Page 1 of 2 1 2 LastLast
Results 1 to 25 of 37
Thread: nRF24L01+ working in Teensy++ 2.0 and Teensy 3.0
    Post nRF24L01+ working in Teensy++ 2.0 and Teensy 3.0
    I got this module working and I wanted to share my experience so no one else has to fight with it.
    I'm currently using this fork that has some extra optimizations and fixes in general:
    https://github.com/TMRh20/RF24
    https://github.com/TMRh20/RF24Network
    This libraries work fine with Teensy 3.0, Arduino Mega and a RPi. It's also more reliable than the original versions
    Getting started
    NOTE: the following zip contains the original libraries, but TRMRh20 new libraries are better. Check them out too. They use the same API, and it's a direct replacement.
    1. Download RF24_teensy2_and_3.zip and unzip it in "arduino_installation_dir/libraries"
    2. Download these example projects:pingpong test.zip
    3. Modify the CE and CSN pins in the code to match your pinout.
    4. If you are using Teensy 2 or Arduino Mega, uncomment the lines that set SS as output.
    5. Upload "Pingtest" to one device
    6. Upload "Pongtest" to the other
    7. Open the serial monitor in the "Pingtest" to make sure the other device is replying to your packets
    Pinout
    Teensy3 -> nrf24l01
    Gnd 1. GND
    VCC 2. VCC
    Pin 9 3. CE
    Pin 10 4. CSN
    Pin 13 5. SCK
    Pin 11 6. MOSI
    Pin 12 7. MISO
    no connected 8. IRQ
    Teensy++ 2.0 -> nrf24l01
    Gnd 1. GND
    VCC 2. VCC (*)
    Pin 11 3. CE
    Pin 12 4. CSN
    Pin 23 7. MISO
    Pin 22 6. MOSI
    Pin 21 5. SCK
    Pin 20 X. SS
    no connected 8. IRQ
    Arduino Mega -> nrf24l01
    Gnd -> 1. GND
    VCC -> 2. VCC (**)
    48 -> 3. CE
    49 -> 4. CSN
    50 -> 7. MISO
    51 -> 6. MOSI
    52 -> 5. SCK
    53 -> X. SS
    no connected 8. IRQ
    Teensy 3.0:
    Newer versions of Teensyduino don't need any changes in the code to work. (tested on Teensyduino 1.21 test#2)
    DEPRECATED:
    You will get lots of errors about "printf" not working and IF_SERIAL_DEBUG not defined. Edit RF24.cpp and comment all lines that mention printf and IF_SERIAL_DEBUG (Thanks Matheus Bratfisch for the tip!). I attached a zip file with working code if you don't want to do it manually. RF24_teensy2_and_3.zip
    Teensy++ 2.0 advice:
    Important: set pin20 (SS) as OUTPUT
    Power supply
    These small modules fail if your power supply is not good enough. I have tested the following schematics on a Raspberry Pi, and two Arduino Mega (which is known to cause issues with the power supply in these modules).
    Teensy++ 2.0 only:
    Don't fight with voltage level conversion. Make your teensy run at 3.3V using this: http://www.pjrc.com/teensy/3volt.html
    Once you do that, the 5V pin will become 3.3V, and you don't need to do anything else. Just power the nRF24L01+ from there (printed on pcb and external antennas should work out of the box).
    Teensy 3.0/3.1, Raspberry pi, Arduino Mega, etc:
    For the small, printed antenna, modules:
    Teensy 3.0/3.1: just get your 3.3v from the teensy directly. The internal regulator is enough: https://forum.pjrc.com/threads/24343...aximal-Current
    Arduinos and RaspberryPi: Try to take 5V from Rpi or Arduino and then use an L78L33 regulator to get 3.3V. The standard 78L33 design with one .33uF and one .1uF cap works fine
    For the bigger modules with external detachable antennas:
    Get 5V from Teensy, RPi or Arduino, then use a bigger regulator! This module consumes up to 115 mA, and the 78L33 and Teensy internal regulator are rated at 100mA max, so none of these will work.
    What I did: I live in Argentina and I couldn't find any decent 3.3v regulator in my city so I ended up using the LM317. It's a variable voltage regulator and you can change the output with two resistances. I verified the nrf24L01+ datasheet and when the input signals come from a 5V source (like the Arduino Mega, or the RPi), then you need to supply from 2.7 to 3.3v max.
    I used R1=220 and R2=330 to get 3.125 volts from the regulator, and the module worked great. The LM317 can supply up to 1.5Amps and you only need 115mA (so it will run very very cool)
    Raspberry users:
    To make the examples work (ping between teensy<->raspberry) you have to make a few small changes to the librf24-bcrm examples:
    1) set CE and CSN correctly (check wich raspberry you have, verify the GPIO values)
    2) Make sure you set the payload size during setup. It's commented out in the RPi examples, so you will have to change that.
    3) change "RF24_PA_LOW" to "RF24_PA_MAX" to make sure it's not a signal strength related issue.
    4) Enable SPI from the Advanced menu, in raspi-config
    PIC users:
    For the love of whatever you love the most... if you get this module working with a 5V pic (specifically 18f4550), please email me! I've used level shifters for the MISO signal with no luck. I can't manage to get SPI working. (I also tried pinguino)
    32 bit users (ie: teensy 3.1):
    if your code works on arduinos, but it doesn't work on Teensy, you may find this post useful:
    http://forum.pjrc.com/threads/24940-...nrf24l01-issue
    Open source networks
    tmrh20 (recommended libs): TCP/IP, RF24Network, RF24 and RF24Mesh libraries:
    http://tmrh20.github.io/
    Original library:
    https://github.com/maniacbug/RF24
    Raspberry pi port for the original lib
    https://github.com/gnulnulf/RF24
    Original RF24Network
    http://maniacbug.github.io/RF24Network/index.html
    RF24SH
    http://www.matbra.com/en/code/rf24sh...et-das-coisas/
    RadioHead
    http://www.airspayce.com/mikem/arduino/RadioHead/
    I hope you guys find this post useful. Good Luck!
    Last edited by dc740; 03-09-2015 at 03:36 AM. Reason: Updated to recommend tmrh20 libraries
    Senior Member+
    Jul 2013
    292
    I'm having problems compiling the Geting Started example in you library for the Teensy 3.0. I've used the .zip files attached in you post. The error message is:
    enabled in File > Preferences.
    Arduino: 1.0.5 (Windows 7), Board: "Teensy 3.0"
    c:/program files (x86)/arduino/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-none-eabi/bin/ld.exe: section .progmem.data loaded at [0000ce9c,0000cead] overlaps section .data loaded at [0000ce9c,0000d667]
    c:/program files (x86)/arduino/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-none-eabi/lib/thumb2\libc.a(lib_a-fstatr.o): In function `_fstat_r':
    fstatr.c.text+0x14): undefined reference to `_fstat'
    c:/program files (x86)/arduino/hardware/tools/arm-none-eabi/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-none-eabi/lib/thumb2\libc.a(lib_a-isattyr.o): In function `_isatty_r':
    isattyr.c.text+0x12): undefined reference to `_isatty'
    Quote Originally Posted by Pedvide View Post
    UPDATE:
    I found your problem. That one is not my library. ManiacBug is the owner. He released it a long time ago.
    The Getting started example in his library uses lots of printf. Arduino for Teensy 3.0 has a bug and you can't use it (you can if you use Teensy 2.0).
    Replace all references to printf by "Serial.println" OR use the "ping/pong" test project I uploaded to the original post. These are the errors I was referencing to when I wrote about teensy 3.0 problems
    Jun 2013
    So. Calif
    2,828
    It depends... It says that it's free for personal projects, but what is the license for commercial usage? The license defines if the code is usable. So far it's easier to use Serial.println
    Jun 2013
    So. Calif
    2,828
    Quote Originally Posted by dc740 View Post
    printf.... I'm just so accustomed to being able to simply nicely formatted output with printf, or sprintf, and all in one statement. Lots of public domain printf. I have one for the T3 that's all public domain C code and does all formatting except floats, and is small and reentrant.
    Senior Member+
    Jul 2013
    292
    The ping/pong test works!! I have two Teensys 3.0 talking to one another now.
    Thanks a lot for the library and the help.
    I updated the attached library. ManiacBug added one method to RF24.h, and you can't use RF24Network without it.
    I updated the post with some extra information on the Octal addressing used by RF24Network for a multinode setup with parent and child nodes.
    Updated original post with a new fork that fixes a few problems with the maniacbug original implementation.
    Nov 2014
    9
    I'm pretty stuck and this thread seems to be the only mention of the Teensy++ 2.0. I'm unable to have anything broadcast: radio.write returns a failed result.
    Teensy++ 2.0 is running at 5V with an LE33 3V3 regulator for the NRF24L01+. Oscilloscope shows a stable 3.3V (100uF capacitor didn't change radio.write results)
    I'm using maniacbug's library, running GettingStarted.
    printDetails shows
    RF24/examples/GettingStarted/
    ROLE: Pong back
    *** PRESS 'T' to begin transmitting to the other node
    STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
    RX_ADDR_P0-1	= 0xe7e7e7e7e7 0xc2c2c2c2c2
    RX_ADDR_P2-5	= 0xc3 0xc4 0xc5 0xc6
    TX_ADDR		 = 0xe7e7e7e7e7
    RX_PW_P0-6	= 0x00 0x00 0x00 0x00 0x00 0x00
    EN_AA		 = 0x3f
    EN_RXADDR	= 0x03
    RF_CH		 = 0x02
    RF_SETUP	= 0x0f
    CONFIG		 = 0x08
    DYNPD/FEATURE	= 0x00 0x00
    Data Rate	 = 2MBPS
    Model		 = nRF24L01+
    CRC Length	 = 8 bits
    PA Power	 = PA_HIGH
    Sending "T" to begin transmission results with
    *** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK
    Now sending 8307...failed.
    Failed, response timed out.
    Now sending 10009...failed.
    Now sending 11710...failed.
    Now sending 13412...failed.
    Now sending 15114...failed.
    Now sending 16816...failed.
    Now sending 18518...failed.
    Now sending 20219...failed.
    Now sending 21920...failed.
    Now sending 23621...failed.
    Now sending 25322...failed.
    Would be grateful if anyone could shed light on where I'm going wrong.
    Cheers
    Can you post a pic of your teensy? To verify that you connected the right pins. Also, did you set the SS pin as output?
    I successfully used the teensy++2.0 in several ocasions. The only difference I see is that I used the oficial 3.3v regulator (MCP1825) instead of the L33. (I used the L33 in the arduino Mega without problems though)
    I don't know if 3.3V level signals trigger correctly in the teensy++ 2.0. If I were you, I would try with the oficial regulator. That way you know for sure the teensy will accept the 3.3V signal from the nrf24l01 module.
    Nov 2014
    9
    Thanks for the quick reply, though I had already given up and turned in for the night.
    I didn't think setting pin20 (SS) would make a difference and hadn't done so, I tried it this morning with the same results.
    void setup(void)
      // Set SS pin output (pin 20)
      pinMode(20, OUTPUT);
      // Print preamble
      Serial.begin(57600);
    As for the 3.3V, the LE33 is stepping down 5V just for the NRF. The Teensy is still operating at 5V.
Name:	2014-11-29 11.30.14 (Medium).jpg
    Jun 2013
    So. Calif
    2,828
    do you have the as-really-wired slave/chip-select pin # in the class instance (constructor's info), to override the default?
    Quote Originally Posted by Tick View Post
    That's what I'm talking about. For example: The pic 18f4550 does NOT work when connected to the nrf24l01 directly because it can only "interpret" signals around 0.8*5V (depending on the port) So even when the nrf module is correctly powered, the pic won't be able to talk to it because it only understands 4V. This is probably your current problem. I insist, try to run the teensy at 3.3v too.
    Here is a little more detail of what's going on (they talk about a PIC, but it could also be your problem)
    However, every PIC datasheet I've examined states that the minimum high input voltage (Vih) is 0.8 Vdd for inputs with Schmitt-trigger buffers. (Inputs such as SPI In and INT all utilize Schmitt-trigger buffers.) Since Vdd for the PIC is nominally 5 volts, that means that the minimum Vih is 4 volts, which is greater than the maximum output of the nRF.
    https://forum.sparkfun.com/viewtopic.php?t=4904
    You have to read the datasheet about the at90usb1286 to find the minimum trigger voltage. Probably other members know this (I don't).
    http://www.atmel.com/devices/at90usb1286.aspx
    Danville, California
    921
    Just a note for those contemplating using this wonderful little nRF24L01+ 2.4 GHz radio, I am offering a small (17.91 mm x 19.66 m) add-on board at Tindie that mounts directly onto the Teensy 3.1 for a compact remote communication solution.
    2,696
    Quote Originally Posted by onehorse View Post
    For some reason, The pictures don't show
    Nov 2014
    9
    @stevech
    Do you mean having the CE and CSN pins same as the code? If so, I have pin 9 as CE and pin 10 as CSN, as is specified in the code by default (figured it would be better than using different pins and having to make sure all references in the code was changed)
    @dc740
    Going by the specification sheets on both the AT90USB1286 and NRF24L01+, the working voltages are within range (I didn't use expected 5V/3.3V either, I measured and monitored supply voltages and used these in calculating the range of working voltages), but as it is the only difference between your setup and mine, I am thinking that it is the issue. However, I am loathe to doing this as I'm wanting to drive 5V relays and I'd have to source the regulators from outside of Oceania (scratch this, I don't think I was sane last time I tried searching for it)
    Outside of running the teensy at 3.3V, are there any other differences? I'm running the teensy at 16MHz (just in case you have it different at 3.3V) and the NRF is running at 2MBPS as opposed the the 1MBPS I encounter when looking at others' experiences.
    Also, my status reports all 0's, is this normal? The only one which isn't 0 is the hardcoded 7 (B111) for RX_P_NO.
    I will take the plunge and use my LE33's to supply the Teensy with 3.3V order two of these voltage regulators tomorrow morning unless something obvious has been pointed out before then. I have just spent my entire day figuring out how to get eclipse to play nice with AVR and this Teensy (I'm at the point where I'm willing to write my own code from scratch to see exactly where it's going wrong).
    921
    Yes, I have a complaint lodged at Tindie and they are trying to sort it out.
    Here is what it looks like:
ID:	3022Click image for larger version.
    Nov 2014
    9
    Update:
    I have gotten the MCP 3.3v regulators for the Teensy, soldered it on and cut the connection to run the whole lot at 3.3v (with a 47uF cap between vcc and gnd) then checked with multimeter to make sure everything was good. Still no success, the same results.
    At the same time, I've also bought new NRF's just in case the ones sent were faulty. Again, no success. This leads me to believe that the fault lies with the code. I'm afraid this endeavour will take much more time than I had originally expected. Will update again at a later date
    Jun 2013
    So. Calif
    2,828
    Tried these radios with the RadioHead library?
    Nov 2014
    9
    No I haven't, I'll give it a go
    Tick, I'm still surprised you are having so many problems. It works "out of the box" with the 3.3 regulator. I even soldered the teensy++ 2.0 to the module "on the air", I didn't even use a proper PCB, nor a protoboard, just plain wires and it simply worked at first try.
    I'll take a look as soon as I get home. Did you try the attachment in the first thread instead of downloading the source from the maniacbug github? I really don't know what's the problem, but you could try that, so you know you are using the same code as I did. I insist there must be some wiring problem. Can you post a picture were we can clearly see your new wiring (the simplified version, with the teensy working at 3.3v)
    Nov 2014
    9
    Yeah, I'm really hoping it's something stupid and simple that I messed up on.
    Here's a picture of the set up
Name:	2014-12-10 18.00.02 (Large).jpg
    and a diagram of it to make it easier
    I've tried both maniacbug's and the one posted here teensy 2 and 3.
    1) That's the very same configuration I used. No differences except for:
    Pin 11 3. CE
    Pin 12 4. CSN
    (you used 9 and 10)... I honestly don't know about any other difference. And that shouldn't cause any problems, since CE and CSN can be changed... only MISO, MOSI and SCK should be respected:
    http://www.pjrc.com/teensy/pinout.html
    2) Can you remove all those leds and try just the teensy and the nrf module? Nothing else connected to it. Are you sure the other side is connected exactly like the teensy?
    3) Use the demo code only, don't add anything else (software or hardware) until you get it to work.
    4)
    Also, try at 1Mbps
    5) you showed one side, what about the other one? Is it another teensy?
    6) What is the address of each node?
