Results 1 to 3 of 3
Thread: "Error reading Teensy Loader status! (tr)This error should never happen."
    May 2013
    San Jose, CA
    680
    My ability to update the program on my Teensy 3 is intermittent with various failure modes. I've included as much output as I can find below on a recent one. I work around this by retrying the upload, unplugging the USB cable, or power cycling the T3. I haven't counted but upload problems happen several times an hour when I'm uploading code frequently.
    Sometimes, the Arduino environment reports a "shouldn't happen" error. Sometimes it claims the Teensy Loader is busy. Sometimes when it claims the Teensy loader is busy, it works anyway. Sometimes the Teensy loader hangs erasing the part. There isn't a single consistent pattern to it.
    For what it's worth, I also have trouble connecting the serial monitor both from the Arduino environment and from the command line using the cu command, like this:
    sudo cu -l /dev/tty.usbmodem* -s 9600 --nostop --parity=none
    The laptop I'm using is a 2007 MacBook Pro running OS X 10.8.4.
    From the Teensy loader:
    Verbose Information
    00:40:50: Teensy Loader 1.15-rc1, begin program
    00:40:50: File "Morse.cpp.hex". 33968 bytes, 26% used
    00:40:50: Listening for remote control on port 3149
    00:40:50: initialized, showing main window
    00:40:50: remote connection opened
    00:40:50: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    00:40:50: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build1320331754475755942.tmp/"
    00:40:50: remote cmd: "file:Morse.cpp.hex"
    00:40:50: remote cmd: "status"
    00:40:50: status data sent
    00:40:50: remote cmd: "auto:on"
    00:40:50: remote connection closed
    00:40:51: HID/macos: no devices found
    07:40:57: remote connection opened
    07:40:57: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    07:40:57: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build1320331754475755942.tmp/"
    07:40:57: remote cmd: "file:Morse.cpp.hex"
    07:40:57: File "Morse.cpp.hex". 33968 bytes, 26% used
    07:40:57: remote cmd: "status"
    07:40:57: status data sent
    07:40:57: remote connection closed
    07:40:58: remote cmd: "status"
    07:40:58: status data sent
    07:40:59: remote cmd: "status"
    07:40:59: status data sent
    07:41:00: remote cmd: "status"
    07:41:00: status data sent
    07:41:01: remote cmd: "status"
    07:41:01: status data sent
    07:41:02: remote cmd: "status"
    07:41:02: status data sent
    07:41:03: remote connection closed
    07:41:17: file changed
    07:41:17: File "Morse.cpp.hex". 33968 bytes, 26% used
    07:41:17: remote connection opened
    07:41:17: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    07:41:17: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build1320331754475755942.tmp/"
    07:41:17: remote cmd: "file:Morse.cpp.hex"
    07:41:17: remote cmd: "status"
    07:41:17: status data sent
    07:41:17: remote connection closed
    07:41:18: remote connection opened
    07:41:18: remote cmd: "status"
    07:41:18: status data sent
    07:41:18: Device came online, code_size = 131072
    07:41:18: Board is: Teensy 3.0 (MK20DX128)
    07:41:18: File "Morse.cpp.hex". 33968 bytes, 26% used
    07:41:18: elf size appears to be 131072
    07:41:18: elf binary data matches hex file
    07:41:18: Code size from .elf file = 131072
    07:41:18: begin operation
    07:41:18: flash, block=0, bs=1024, auto=1
    07:41:18: flash, block=1, bs=1024, auto=1
    07:41:18: remote connection closed
    07:41:18: flash, block=2, bs=1024, auto=1
    07:41:18: flash, block=3, bs=1024, auto=1
    07:41:18: flash, block=4, bs=1024, auto=1
    07:41:18: flash, block=5, bs=1024, auto=1
    07:41:18: flash, block=6, bs=1024, auto=1
    07:41:18: flash, block=7, bs=1024, auto=1
    07:41:18: flash, block=8, bs=1024, auto=1
    07:41:18: HID/macos: waiting for device
    07:41:18: flash, block=9, bs=1024, auto=1
    07:41:18: flash, block=10, bs=1024, auto=1
    07:41:19: HID/macos: waiting for device
    07:41:19: flash, block=11, bs=1024, auto=1
    07:41:19: flash, block=12, bs=1024, auto=1
    07:41:19: flash, block=13, bs=1024, auto=1
    07:41:19: flash, block=14, bs=1024, auto=1
    07:41:19: flash, block=15, bs=1024, auto=1
    07:41:19: flash, block=16, bs=1024, auto=1
    07:41:19: flash, block=17, bs=1024, auto=1
    07:41:19: flash, block=18, bs=1024, auto=1
    07:41:19: flash, block=19, bs=1024, auto=1
    07:41:19: flash, block=20, bs=1024, auto=1
    07:41:19: flash, block=21, bs=1024, auto=1
    07:41:19: flash, block=22, bs=1024, auto=1
    07:41:19: flash, block=23, bs=1024, auto=1
    07:41:19: flash, block=24, bs=1024, auto=1
    07:41:19: flash, block=25, bs=1024, auto=1
    07:41:19: flash, block=26, bs=1024, auto=1
    07:41:19: flash, block=27, bs=1024, auto=1
    07:41:19: flash, block=28, bs=1024, auto=1
    07:41:19: flash, block=29, bs=1024, auto=1
    07:41:19: flash, block=30, bs=1024, auto=1
    07:41:19: flash, block=31, bs=1024, auto=1
    07:41:19: flash, block=32, bs=1024, auto=1
    07:41:19: flash, block=33, bs=1024, auto=1
    07:41:19: sending reboot
    07:41:19: begin wait_until_offline
    07:41:19: HID/macos: status: ok
    07:41:19: offline, waited 9
    07:41:19: end operation
    07:41:19: redraw timer set, image 14 to show for 1200 ms
    07:41:19: HID/macos: number of devices found = 0
    07:41:19: HID/macos: no devices found (empty set)
    07:41:20: redraw, image 9
    17:30:28: remote connection opened
    17:30:28: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    17:30:28: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build1320331754475755942.tmp/"
    17:30:28: remote cmd: "file:Morse.cpp.hex"
    17:30:28: File "Morse.cpp.hex". 34512 bytes, 26% used
    17:30:28: remote cmd: "status"
    17:30:28: status data sent
    17:30:28: remote connection closed
    17:30:29: remote cmd: "status"
    17:30:29: status data sent
    17:30:29: Device came online, code_size = 131072
    17:30:29: Board is: Teensy 3.0 (MK20DX128)
    17:30:29: File "Morse.cpp.hex". 34512 bytes, 26% used
    17:30:29: elf size appears to be 131072
    17:30:29: elf binary data matches hex file
    17:30:29: Code size from .elf file = 131072
    17:30:29: begin operation
    17:30:29: flash, block=0, bs=1024, auto=1
    17:30:29: flash, block=1, bs=1024, auto=1
    17:30:29: remote connection closed
    17:30:29: flash, block=2, bs=1024, auto=1
    17:30:29: flash, block=3, bs=1024, auto=1
    17:30:29: flash, block=4, bs=1024, auto=1
    17:30:29: flash, block=5, bs=1024, auto=1
    17:30:29: flash, block=6, bs=1024, auto=1
    17:30:29: flash, block=7, bs=1024, auto=1
    17:30:29: flash, block=8, bs=1024, auto=1
    17:30:29: flash, block=9, bs=1024, auto=1
    17:30:29: flash, block=10, bs=1024, auto=1
    17:30:29: flash, block=11, bs=1024, auto=1
    17:30:29: flash, block=12, bs=1024, auto=1
    17:30:29: flash, block=13, bs=1024, auto=1
    17:30:29: HID/macos: waiting for device
    17:30:29: flash, block=14, bs=1024, auto=1
    17:30:29: flash, block=15, bs=1024, auto=1
    17:30:29: flash, block=16, bs=1024, auto=1
    17:30:29: flash, block=17, bs=1024, auto=1
    17:30:29: flash, block=18, bs=1024, auto=1
    17:30:29: flash, block=19, bs=1024, auto=1
    17:30:29: flash, block=20, bs=1024, auto=1
    17:30:29: flash, block=21, bs=1024, auto=1
    17:30:29: flash, block=22, bs=1024, auto=1
    17:30:29: flash, block=23, bs=1024, auto=1
    17:30:29: flash, block=24, bs=1024, auto=1
    17:30:29: flash, block=25, bs=1024, auto=1
    17:30:29: flash, block=26, bs=1024, auto=1
    17:30:29: flash, block=27, bs=1024, auto=1
    17:30:29: flash, block=28, bs=1024, auto=1
    17:30:29: flash, block=29, bs=1024, auto=1
    17:30:29: flash, block=30, bs=1024, auto=1
    17:30:29: flash, block=31, bs=1024, auto=1
    17:30:29: flash, block=32, bs=1024, auto=1
    17:30:29: flash, block=33, bs=1024, auto=1
    17:30:29: sending reboot
    17:30:29: begin wait_until_offline
    17:30:29: HID/macos: status: ok
    17:30:29: offline, waited 4
    17:30:29: end operation
    17:30:29: redraw timer set, image 14 to show for 1200 ms
    17:30:30: HID/macos: number of devices found = 0
    17:30:30: HID/macos: no devices found (empty set)
    17:30:31: redraw, image 9
    17:34:44: remote connection opened
    17:34:44: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    17:34:44: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build1320331754475755942.tmp/"
    17:34:44: remote cmd: "file:Morse.cpp.hex"
    17:34:44: File "Morse.cpp.hex". 34528 bytes, 26% used
    17:34:44: remote cmd: "status"
    17:34:44: status data sent
    17:34:44: remote connection closed
    17:47:30: remote connection opened
    17:47:30: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    17:47:30: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
    17:47:30: remote cmd: "file:Morse.cpp.hex"
    17:47:30: File "Morse.cpp.hex". 34776 bytes, 27% used
    17:47:30: remote cmd: "status"
    17:47:30: status data sent
    17:47:30: remote connection closed
    17:47:30: Device came online, code_size = 131072
    17:47:30: Board is: Teensy 3.0 (MK20DX128)
    17:47:30: elf size appears to be 131072
    17:47:30: elf binary data matches hex file
    17:47:30: Code size from .elf file = 131072
    17:47:30: begin operation
    17:47:30: flash, block=0, bs=1024, auto=1
    17:47:31: remote connection closed
    17:47:31: flash, block=1, bs=1024, auto=1
    17:47:31: HID/macos: waiting for device
    17:47:31: flash, block=2, bs=1024, auto=1
    17:47:31: flash, block=3, bs=1024, auto=1
    17:47:31: flash, block=4, bs=1024, auto=1
    17:47:31: flash, block=5, bs=1024, auto=1
    17:47:31: flash, block=6, bs=1024, auto=1
    17:47:31: flash, block=7, bs=1024, auto=1
    17:47:31: flash, block=8, bs=1024, auto=1
    17:47:31: flash, block=9, bs=1024, auto=1
    17:47:31: flash, block=10, bs=1024, auto=1
    17:47:31: flash, block=11, bs=1024, auto=1
    17:47:31: flash, block=12, bs=1024, auto=1
    17:47:31: flash, block=13, bs=1024, auto=1
    17:47:31: flash, block=14, bs=1024, auto=1
    17:47:31: flash, block=15, bs=1024, auto=1
    17:47:31: flash, block=16, bs=1024, auto=1
    17:47:31: flash, block=17, bs=1024, auto=1
    17:47:31: flash, block=18, bs=1024, auto=1
    17:47:31: flash, block=19, bs=1024, auto=1
    17:47:31: flash, block=20, bs=1024, auto=1
    17:47:31: flash, block=21, bs=1024, auto=1
    17:47:31: flash, block=22, bs=1024, auto=1
    17:47:31: flash, block=23, bs=1024, auto=1
    17:47:31: flash, block=24, bs=1024, auto=1
    17:47:31: flash, block=25, bs=1024, auto=1
    17:47:31: flash, block=26, bs=1024, auto=1
    17:47:31: flash, block=27, bs=1024, auto=1
    17:47:31: flash, block=28, bs=1024, auto=1
    17:47:31: flash, block=29, bs=1024, auto=1
    17:47:31: flash, block=30, bs=1024, auto=1
    17:47:31: flash, block=31, bs=1024, auto=1
    17:47:31: flash, block=32, bs=1024, auto=1
    17:47:31: flash, block=33, bs=1024, auto=1
    17:47:31: sending reboot
    17:47:31: begin wait_until_offline
    17:47:31: HID/macos: status: ok
    17:47:31: offline, waited 3
    17:47:31: end operation
    17:47:31: redraw timer set, image 14 to show for 1200 ms
    17:47:31: HID/macos: number of devices found = 0
    17:47:31: HID/macos: no devices found (empty set)
    17:47:32: redraw, image 9
    17:53:09: remote connection opened
    17:53:09: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    17:53:09: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
    17:53:09: remote cmd: "file:Morse.cpp.hex"
    17:53:09: File "Morse.cpp.hex". 34760 bytes, 27% used
    17:53:09: remote cmd: "status"
    17:53:09: status data sent
    17:53:09: remote connection closed
    17:53:10: remote cmd: "status"
    17:53:10: status data sent
    17:53:10: Device came online, code_size = 131072
    17:53:10: Board is: Teensy 3.0 (MK20DX128)
    17:53:10: File "Morse.cpp.hex". 34760 bytes, 27% used
    17:53:10: elf size appears to be 131072
    17:53:10: elf binary data matches hex file
    17:53:10: Code size from .elf file = 131072
    17:53:10: begin operation
    17:53:10: flash, block=0, bs=1024, auto=1
    17:53:10: remote connection closed
    17:53:10: flash, block=1, bs=1024, auto=1
    17:53:10: flash, block=2, bs=1024, auto=1
    17:53:10: flash, block=3, bs=1024, auto=1
    17:53:10: HID/macos: waiting for device
    17:53:10: flash, block=4, bs=1024, auto=1
    17:53:10: flash, block=5, bs=1024, auto=1
    17:53:10: flash, block=6, bs=1024, auto=1
    17:53:10: flash, block=7, bs=1024, auto=1
    17:53:10: flash, block=8, bs=1024, auto=1
    17:53:10: flash, block=9, bs=1024, auto=1
    17:53:10: flash, block=10, bs=1024, auto=1
    17:53:10: flash, block=11, bs=1024, auto=1
    17:53:10: flash, block=12, bs=1024, auto=1
    17:53:10: flash, block=13, bs=1024, auto=1
    17:53:10: flash, block=14, bs=1024, auto=1
    17:53:10: flash, block=15, bs=1024, auto=1
    17:53:10: flash, block=16, bs=1024, auto=1
    17:53:10: flash, block=17, bs=1024, auto=1
    17:53:10: flash, block=18, bs=1024, auto=1
    17:53:10: flash, block=19, bs=1024, auto=1
    17:53:10: flash, block=20, bs=1024, auto=1
    17:53:10: flash, block=21, bs=1024, auto=1
    17:53:10: flash, block=22, bs=1024, auto=1
    17:53:10: flash, block=23, bs=1024, auto=1
    17:53:10: flash, block=24, bs=1024, auto=1
    17:53:10: flash, block=25, bs=1024, auto=1
    17:53:10: flash, block=26, bs=1024, auto=1
    17:53:10: flash, block=27, bs=1024, auto=1
    17:53:10: flash, block=28, bs=1024, auto=1
    17:53:10: flash, block=29, bs=1024, auto=1
    17:53:10: flash, block=30, bs=1024, auto=1
    17:53:10: flash, block=31, bs=1024, auto=1
    17:53:10: flash, block=32, bs=1024, auto=1
    17:53:11: flash, block=33, bs=1024, auto=1
    17:53:11: sending reboot
    17:53:11: begin wait_until_offline
    17:53:11: HID/macos: status: ok
    17:53:11: offline, waited 3
    17:53:11: end operation
    17:53:11: redraw timer set, image 14 to show for 1200 ms
    17:53:11: HID/macos: number of devices found = 0
    17:53:11: HID/macos: no devices found (empty set)
    17:53:12: redraw, image 9
    21:29:10: remote connection opened
    21:29:10: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    21:29:10: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
    21:29:10: remote cmd: "file:Morse.cpp.hex"
    21:29:10: File "Morse.cpp.hex". 34760 bytes, 27% used
    21:29:10: remote cmd: "status"
    21:29:10: status data sent
    21:29:10: remote connection closed
    21:37:32: remote connection opened
    21:37:32: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    21:37:32: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
    21:37:32: remote cmd: "file:Morse.cpp.hex"
    21:37:32: File "Morse.cpp.hex". 34760 bytes, 27% used
    21:37:32: remote cmd: "status"
    21:37:32: status data sent
    21:37:32: remote connection closed
    21:45:10: remote connection opened
    21:45:10: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    21:45:10: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
    21:45:10: remote cmd: "file:Morse.cpp.hex"
    21:45:10: File "Morse.cpp.hex". 34776 bytes, 27% used
    21:45:10: remote cmd: "status"
    21:45:10: status data sent
    21:45:10: remote connection closed
    22:37:09: remote connection opened
    22:37:09: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    22:37:09: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
    22:37:09: remote cmd: "file:Morse.cpp.hex"
    22:37:09: File "Morse.cpp.hex". 34768 bytes, 27% used
    22:37:09: remote cmd: "status"
    22:37:09: status data sent
    22:37:09: remote connection closed
    23:07:23: remote connection opened
    23:07:23: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    23:07:23: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
    23:07:23: remote cmd: "file:Morse.cpp.hex"
    23:07:23: File "Morse.cpp.hex". 35088 bytes, 27% used
    23:07:23: remote cmd: "status"
    23:07:23: status data sent
    23:07:23: remote connection closed
    23:21:15: remote connection opened
    23:21:15: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    23:21:15: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
    23:21:15: remote cmd: "file:Morse.cpp.hex"
    23:21:15: File "Morse.cpp.hex". 35088 bytes, 27% used
    23:21:15: remote cmd: "status"
    23:21:15: status data sent
    23:21:15: remote connection closed
    07:58:57: remote connection opened
    07:58:57: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    07:58:57: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
    07:58:57: remote cmd: "file:Morse.cpp.hex"
    07:58:57: File "Morse.cpp.hex". 35064 bytes, 27% used
    07:58:57: remote cmd: "status"
    07:58:57: status data sent
    07:58:57: remote connection closed
    07:58:58: remote cmd: "status"
    07:58:58: status data sent
    07:58:59: remote cmd: "status"
    07:58:59: status data sent
    07:59:00: remote cmd: "status"
    07:59:00: status data sent
    07:59:01: remote cmd: "status"
    07:59:01: status data sent
    07:59:02: remote cmd: "status"
    07:59:02: status data sent
    07:59:02: remote connection closed
    08:19:17: file changed
    08:19:17: File "Morse.cpp.hex". 35296 bytes, 27% used
    08:19:17: remote connection opened
    08:19:17: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    08:19:17: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
    08:19:17: remote cmd: "file:Morse.cpp.hex"
    08:19:17: remote cmd: "status"
    08:19:17: status data sent
    08:19:17: remote connection closed
    08:44:15: remote connection opened
    08:44:15: file changed
    08:44:15: File "Morse.cpp.hex". 35300 bytes, 27% used
    08:44:15: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    08:44:15: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
    08:44:15: remote cmd: "file:Morse.cpp.hex"
    08:44:15: remote cmd: "status"
    08:44:15: status data sent
    08:44:15: remote connection closed
    14:52:23: remote connection opened
    14:52:24: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    14:52:24: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
    14:52:24: remote cmd: "file:Morse.cpp.hex"
    14:52:24: File "Morse.cpp.hex". 35300 bytes, 27% used
    14:52:24: remote cmd: "status"
    14:52:24: status data sent
    14:52:24: remote connection closed
    14:52:24: remote connection opened
    14:52:25: remote cmd: "status"
    14:52:25: status data sent
    14:52:26: remote cmd: "status"
    14:52:26: status data sent
    14:52:27: remote cmd: "status"
    14:52:27: status data sent
    14:52:28: remote cmd: "status"
    14:52:28: status data sent
    14:52:29: remote cmd: "status"
    14:52:29: status data sent
    14:52:29: remote connection closed
    14:52:38: remote connection opened
    14:52:38: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    14:52:38: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
    14:52:38: remote cmd: "file:Morse.cpp.hex"
    14:52:38: File "Morse.cpp.hex". 35300 bytes, 27% used
    14:52:38: remote cmd: "status"
    14:52:38: status data sent
    14:52:38: remote connection closed
    14:52:39: remote cmd: "status"
    14:52:39: status data sent
    14:52:39: Device came online, code_size = 131072
    14:52:39: Board is: Teensy 3.0 (MK20DX128)
    14:52:39: File "Morse.cpp.hex". 35300 bytes, 27% used
    14:52:39: elf size appears to be 131072
    14:52:39: elf binary data matches hex file
    14:52:39: Code size from .elf file = 131072
    14:52:39: begin operation
    14:52:39: flash, block=0, bs=1024, auto=1
    14:52:39: HID/macos: waiting for device
    14:52:39: remote connection closed
    14:52:39: flash, block=1, bs=1024, auto=1
    14:52:39: flash, block=2, bs=1024, auto=1
    14:52:39: flash, block=3, bs=1024, auto=1
    14:52:39: flash, block=4, bs=1024, auto=1
    14:52:39: flash, block=5, bs=1024, auto=1
    14:52:39: flash, block=6, bs=1024, auto=1
    14:52:39: flash, block=7, bs=1024, auto=1
    14:52:39: flash, block=8, bs=1024, auto=1
    14:52:40: flash, block=9, bs=1024, auto=1
    14:52:40: flash, block=10, bs=1024, auto=1
    14:52:40: flash, block=11, bs=1024, auto=1
    14:52:40: flash, block=12, bs=1024, auto=1
    14:52:40: flash, block=13, bs=1024, auto=1
    14:52:40: HID/macos: waiting for device
    14:52:40: flash, block=14, bs=1024, auto=1
    14:52:40: flash, block=15, bs=1024, auto=1
    14:52:40: flash, block=16, bs=1024, auto=1
    14:52:40: flash, block=17, bs=1024, auto=1
    14:52:40: flash, block=18, bs=1024, auto=1
    14:52:40: flash, block=19, bs=1024, auto=1
    14:52:40: flash, block=20, bs=1024, auto=1
    14:52:40: flash, block=21, bs=1024, auto=1
    14:52:40: flash, block=22, bs=1024, auto=1
    14:52:40: flash, block=23, bs=1024, auto=1
    14:52:40: flash, block=24, bs=1024, auto=1
    14:52:40: flash, block=25, bs=1024, auto=1
    14:52:40: flash, block=26, bs=1024, auto=1
    14:52:40: flash, block=27, bs=1024, auto=1
    14:52:40: flash, block=28, bs=1024, auto=1
    14:52:40: flash, block=29, bs=1024, auto=1
    14:52:40: flash, block=30, bs=1024, auto=1
    14:52:40: flash, block=31, bs=1024, auto=1
    14:52:40: flash, block=32, bs=1024, auto=1
    14:52:40: flash, block=33, bs=1024, auto=1
    14:52:40: flash, block=34, bs=1024, auto=1
    14:52:40: sending reboot
    14:52:40: begin wait_until_offline
    14:52:40: HID/macos: status: ok
    14:52:42: offline failed, timeout after 50
    14:52:42: reboot error
    14:52:42: end operation
    14:52:42: redraw timer set, image 13 to show for 4000 ms
    14:52:46: redraw, image 10
    14:53:00: remote connection opened
    14:53:00: remote cmd: "comment: Teensyduino 1.15-rc1 - MACOSX"
    14:53:00: remote cmd: "dir:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/"
    14:53:00: remote cmd: "file:Morse.cpp.hex"
    14:53:00: File "Morse.cpp.hex". 35292 bytes, 27% used
    14:53:00: remote cmd: "status"
    14:53:00: status data sent
    14:53:00: remote cmd: "auto:on"
    14:53:00: elf size appears to be 131072
    14:53:00: elf binary data matches hex file
    14:53:00: Code size from .elf file = 131072
    14:53:00: begin operation
    14:53:00: remote connection closed
    14:53:00: flash, block=0, bs=1024, auto=1
    14:53:11: program: write error
    14:53:11: remote cmd: "status"
    14:53:11: status data sent
    14:53:11: remote connection closed
    14:53:11: end operation
    14:53:11: redraw timer set, image 11 to show for 4000 ms
    14:53:15: redraw, image 10
    14:53:22: Open File event
    14:53:57: Verbose Info event
    Arduino Compiler Output
    /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=24000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -fno-rtti -felide-constructors -std=gnu++0x -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -I/Applications/Arduino.app/Contents/Resources/Java/libraries/EEPROM -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Time /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/actions.cpp -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/actions.cpp.o
    /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=24000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -fno-rtti -felide-constructors -std=gnu++0x -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -I/Applications/Arduino.app/Contents/Resources/Java/libraries/EEPROM -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Time /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/libmorse.cpp -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/libmorse.cpp.o
    /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=24000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -fno-rtti -felide-constructors -std=gnu++0x -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -I/Applications/Arduino.app/Contents/Resources/Java/libraries/EEPROM -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Time /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/mac.cpp -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/mac.cpp.o
    /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=24000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -fno-rtti -felide-constructors -std=gnu++0x -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -I/Applications/Arduino.app/Contents/Resources/Java/libraries/EEPROM -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Time /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.o
    /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=24000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -fno-rtti -felide-constructors -std=gnu++0x -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 -I/Applications/Arduino.app/Contents/Resources/Java/libraries/EEPROM -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Time /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/teensy3_morse_bsp.cpp -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/teensy3_morse_bsp.cpp.o
    teensy3_morse_bsp.cpp: In function 'void check_read_dword()':
    teensy3_morse_bsp.cpp:283:12: warning: unused variable 'e' [-Wunused-variable]
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/EEPROM/EEPROM.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Time/DateStrings.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Time/Time.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/analog.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/eeprom.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/keylayouts.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/math_helper.c.o
    /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=24000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -DTIME_T=1372517580 -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/mk20dx128.c -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/mk20dx128.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/nonstd.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/pins_teensy.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/serial1.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/serial2.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/serial3.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/touch.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_desc.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_dev.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_joystick.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_keyboard.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_mem.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_midi.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_mouse.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_rawhid.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_seremu.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_serial.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/yield.c.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/HardwareSerial1.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/HardwareSerial2.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/HardwareSerial3.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/IntervalTimer.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/IPAddress.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/main.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Print.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Stream.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Tone.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_flightsim.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_inst.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/WMath.cpp.o
    Using previously compiled: /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/WString.cpp.o
    /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -Os -Wl,--gc-sections -mcpu=cortex-m4 -mthumb -T/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/mk20dx128.ld -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.elf /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/actions.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/libmorse.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/mac.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/teensy3_morse_bsp.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/EEPROM/EEPROM.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Time/DateStrings.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Time/Time.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/analog.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/eeprom.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/keylayouts.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/math_helper.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/mk20dx128.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/nonstd.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/pins_teensy.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/serial1.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/serial2.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/serial3.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/touch.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_desc.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_dev.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_joystick.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_keyboard.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_mem.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_midi.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_mouse.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_rawhid.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_seremu.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_serial.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/yield.c.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/HardwareSerial1.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/HardwareSerial2.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/HardwareSerial3.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/IntervalTimer.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/IPAddress.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/main.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Print.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Stream.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Tone.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_flightsim.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/usb_inst.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/WMath.cpp.o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/WString.cpp.o -L/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp -larm_cortexM4l_math -lm
    /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.elf /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.eep
    /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-objcopy -O ihex -R .eeprom /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.elf /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.hex
    Binary sketch size: 33,152 bytes (of a 131,072 byte maximum)
    Estimated memory use: 8,528 bytes (of a 16,384 byte maximum)
    /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/teensy_reboot -v -v -v -v -pmk20dx128 -chalfkay -P/dev/tty.usbmodem12341 -b12000000 -D -Uflash:w:/var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/Morse.cpp.hex:i
    teensy_reboot, verbose mode
    trying port 3149
    get_line: "Teensy Loader 1.15-rc1"
    found Teensy Loader, version 1.15
    send: status - at Sat Jun 29 14:53:00 2013
    sent: status - at Sat Jun 29 14:53:00 2013
    Error reading Teensy Loader status! (tr)This error should never happen. Please report this to paul@pjrc.com, hopefully with enough information to reproduce the problem so it can be understood and fixed!
    Second try
    /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/arm-none-eabi/bin/arm-none-eabi-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=24000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX128__ -DTIME_T=1372517751 -DUSB_SERIAL_HID -DLAYOUT_US_ENGLISH -I/Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3 /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy/cores/teensy3/mk20dx128.c -o /var/folders/05/pcw9blpx5931b0rppzlcbpmr0000gn/T/build7504295830020799992.tmp/mk20dx128.c.o
    trying port 3149
    trying port 25981
    trying port 6837
    trying port 4782
    trying port 5293
    trying port 13752
    Unable find Teensy Loader. Is the Teensy Loader application running?
    trying port 3149
    trying port 25981
    trying port 6837
    trying port 4782
    trying port 5293
    trying port 13752
    22,754
    There's definitely a known bug on the Mac. I'm working on it, but it's been slow going. I got diverted for several days to release 1.15, which fixed other issues on all platforms and added a couple small but important features.
    Please post this on the mac errors thread. It really helps me if all the Mac-related stuff is on a single thread. I will be reviewing everything on that thread as I work on the Mac code...
    May 2013
    San Jose, CA
    680
    Done. And output converted to attachments. Thanks!
