Results 1 to 9 of 9
Thread: Float to Sting help
    May 2013
    12
    Float to Sting help
    I have switched from a Teensy2 to a Teensy3 and now much of my code won't work. I've worked around most of the issues (using "while(!Serial){}", for example, after baud rate is established) but I am stuck on converting floats to strings for simple string concatenation. I was using dtostrf, but this doesn't work on the 3.0. I see that some suggest using sprintf, but I've not been able to make that work.
    I would appreciate seeing a *simple* FULL code example to take the number 12.345 and have the message "number = 12.345" appear on the serial monitor.
    Any assistance would be greatly appreciated. Thanks in advance!
    May 2013
    12
    "Float to stRing" help, that is.
    1,925
    float a = 12.345;
    void setup(void)
      while(!Serial);
      Serial.print("number = ");
      Serial.println(a,3);
      char s[20];
      sprintf(s,"number = %6.3f",a);
      Serial.println(s);
    void loop(void)
    Pete
    May 2013
    12
    el_supremo, your name says it all. Thanks for your help, Pete. I'm not sure what I was doing wrong....
    May 2013
    12
    So after a bit more experimentation, I find that sprintf works fine on my Teensy3, but not on my Teensy2 or on my Arduino Uno. Is this to be expected? I'm not sure I understand what's going on under the hood.
    I need code that works with all these boards; am I relegated to working only with print and println functions then?
    1,925
    dtostrf worked for me on Teensy3
    Pete
    28,459
    A recent version added dtostrf (using sprintf). If that function is missing on Teensy3, please upgrade to Teensyduino 1.15.
    May 2013
    12
    Thanks Paul and Pete. dtostrf now works on the Teensy3. I wish sprintf worked on the Teensy2.
    28,459
    Quote Originally Posted by ChrisOdom View Post
    Perhaps try adding this to hardware/teensy/boards.txt
    teensy2.build.linkoption1=-Wl,-u,vfprintf
    teensy2.build.linkoption2=-lprintf_flt
Tags for this Thread
