spanner888
Posting this here as initial investigations seem to show this might be Teensy library issue.
Using the example code for SerialUI works OK until compiled using any Teensy board. The error is different for Teensy3 and earlier versions.
Teensy3 error:
/home/spanner888/Documents/sKETCHES/libraries/SerialUI/SerialUI.cpp: In member function 'size_t SUI::SerialUI:rint_P(const char*)':
/home/spanner888/Documents/sKETCHES/libraries/SerialUI/SerialUI.cpp:301:69: error: 'strncpy_P' was not declared in this scope
/home/spanner888/Documents/sKETCHES/libraries/SerialUI/SerialUI.cpp: In member function 'size_t SUI::SerialUI:rintln_P(const char*)':
/home/spanner888/Documents/sKETCHES/libraries/SerialUI/SerialUI.cpp:310:69: error: 'strncpy_P' was not declared in this scope
other Teensy's error:
SuperBlinker.cpp.o: In function `setup':
/home/spanner888/Documents/sKETCHES/libraries/SerialUI/includes/SUIPlat_ArduinoSerial.h:61: undefined reference to `Print::write(unsigned char)'
http://flyingcarsandstuff.com/projects/SerialUI/
Also sending email to SerialUI developer with link to this post.
Teensy3 error:
