Results 1 to 9 of 9
Thread: gameduino 2
    gameduino 2
    http://www.kickstarter.com/projects/...e-its-personal
    WOW why is that awesome little chip not added to the arduino by default!!! seriously the FT800 chip is a powerfully tiny gpu!!
    found this EVE Click which is a 3.3v compliant FT800 break out board with lcd connector and audio amp... Wonder how hard this would be to use on the teensy 3.0?
    412
    The author finally released the Gameduino 2 manual pdf and Arduino library.
    We tried to use the Teensy 3 and the GD2 library to see if it would compile, with no errors, and it does!!!!
    We do not have the Gameduino 2 hardware yet (Seeedstudio is sending it from China) but hopefully when it arrives we will try to connect it to the Teensy 3.0/3.1.
    What is so great about the Gameduino 2 it has sound, touch, SD and a 4.3 LCD screen with most, if not all, of FTDI's Eve's FT800 graphics already debugged and tested ---> just plug and play. Our application is to use this module as a portable touch display.
    Not sure if anyone's been playing with the hardware yet, but I have a couple of Gameduino 2's and everything works great out of the box with the Teensy 3.Xs (I haven't connected the accelerometer outputs up yet). I'm using the hardware SPI pins, CS's and interrupt as defined for a standard Arduino shield, and haven't tried tweaking/optimizing anything yet. The resistive touchscreen functions better than I anticipated.
    Has anyone used it in a project yet?
    Member geekguy's Avatar
    Feb 2014
    Spring Valley, CA
    78
    Quote Originally Posted by t3andy View Post
    Compiling without errors, unfortunately, doesn't really tell us too much. For instance, some of the Adafruit libraries compile perfectly with TeensyDuino for the Teensy 3.1, but they give incorrect values, compared to a true blue Arduino board. I am going to look into this once I get my W.A.L.T.E.R. 2.0 robot running with a Teensy 3.1 full time, which will hopefully be soon.
    I will be watching for your experiences! I have the Gameduino 2 in my sights for possible use with a Teensy 3.1 in my wireless robot controller design.
    Yes, indeed! It has pretty much everything one might need for most touch display applications. I plan to get one, regardless of whether I use it for my robot controller or not.
    8-Dale
    Mar 2014
    3
    Hello!! I want to display date and time on gameduino 2 but an error exists. I included the library time.h and it appears an error on this part:
    int m;
    m=minute();
    GD.cmd_number=(10,10,20, OPT_CENTER, m);
    .The error is :"error: invalid use of member (did you forget the '&' ?)"
    Could you please tell me what is going wrong?
    4,090
    Quote Originally Posted by alex123 View Post
    int m;
    m=minute();
    Not being familiar with the GD code, I suspect you want either:
    // Note, I messed up on the syntax initially.  There should NOT be an
    // equal sign between cmd_number and '('
    GD cmd_number (10, 10, 20, OPT_CENTER, m);
    if you want to declare cmd_number as a variable of type GD, with 5 arguments as part of the initialization, or:
    GD.cmd_number (10, 10, 20, OPT_CENTER, m);
    if you want to call member function cmd_number in the global GD data structure. I suspect the later. If GD is a pointer, then you might want instead:
    GC->cmd_number (10, 10, 20, OPT_CENTER, m);
    This is probably unlikely.
    Mar 2014
    3
    I want to make gameduino2 display every 5 seconds a different image. what position should i write in cmd_loadimage(x,0) in order to make them appear?
    Jul 2015
    19
    I've tried to use the GD2 in my project,
    I'm using Teensy 3.1 - could you explain me more specifically how to connect the pins of the GD2 to the Teensy?
    Thank you.
