Results 1 to 4 of 4
Thread: Control Teensy 3.0 via game pad?
    Jul 2013
    2
    Question Control Teensy 3.0 via game pad?
    I have a project for which I would like to control three seperate stepper motors independently using the analog sticks on a game-pad. One analog stick will control one pair of steppers (x and y) and the second stick will control the final motor. I was initially planning on doing this with a Raspberry Pi and a PS3 game pad. This way I could use the shoulder buttons to switch between coarse and fine motions (i.e. full steps and micro-steps). Now I'm wondering if it will be possible to do it with a Teensy 3.0 instead of a Rasperry Pi. I prefer the simplicity of the Teensy for this task. I know that analog control sticks are available on SparkFun (https://www.sparkfun.com/products/9032) but I like the form factor of the joypad with the buttons, etc. So are there any libraries out there which will allow me to plug a USB joypad into the Teensy and convert position of the analog sticks into whatever output signal I choose (e.g. a "tone" or an analog output) to contol the stepper drivers? I guess an alternative might be open up the joypad, by-pass the USB, and hook up the buttons and analog sticks I need directly to the Teensy input pins. That would be a pain, though. Anyone have suggestions?
    EDIT: it seems that this might be one option: http://airspayce.com/mikem/arduino/USBJoystick/ and another: USB host shield and PS3: http://www.circuitsathome.com/mcu/so...#comment-22205
    Any other suggestions would, of course, be welcome!
    20,556
    You would need something like the host shield, but its library is not ported to Teensy3 yet.
    I actually started work on this recently, but it got set aside because so many other things were more urgent. Here's the work-in-progress code. It at least compiles, but it's untested so far. If you're feeling like a challenge, this might be interesting. But if you're looking for an easy path to getting the PS3 controller working, this probably isn't ready just yet.
    https://github.com/PaulStoffregen/USB_Host_Shield_2.0
    20,556
    The host shield does work on Teensy 2.0... so if you don't need 3.0's features, using a 2.0 board might be a fairly easy path.
    I also have a host shield board that was made for Teensy 2.0, but never fully released. I have several boards here. They're untested (one of the things I never got around to doing was building a test fixture) and very little documentation is available, but at least a few people have used this unreleased product successfully, so they do work nicely.
    Jul 2013
    2
    Cheers, that's useful. I'm not particularly attached to the Teensy for this purpose (it just happens to be the only mic I have on hand right now). I'll probably give the Arduino a shot. TBH, the Teensy 3 is overkill for this job anyway. The only extra thing I'll need is a shift register, or I'll run out of pins.
Tags for this Thread
