Hi
I've got a teensy 3 and a wiznet board, the wiz812 is mounted on an adapter board, the boards mounted on a vero board and connected to the teensy via the 4 pins 10-13.
I've double checked the wiring, and continuity tested it too, so I know the pins all go where they should, but when I run the Webserver app and open the serial monitor I get server is at 0.0.0.0 which seems to say that it has no IP...
I don't have a reset connection, unless its on the adapter, which pin should that go to if it is, and I need to have it?
How can I troubleshoot this? Is there any way to check from the teensy if the wiz board is ok?
Sorry for newby questions!
Cat
by the way the wiznet board lights up and has a flashing activity light
Cat
