Results 1 to 5 of 5
Thread: Basic Teensy USB Keyboard Q
    Oct 2013
    8
    Question Basic Teensy USB Keyboard Q
    Hi guys,
    I'm new to teensy and also electronics (including coding). I've recently purchased a Teensy++ 2.0 and am building a controller which will act as a replacement for keyboard shortcuts (for example, 1 momentary switch will result in Command + T being pushed simultaneously) which will hopefully make using my music production software (Ableton) a bit easier.
    I think I've got most of the idea on coding a Teensy for a USB keyboard, but there is one function which I'm not sure whether it is feasible/possible. What I need in this function, is when holding down a button, to have that button keep the command key (for example) activated until I release the button. So when the button is pushed down, command/option/shift/control is held active until the button is released. This is quite vital as I often need to hold down one of these keys whilst clicking and dragging with my mouse.
    I will be wanting to run this on a mac (if that makes any difference)
    Is this possible with a Teensy? I'm SURE it is, but this is all quite foreign to me so I thought I'd get some clarification/insight from knowledgable people.
    Cheers,
    Stephen
    Boston, MA, USA
    1,112
    Yes, you can do this. Read this page and scroll down to The Micro Manager Way.
    23,488
    The mac's "command key" is MODIFIERKEY_GUI.
    Oct 2013
    8
    Great, thanks a lot. I'm still in the building stages before programming so hopefully once I get to the programming I don't get too lost.
    23,488
    Well, if you do need help, just post here. But please, read these guidelines. Composing your question with enough info saves everyone time, and it really increases your chances of getting a useful answer.
Tags for this Thread
