Results 1 to 15 of 15
Thread: Teensy 2 ++ Midi out problem.
    Oct 2013
    9
    When using Teensy 2 ++ as a Usb midi device I have no problems.
    I need to send Midi out to another device through the Midi port , I tried this schematic and code :
    http://www.pjrc.com/teensy/td_libs_MIDI.html
    I used an oscilloscope to see if there was a a signal from the TX pin (pin 3) but found no signal ...
    When I use MIDI.sendNoteOn(note, 100, channel); nothing but usbMIDI.sendNoteOn(note, 100, channel); works fine.
    Thank you
    Brgds
    Kristinn
    Oct 2013
    9
    I have tried using Teensy as Serial and as Midi..
    18,967
    I can give it a try here on a Teensy++ 2.0, but only if you post the code you're testing, and specific which version of the library you're using.
    Oct 2013
    9
    Thanks !
    I am using Midi library 3.2 and just using this code:
    #include <MIDI.h>
    const int channel = 1;
    MIDI.begin();
    int note;
    for (note=10; note <= 127; note++) {
    delay(200);
    MIDI.sendNoteOff(note, 100, channel);
    delay(2000);
    Oct 2013
    9
    And the schematic (only the midi out part) : Click image for larger version.
    Aug 2013
    Gothenburg, Sweden
    292
    Try to include Arduino.h before including MIDI.h.
    From the MIDI.h file:
    // Use Serial1 on all Teensy boards, because Serial is USB virtual serial
    // Arduino.h must be included before MIDI.h to define CORE_TEENSY
    Oct 2013
    9
    Thanks for the help , but no change :
    #include <Arduino.h>
    #include <MIDI.h>
    MIDI.begin();
    int note;
    delay(200);
    delay(2000);
    When I change it to :
    #include <MIDI.h>
    MIDI.begin();
    int note;
    delay(200);
    usbMIDI.sendNoteOff(note, 100, channel);
    delay(2000);
    I get the notes played over USB.
    The project I am doing would be so much better if I can avoid USB.
    I appreciate the help
    Oct 2013
    9
    I needed to change Serial to Serial1 in Midi.h
    Now it works !!
    Thanks for the help
    18,967
    Quote Originally Posted by kiddikiddi View Post
    Was this code present in Midi.h?
    #if defined(CORE_TEENSY)
    #undef USE_SERIAL_PORT
    #define USE_SERIAL_PORT         Serial1
    Oct 2013
    9
    Yes , but it was #define USE_SERIAL_PORT Serial.
    Not Serial1.
    18,967
    Did you get the MIDI library from the page on PJRC, or from the Teensyduino installer, or from the Sourceforge site?
    The copy on Sourceforge doesn't have those extra lines to automatically use Serial1 for Teensy.
    Oct 2013
    9
    From the PJRC site.
    18,967
    The copy on PJRC has this in MIDI.h:
    #define USE_SERIAL_PORT         Serial      // Change the number (to Serial1 for example) if you want
        // to use a different serial port for MIDI I/O.
    Then right after that in MIDI.h, it has this:
    It's supposed to undefine "Serial" and automatically change it to "Serial1".
    I'm trying to understand why this didn't work for you. Maybe it's a bug that needs to be fixed?
    Could you please take another quick look at your copy of MIDI.h? Does it have both of these, or only the first part? If it was simply missing the 2nd part, then that's the cause. But if that 2nd part is present in your copy, then I have more work to do to figure out why it didn't work as intended.
    I really do want to make sure this problem don't affect anyone else, so if you could please just take another quick look at your copy of MIDI.h and check if it has only 1 or both of these parts, that would really help!
    Oct 2013
    9
    In my Midi.h I have :
    So , I donīt understand what caused it ?
    Oct 2016
    10
    Hi, I have the same issue.
    My system (Teensyduino 1.30 supports Arduino versions 1.0.6.11).
    I have downloaded the Midi-Lib from PJRC.
    While the code works below fine for Arduino UNO but it does not work for Teensy 3.2.
    In adddition I have some questions
    1: I have downloaded the MIDI-LIB and added it as Library in Arduino
    The code compiles even when I remove the downloaded Midi-Lib form my computer.
    So, how can I be sure that the downloaded Midi-Lib is used.
    2: I have inserted the line
    but it did not get red color, does it mean, the Lib is not installed ?
    My Code
    #include <MIDI.h>
    Basic I/O MIDI tutorial
    by Franky
    28/07/2009
    MIDI.begin(4); // Launch MIDI with default options
    // input channel is set to 4
    MIDI.sendNoteOn(42,127,1); // Send a Note (pitch 42, velo 127 on channel 1)
    delay(1000); // Wait for a second
    MIDI.sendNoteOff(42,0,1); // Stop the note
    My Midi.h
Tags for this Thread
