I made a system with the Teensy 3 where it recieves midi data to control regular rgb led strips using pwm.
The teensy is plugged to rgb amplfiers using an uln2003 because they only work at 12v.
The computer where the teensy is plugged sends midi to the teensy and I also use the audio line out of the computer at the same time to send sound through an amp and speakers. Whenever I use the audio out of the computer with the teensy plugged in I get a high pitched noise through the speakers. I'm using the AGND pin on the teensy and I read in another thread that it's not a good idea to mix this with digital io. Could this be the reason I am hearing a high pitched noise ?
thanks !
thanks !
