Results 1 to 5 of 5
Thread: Problems_Serial1
    Jun 2013
    4
    Problems_Serial1
    I was testing the serial1 teensy 3.0 with the following code:
    {  Serial.begin(9600);
       Serial1.begin(9600);
    void loop(){
    Serial.println("arduino");
    Serial1.println("arduino");
    I used the trendnet TU-S9 to read the serial1 and get this:
    i dont understand why write that. I'm printing "arduino"
    Thanks for any help
    19,922
    Teensy 3.0 has 3.3V TTL level signals.
    The TU-S9 has +/- 12V RS232 level signals.
    Are you using a MAX232 or similar TTL to RS-323 chip to convert Teensy's signals to the type needed for that RS232 cable? This serial monitor output looks like the small signal from Teensy3 is being received by the TU-S9, but the TTL level output uses the opposite polarity. Even just a logic-level inverter might do the trick, if you don't have a proper RS-232 driver chip.
    Jun 2013
    4
    Thanks for the fast reply
    I will use your suggestions to solve the problem
    Ty
    Apr 2019
    1
    I am also this type of problem, shall i provide my string here
    8,337
    Quote Originally Posted by Brian14 View Post
    Text and details can be posted here if not SPAM or bogus links
