MichaelMeissner
Senior Member+
I've recently picked 2 Adafruit's neopixel rings (16 leds using WS2812), and I have a few more neopixels on order, and I had a question about powering the leds.
According to Adafruit, the draw is 5 volts and 1 amp for 16 LEDs all at full power, with the leds supporting 4-7v. With my two rings, I used the Teensy's VIN pin to power the LEDs, on the assumption that VIN was before the voltage regulator, and 1-2 amps could go to the leds, and the Teensy would take whatever it needed. However, if VIN has limitations on the amperage, I would need to rework things.
At the moment, I'm not running the teensy where I have all leds turned to white, but I may do this in the future. When I'm not programming it, I've been thinking of running it from a 4 Nimh AA battery pack (4.8v and/or regulated up to 5v) and/or a 2amp USB cell phone battery charger. At this power level, would it be safe to use the VIN pin? Or do I need to have two power units, one for the teensy and one for the LEDs (or one unit, and split the power before it gets to the teensy)? I realize for larger amounts of lights, you need to do multiple power supplies, but I was hoping to only have one power supply in this configuration. If things will work, but the lights are dimmer, I can live with that.
Thanks in advance.
Thanks in advance.
