Administrator
Teensyduino 1.15 Released
Teensyduino 1.15 has been officially released.
http://www.pjrc.com/teensy/td_download.html
For a detailed list of all the changes since 1.14, scroll down to "Teensyduino Revision History".
Thanks!!! Good Job!!! ¿there exist some "revision control" to contribute or get some devel branch of Teensyduino?
Originally Posted by
Paul
I understand this might be a stupid question but I had to have a go. How do I figure out which version of Teensyduino I'm on currently? I want to upgrade but I want to see the changelog before I do. Thanks!
Make sure Teensy Loader is not running. Then click Verify in Arduino, so the Teensy Loader installed by Teensyduino runs. Look in the Teensy Loader's verbose info (help menu). Prior to 1.15, Teensy Loader had a different version number from Teensyduino. Now they're in sync, so if it's Teensy Loader 1.15, then you have Teensyduino 1.15.
If you have Teensy Loader 1.07 or older, look in the comments when you do an upload. When the Teensyduino utilities send the filename to the Teensy Loader, the version of Teensyduino should be shown.
PaulStoffregen
Thanks, that was quick!
Loader = 1.07
Teensyduino = 1.13.
Cheers.
Thanks for this Paul,
what was the problem with USB MIDI sendProgramChange in earlier versions?
- You may not post replies
- You may not edit your posts
Forum Rules
