Results 1 to 3 of 3
Thread: Mapping Teensy with usbMidi in Traktor/Ableton
    Oct 2013
    1
    Hi all, I'm new here.
    I came over from Arduino because of it's better options for sending MIDI signals.
    I just set up a simple pushbutton on my teensy ++ to send a midi note when HIGH. This actually
    works perfectly well and in MIDI-OX I receive the notes and all, but when it
    comes to mapping my button in software (I have Traktor Pro and Ableton Live),
    I get no response whatsoever. In both programs, it seems as if the MIDI isn't
    coming through (It doesn't "learn"). Yet, at the same time, I can see the note coming in in MIDI-OX.
    I've set the teensy as my input port, and "None" as my output port.
    I've switched the button for a potentiometer - same result.
    Unfortunately, I can't change computers.
    Below is my code, could anything be interfering?
    Am I using the right MIDI command?
    const int b = 7;
    const int led = 6;
      pinMode(b,INPUT);
      pinMode(led,OUTPUT);
      if (digitalRead(b) == HIGH)
        digitalWrite(led,HIGH);
        usbMIDI.sendNoteOn(26,100,1); //note, velocity, channel
        delay(150); //delay so that only one signal goes through
        digitalWrite(led,LOW);
    Boston, MA, USA
    1,114
    Having switched the note on, you are not switching it off again!
    else {
        usbMIDI.sendNoteOn(26,0,1); //velocity zero means off
    25,212
    Try the example, from File > Examples > Teensy > USB_MIDI > Buttons.
    I highly recommend you use the Bounce library to read pushbuttons (as shown in that example), rather than digitalRead().
Tags for this Thread
