Results 1 to 8 of 8
Thread: Menu system on Teensy3 and OLED (SSD1306)
    Oct 2013
    10
    Can anyone offer any advice on any libraries out there I can use to implement a multi level menu system for an OLED screen, I would like to use 5 buttons, left, right, up, down and enter for navigation. I've tried googling but have not found anything out there.
    If there are not any libraries if there are any projects with source code I can reverse engineer I'd love to find out.
    This is the main part of my project and I will build upon the menu once it works smoothly, I will be happy to share my progress as it develops.
    So any help would be greatly appreciated so I can get moving on my project, I'm feeling eager to get on with it.
    The typical use would be
    '=' Top Menu
    '==' Sub Menu
    '===' Menu item
    Menu structure
    = Main menu
    == Set up
    === Set temp
    === Set time
    == Display
    === Show temp
    === Show time
    Oct 2013
    10
    So I have managed to solve this myself, anyone else who is looking for basic code for a menu for a OLED here it is
      OLED Menu System
      Created by Dean, 10th October 2013.
      Menu Library from http://jonblack.org/
      OLED Library from Adafruit
    #include <MenuSystem.h>
    #include <Adafruit_GFX.h>
    #include <Adafruit_SSD1306h.h>
    //DEFINES
    #define OLED_DC 8
    #define OLED_CS 10
    #define OLED_CLK 13
    #define OLED_MOSI 11
    #define OLED_RESET 7
    Adafruit_SSD1306h display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
    // Menu variables
    MenuSystem ms;
    Menu mm("");
    Menu mu1("Display");
    MenuItem mu1_mi1("Display1");
    MenuItem mu1_mi2("Display2");
    MenuItem mu1_mi3("Display3");
    Menu mu2("Settings");
    MenuItem mu2_mi1("Settings1");
    MenuItem mu2_mi2("Settings2");
    MenuItem mu2_mi3("Settings3");
    // Example variables
    const int UpBtn = 5;       // the number of the pushbutton pin
    const int DownBtn = 4;     // the number of the pushbutton pin
    const int SelectBtn = 3;   // the number of the pushbutton pin
    const int BackBtn = 2;     // the number of the pushbutton pin
    int UpButtonState = 0;     // variable for reading the pushbutton status
    int DownButtonState = 0;   // variable for reading the pushbutton status
    int SelectButtonState = 0; // variable for reading the pushbutton status
    int BackButtonState = 0;   // variable for reading the pushbutton status
    bool bRanCallback = false;
    bool bForward = true;
    int line = 10;             // variable for setting display line
    // Menu callback function
    // In this example all menu items use the same callback.
    void on_display1_selected(MenuItem* p_menu_item)
      //Serial.println("DISPLAY1 Selected");
      display.setCursor(0,55);
      display.print("DISPLAY1 Selected");
      bRanCallback = true;
      bForward = true;
    void on_display2_selected(MenuItem* p_menu_item)
      //Serial.println("DISPLAY2 Selected");
      display.print("DISPLAY2 Selected");
      //bRanCallback = false;
      bForward = true;
    void on_display3_selected(MenuItem* p_menu_item)
      //Serial.println("DISPLAY3 Selected");
      display.print("DISPLAY3 Selected");
      bForward = true;
    void on_settings1_selected(MenuItem* p_menu_item)
      //Serial.println("SETTINGS1 Selected");
      display.print("SETTINGS1 Selected");
      bForward = true;
    void on_settings2_selected(MenuItem* p_menu_item)
      //Serial.println("SETTINGS2 Selected");
      display.print("SETTINGS2 Selected");
      bForward = true;
    void on_settings3_selected(MenuItem* p_menu_item)
      //Serial.println("SETTINGS3 Selected");
      display.print("SETTINGS3 Selected");
      bForward = true;
    // Standard arduino functions
    // by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
      display.begin(SSD1306h_SWITCHCAPVCC);
        // initialize the pushbutton pin as an input:
      pinMode(UpBtn, INPUT);
      pinMode(DownBtn, INPUT);
      pinMode(SelectBtn, INPUT);
      pinMode(BackBtn, INPUT);
      display.display(); 		// show splashscreen
      delay(2000);
      display.clearDisplay();   // clears the screen and buffer
    // Menu setup
      mm.add_menu(&mu1);
      mu1.add_item(&mu1_mi1, &on_display1_selected);
      mu1.add_item(&mu1_mi2, &on_display2_selected);
      mu1.add_item(&mu1_mi3, &on_display3_selected);
      mm.add_menu(&mu2);
      mu2.add_item(&mu2_mi1, &on_settings1_selected);
      mu2.add_item(&mu2_mi2, &on_settings2_selected);
      mu2.add_item(&mu2_mi3, &on_settings3_selected);
      ms.set_root_menu(&mm);
    //OLED set up
      display.display();
      display.setTextSize(1);
      display.setTextColor(WHITE);
      line=10; //line variable reset
      //Serial.println("");
    // Display Title
      display.setCursor(0,0);
      display.println("MENU");
    // Display the menu
      Menu const* cp_menu = ms.get_current_menu();
      MenuComponent const* cp_menu_sel = cp_menu->get_selected();
      for (int i = 0; i < cp_menu->get_num_menu_components(); ++i)
        MenuComponent const* cp_m_comp = cp_menu->get_menu_component(i);
        //Serial.print(cp_m_comp->get_name());
        display.setCursor(30,line);
        display.print(cp_m_comp->get_name());
        if (cp_menu_sel == cp_m_comp){
          //Serial.print("<<< ");
          display.setCursor(0,line);
          display.print(">>> ");
        line=line+10;
    // read the state of the pushbutton value:
      UpButtonState = digitalRead(UpBtn);
      if (UpButtonState == HIGH) {
        ms.prev();
      DownButtonState = digitalRead(DownBtn);
      if (DownButtonState == HIGH) {
        ms.next();
      SelectButtonState = digitalRead(SelectBtn);
      if (SelectButtonState == HIGH) {
        ms.select();
      BackButtonState = digitalRead(BackBtn);
      if (BackButtonState == HIGH) {
        ms.back();
    // Wait for two seconds so the output is viewable
    Library is available from http://jonblack.org/2012/05/14/ardui...a-menu-system/
    Oct 2013
    10
    Next on the list,
    How to get the buttons to work as interrupts?
    and add a better way of displaying output notice i.e display.print("DISPLAY2 Selected");
    Hello
    If it's possible, please, post <MenuSystem.h> for this code. The download link, it's not working.
    Thank you in advance.
    Aug 2014
    125
    I think the library is the following: https://github.com/jonblack/arduino-menusystem
    Thank you !!!
    Help!
    Hello of Dean! Can you help me? Немогу to add a new menu item. Can you describe more detailed description? How to add the menu item? Already week I sit above a code. Below my code.
    PHP Code:
    #include <Wire.h>
    #include <SPI.h>
    #include <Adafruit_SSD1306.h>
    //Пины
    #define OLED_MOSI   9
    #define OLED_CLK   10
    #define OLED_DC    11
    #define OLED_CS    12
    #define OLED_RESET 13
    Adafruit_SSD1306 display(OLED_MOSIOLED_CLKOLED_DCOLED_RESETOLED_CS);
    // Menu variables
    MenuSystem ms;
    Menu mm("");
    Menu mu3("Ethernet");
    MenuItem mu3_mi1("Set1");
    MenuItem mu3_mi2("Set2");
    MenuItem mu3_mi3("Set3");
    // Объявления переменных и констант
    const int buttonPin 0;   // аналоговый вход для кнопок
    int buttonValue 0;   // переменная для значения АЦП кнопки
    int UpButtonState 0;     // переменная для кнопки вверх
    int DownButtonState 0;   // переменная для кнопки вниз
    int SelectButtonState 0// переменная для кнопки выбора
    int BackButtonState 0;   // переменная для кнопки возврата
    bool bRanCallback false;
    bool bForward true;
    int line 30;             // переменная для установки настроек в линию
    // Функция меню обратного вызова
    // В этом примере все пункты меню можно использовать для обратного вызова.
    void on_display1_selected(MenuItemp_menu_item)
    bRanCallback true;
    bForward true;
    void on_display2_selected(MenuItemp_menu_item)
    bForward true;
    void on_display3_selected(MenuItemp_menu_item)
    bRanCallback false;
    bForward true;
    void on_settings1_selected(MenuItemp_menu_item)
    bRanCallback true;
    bForward true;
    void on_settings2_selected(MenuItemp_menu_item)
    bRanCallback false;
    bForward true;
    void on_settings3_selected(MenuItemp_menu_item)
    bForward true;
    void on_set1_selected(MenuItemp_menu_item)
    bRanCallback true;
    bForward true;
    void on_set2_selected(MenuItemp_menu_item)
    bRanCallback false;
    bForward true;
    void on_set3_selected(MenuItemp_menu_item)
    bForward true;
    void setup()
    display.begin(SSD1306_SWITCHCAPVCC);
    // Menu setup
    mm.add_menu(&mu1);
    mm.add_menu(&mu2);
    mm.add_menu(&mu3);
    mu3.add_item(&mu3_mi1, &on_set1_selected);
    mu3.add_item(&mu3_mi2, &on_set2_selected);
    mu3.add_item(&mu3_mi3, &on_set3_selected);
    void loop()
    buttonValue analogRead(buttonPin);
    Serial.println(buttonValue);
    //OLED set up
    display.display();
    line=15//line variable reset
    Serial.println("//OLED set up");
    // Display Title
    display.setCursor(10,0);
    display.println("MENU CONFIGURATION");
    display.setCursor(0,5);
    display.print("_____________________");
    display.setCursor(110,15);
    Serial.println("//OLED");
    // Display the menu
    Menu const* cp_menu ms.get_current_menu();
    MenuComponent const* cp_menu_sel cp_menu->get_selected();
      for (
    int i 0cp_menu->get_num_menu_components(); ++i)
    MenuComponent const* cp_m_comp cp_menu->get_menu_component(i);
    Serial.println(cp_m_comp->get_name());
    display.setCursor(10,line);
        if (
    display.write(16);
    line=line+10;
    Serial.println("");
    UpButtonState buttonValue;
      if (
    UpButtonState 830 && UpButtonState 840) {
    ms.prev();
    DownButtonState buttonValue;
      if (
    UpButtonState 860 && UpButtonState 870) {
    ms.next();
    SelectButtonState buttonValue;
      if (
    UpButtonState 480 && UpButtonState 490) {
    ms.select();
    BackButtonState buttonValue;
      if (
    UpButtonState 319 && UpButtonState 325) {
    ms.back();
    delay(1500);
    And it is your working code
    PHP Code:
    #include <Wire.h>
    #include <SPI.h>
    //Пины
    #define OLED_MOSI   9
    #define OLED_CLK   10
    #define OLED_DC    11
    #define OLED_CS    12
    // Menu variables
    MenuSystem ms;
    Menu mm("");
    bool bForward true;
    bRanCallback true;
    bForward true;
    bForward true;
    bRanCallback false;
    bForward true;
    bRanCallback true;
    bForward true;
    bRanCallback false;
    bForward true;
    bForward true;
    void setup()
    // Menu setup
    mm.add_menu(&mu1);
    mm.add_menu(&mu2);
    void loop()
    //OLED set up
    display.display();
    // Display Title
    // Display the menu
      for (
    //Serial.println(cp_m_comp->get_name());
        if (
    display.write(16);
    line=line+10;
      if (
    ms.prev();
      if (
    ms.next();
      if (
    ms.select();
      if (
    ms.back();
    delay(200);
    Is there any explanation about how the menu works ? especially about
    bForward = true;
    I wonder if I can jump to a menu from inside a running program, ie GPS to access the setup ? how would that work ?
Tags for this Thread
