Page 8 of 8 FirstFirst ... 6 7 8
Results 176 to 183 of 183
Thread: Audio For Teensy3 - What Features Would You Want?
  1. #176
    Oslo, Norway
    32
    Quote Originally Posted by Nantonos View Post
    There is already a USB connector, and a very capable USB MIDI implementation - just select it from the menu. (this does require a USB host, such as a computer, unlike the point-to-point DIN MIDI. On the other hand, throughput is much higher so you don't get congestion botlenecks).
    Yes, but why always involve an computer?
  2. #177
    20,169
    If you really want serial MIDI, you certainly can use the MIDI 3.2 library and a small amount of hardware to get it.
    http://www.pjrc.com/teensy/td_libs_MIDI.html
  3. #178
    Oslo, Norway
    32
    That looks fine, have all parts, except for the pc900, but I have the 6n138 so that should be just as well..
  4. #179
    Boston, MA, USA
    1,106
    Quote Originally Posted by neslekkim View Post
    Yes, that optoisolator should be fine. What passes for a MIDI electrical spec says "Opto-isolator shown is Sharp PC-900. HP 6N138 or other can be used with changes. "
    In practice I have not seen anyone make any changes.
  5. #180
    6
    need the schematic
    Here's what the audio shield will probably look like....
    Attachment 906 Attachment 905
    http://oshpark.com/shared_projects/2k03eMcK
    Hello
    Thank you for a great forum and great help
    I managed to get the Greber files for the Audio shield for Teensy
    Is there a way that you can direct me to the schematic?
    Please advise
  6. #181
    Dec 2013
    131
    Check the sgtl5000 data sheet for the schematic. I'm using that at the moment. Haven't received my first board to test yet though.
  7. #182
    6
    Hello mattomatto
    Thank you for your quick replay
    I am looking at the data sheet
    I am tring to do reverse engineering for the connection of the SD card
    Thank you again
  8. #183
    20,169
    Quote Originally Posted by tzif View Post
