RAWHID)},
    	{0x0303, 0x0409, (const uint8_t *)&string3, sizeof(STR_DEBUG)},
    #define NUM_DESC_LIST (sizeof(descriptor_list)/sizeof(struct descriptor_list_struct))
     *  Variables - these are the only non-stack RAM usage
    // zero when we are not configured, non-zero when enumerated
    volatile uint8_t usb_configuration USBSTATE;
    volatile uint8_t usb_suspended USBSTATE;
    // the time remaining before we transmit any partially full
    // packet, or send a zero length packet.
    volatile uint8_t debug_flush_timer USBSTATE;
    // these are a more reliable timeout than polling the
    // frame counter (UDFNUML)
    volatile uint16_t rawhid_rx_timeout_count USBSTATE;
    volatile uint16_t rawhid_tx_timeout_count USBSTATE;
     *  Public Functions - these are the API intended for the user
    // initialize USB serial
    void usb_init(void)
    	uint8_t u;
    	u = USBCON;
    	if ((u & (1<<USBE)) && !(u & (1<<FRZCLK))) return;
    	HW_CONFIG();
            USB_FREEZE();				// enable USB
            PLL_CONFIG();				// config PLL
            while (!(PLLCSR & (1<<PLOCK))) ;	// wait for PLL lock
            USB_CONFIG();				// start USB clock
            UDCON = 0;				// enable attach resistor
    	usb_configuration = 0;
    	usb_suspended = 0;
    	debug_flush_timer = 0;
    	rawhid_rx_timeout_count = 0;
    	rawhid_tx_timeout_count = 0;
    	UDINT = 0;
            UDIEN = (1<<EORSTE)|(1<<SOFE);
    	//sei();  // init() in wiring.c does this
    void usb_shutdown(void)
    	UDIEN = 0;		// disable interrupts
    	UDCON = 1;		// disconnect attach resistor
    	USBCON = 0;		// shut off USB periperal
    	PLLCSR = 0;		// shut off PLL
    	usb_suspended = 1;
    // Public API functions moved to usb_api.cpp
     *  Private Functions - not intended for general user consumption....
    // USB Device Interrupt - handle all device-level events
    // the transmit buffer flushing is triggered by the start of frame
    ISR(USB_GEN_vect)
    	uint8_t intbits, t;
            intbits = UDINT;
            UDINT = 0;
            if (intbits & (1<<EORSTI)) {
    		UENUM = 0;
    		UECONX = 1;
    		UECFG0X = EP_TYPE_CONTROL;
    		UECFG1X = EP_SIZE(ENDPOINT0_SIZE) | EP_SINGLE_BUFFER;
    		UEIENX = (1<<RXSTPE);
            if ((intbits & (1<<SOFI)) && usb_configuration) {
                    t = debug_flush_timer;
                    if (t) {
                            debug_flush_timer = -- t;
                            if (!t) {
                                    UENUM = DEBUG_TX_ENDPOINT;
                                    while ((UEINTX & (1<<RWAL))) {
                                            UEDATX = 0;
                                    UEINTX = 0x3A;
                    t = rawhid_rx_timeout_count;
                    if (t) rawhid_rx_timeout_count = --t;
                    t = rawhid_tx_timeout_count;
                    if (t) rawhid_tx_timeout_count = --t;
    	if (intbits & (1<<SUSPI)) {
    		// USB Suspend (inactivity for 3ms)
    		UDIEN = (1<<WAKEUPE);
    		usb_suspended = 1;
    		#if (F_CPU >= 8000000L)
    		// WAKEUPI does not work with USB clock freeze
    		// when CPU is running less than 8 MHz.
    		// Is this a hardware bug?
    		USB_FREEZE();			// shut off USB
    		// to properly meet the USB spec, current must
    		// reduce to less than 2.5 mA, which means using
    		// powerdown mode, but that breaks the Arduino
    		// user's paradigm....
    	if (usb_suspended && (intbits & (1<<WAKEUPI))) {
    		// USB Resume (pretty much any activity)
    		PLL_CONFIG();
    		USB_CONFIG();
    		UDIEN = (1<<EORSTE)|(1<<SOFE)|(1<<SUSPE);
    		usb_suspended = 0;
    		return;
    // Misc functions to wait for ready and send/receive packets
    static inline void usb_wait_in_ready(void)
    	while (!(UEINTX & (1<<TXINI))) ;
    static inline void usb_send_in(void)
    	UEINTX = ~(1<<TXINI);
    static inline void usb_wait_receive_out(void)
    	while (!(UEINTX & (1<<RXOUTI))) ;
    static inline void usb_ack_out(void)
    	UEINTX = ~(1<<RXOUTI);
    // USB Endpoint Interrupt - endpoint 0 is handled here.  The
    // other endpoints are manipulated by the user-callable
    // functions, and the start-of-frame interrupt.
    ISR(USB_COM_vect)
            uint8_t intbits;
    	const uint8_t *list;
            const uint8_t *cfg;
    	uint8_t i, n, len, en;
    	uint8_t bmRequestType;
    	uint8_t bRequest;
    	uint16_t wValue;
    	uint16_t wIndex;
    	uint16_t wLength;
    	uint16_t desc_val;
    	const uint8_t *desc_addr;
    	uint8_t	desc_length;
    	UENUM = 0;
    	intbits = UEINTX;
    	if (intbits & (1<<RXSTPI)) {
    		bmRequestType = UEDATX;
    		bRequest = UEDATX;
    		read_word_lsbfirst(wValue, UEDATX);
    		read_word_lsbfirst(wIndex, UEDATX);
    		read_word_lsbfirst(wLength, UEDATX);
    		UEINTX = ~((1<<RXSTPI) | (1<<RXOUTI) | (1<<TXINI));
    		if (bRequest == GET_DESCRIPTOR) {
    			list = (const uint8_t *)descriptor_list;
    			for (i=0; ; i++) {
    				if (i >= NUM_DESC_LIST) {
    					UECONX = (1<<STALLRQ)|(1<<EPEN);  //stall
    					return;
    				pgm_read_word_postinc(desc_val, list);
    				if (desc_val != wValue) {
    					list += sizeof(struct descriptor_list_struct)-2;
    					continue;
    				if (desc_val != wIndex) {
    					list += sizeof(struct descriptor_list_struct)-4;
    					continue;
    				pgm_read_word_postinc(desc_addr, list);
    				desc_length = pgm_read_byte(list);
    			len = (wLength < 256) ? wLength : 255;
    			if (len > desc_length) len = desc_length;
    			list = desc_addr;
    			do {
    				// wait for host ready for IN packet
    				do {
    					i = UEINTX;
    				} while (!(i & ((1<<TXINI)|(1<<RXOUTI))));
    				if (i & (1<<RXOUTI)) return;	// abort
    				// send IN packet
    				n = len < ENDPOINT0_SIZE ? len : ENDPOINT0_SIZE;
    				for (i = n; i; i--) {
    					pgm_read_byte_postinc(UEDATX, list);
    				len -= n;
    				usb_send_in();
    			} while (len || n == ENDPOINT0_SIZE);
    			return;
    		if (bRequest == SET_ADDRESS) {
    			usb_send_in();
    			usb_wait_in_ready();
    			UDADDR = wValue | (1<<ADDEN);
    			return;
    		if (bRequest == SET_CONFIGURATION && bmRequestType == 0) {
    			usb_configuration = wValue;
    			usb_send_in();
    			cfg = endpoint_config_table;
    			for (i=1; i<NUM_ENDPOINTS; i++) {
    				UENUM = i;
    				pgm_read_byte_postinc(en, cfg);
    				UECONX = en;
    				if (en) {
    					pgm_read_byte_postinc(UECFG0X, cfg);
    					pgm_read_byte_postinc(UECFG1X, cfg);
            		UERST = 0x1E;
            		UERST = 0;
    			return;
    		if (bRequest == GET_CONFIGURATION && bmRequestType == 0x80) {
    			UEDATX = usb_configuration;
    			usb_send_in();
    			return;
    		if (bRequest == GET_STATUS) {
    			i = 0;
    			if (bmRequestType == 0x82) {
    				UENUM = wIndex;
    				if (UECONX & (1<<STALLRQ)) i = 1;
    				UENUM = 0;
    			UEDATX = i;
    			UEDATX = 0;
    			usb_send_in();
    			return;
    		if ((bRequest == CLEAR_FEATURE || bRequest == SET_FEATURE)
    		  && bmRequestType == 0x02 && wValue == 0) {
    			i = wIndex & 0x7F;
    			if (i >= 1 && i <= NUM_ENDPOINTS) {
    				usb_send_in();
    				UENUM = i;
    				if (bRequest == SET_FEATURE) {
    					UECONX = (1<<STALLRQC)|(1<<RSTDT)|(1<<EPEN);
    					UERST = (1 << i);
    					UERST = 0;
    				return;
                    if (wIndex == RAWHID_INTERFACE) {
                            if (bmRequestType == 0xA1 && bRequest == HID_GET_REPORT) {
                                    len = RAWHID_TX_SIZE;
                                    do {
                                            do {
                                                    i = UEINTX;
                                            // send IN packet
                                                    // just send zeros
                                                    UEDATX = 0;
                                            len -= n;
                                            usb_send_in();
                                    return;
                            if (bmRequestType == 0x21 && bRequest == HID_SET_REPORT) {
                                    len = RAWHID_RX_SIZE;
                                    do {
                                            usb_wait_receive_out();
                                            // ignore incoming bytes
                                            usb_ack_out();
                                            len -= n;
                                    } while (len);
                                    usb_send_in();
                                    return;
                    if (wIndex == DEBUG_INTERFACE) {
                            if (bRequest == HID_GET_REPORT && bmRequestType == 0xA1) {
                                    len = wLength;
                                    do {
                                            do {
                                                    i = UEINTX;
                                            // send IN packet
                                                    UEDATX = 0;
                                            len -= n;
                                            usb_send_in();
                                    return;
                            if (bRequest == HID_SET_REPORT && bmRequestType == 0x21) {
    				if (wValue == 0x0300 && wLength == 0x0004) {
    					uint8_t b1, b2, b3, b4;
    					b1 = UEDATX;
    					b2 = UEDATX;
    					b3 = UEDATX;
    					b4 = UEDATX;
                                            usb_ack_out();
                                            usb_send_in();
    					if (b1 == 0xA9 && b2 == 0x45 && b3 == 0xC2 && b4 == 0x6B)
    						_reboot_Teensyduino_();
    					if (b1 == 0x8B && b2 == 0xC5 && b3 == 0x1D && b4 == 0x70)
    						_restart_Teensyduino_();
    		if (bRequest == 0xC9 && bmRequestType == 0x40) {
    			usb_send_in();
    	UECONX = (1<<STALLRQ) | (1<<EPEN);	// stall
    Jun 2013
    296
    I increase that bcdDevice number and everything works! Thank-you so much much for your help!
    Boston, MA, USA
    1,106
    I guess this MIDI expression pedal interface with software controllable CC, channel and curve is the result?
    Jun 2013
    296
    That's correct. I originally designed the device to work with a software drum brain I develop, but adding the MIDI functionality should make it much more broadly marketable.
