Results 1 to 2 of 2
Thread: How do I use teensy 3.0 without the USB port?
    Oct 2013
    3
    Question How do I use teensy 3.0 without the USB port?
    Hey,
    I just destroyed the sub port of my Teensy.....
    I am not able to solder the usb hub back to the board because the solder points are destroyed.
    Is there any other way to solder for example a USB-cable to the teensy?
    I saw that some soldering points on the bottom of the teensy.
    And I watched at the schematic and saw that there are some points directly connected to the USB.
    When I look at the schmeatic I would choose these points to solder my USB cable to, but where can I find these points on the teensy?
    I hope you will help me.
    lg Darcade
Tags for this Thread
