Results 1 to 2 of 2
Thread: Fix for using math library without Arduino (compiling from Makefile)
    Oct 2013
    1
    I had an issue building code with the makefile after including <math.h>. I think it's just a mistake in the following lines, I've added $(LIBS) to the end of the second line.
    $(TARGET).elf: $(OBJS)
    	$(CC) $(LDFLAGS) -o $@ $(OBJS) $(LIBS)
    LIBS is already defined as "-lm", which is the extra option I needed to fix the compile error.
    24,122
    Opps, $(LIBS) is missing. I've added it here, so it'll be in Teensyduino 1.17.
