01-25-2014, 02:05 PM
#176
Originally Posted by
Nantonos
There is already a USB connector, and a very capable USB MIDI implementation - just select it from the menu. (this does require a USB host, such as a computer, unlike the point-to-point DIN MIDI. On the other hand, throughput is much higher so you don't get congestion botlenecks).
Yes, but why always involve an computer?
01-25-2014, 05:53 PM
#177
If you really want serial MIDI, you certainly can use the MIDI 3.2 library and a small amount of hardware to get it.
http://www.pjrc.com/teensy/td_libs_MIDI.html
01-25-2014, 08:00 PM
#178
That looks fine, have all parts, except for the pc900, but I have the 6n138 so that should be just as well..
01-26-2014, 03:44 AM
#179
neslekkim
Yes, that optoisolator should be fine. What passes for a MIDI electrical spec says "Opto-isolator shown is Sharp PC-900. HP 6N138 or other can be used with changes. "
In practice I have not seen anyone make any changes.
04-26-2014, 05:33 PM
#180
need the schematic
PaulStoffregen
Hello
Thank you for a great forum and great help
I managed to get the Greber files for the Audio shield for Teensy
Is there a way that you can direct me to the schematic?
Please advise
04-26-2014, 06:07 PM
#181
Check the sgtl5000 data sheet for the schematic. I'm using that at the moment. Haven't received my first board to test yet though.
04-26-2014, 06:10 PM
#182
Hello mattomatto
Thank you for your quick replay
I am looking at the data sheet
I am tring to do reverse engineering for the connection of the SD card
Thank you again
04-26-2014, 10:54 PM
#183
tzif
- You may not post replies
- You may not edit your posts
Forum Rules
