neep
I have a couple of these RGB LED drivers that go over RF (433.92MHz) :
http://www.aliexpress.com/item/5-24...ntrol-for-LED-RGB-Strip-JS0200/706365687.html
The remote control only works on one driver and is easily lost. So I would like to be able to drive all of these with an Arduino or Teensy but have no idea where to start or if it is even feasible to figure out the protocol and the encoding for the specific remote/controller combination.
I'm also wondering if the controller has more capabilities than the standard remote is allowing one to use, such as individually control each color channel, instead of just cycling through pre-set colors. I found another version of the remote that looks like it may be shipped with the same type of controller, which leads me to believe that more is indeed possible:
http://www.aliexpress.com/item/RF-M...reless-DIY-Dynamic-5V-12V-24V/1180285329.html
Another thing I'd like to do is somehow hook up one of these controllers to a Teensy so that I can use the RF part to create a remote controllable Teensy, with minimal space waste, as these controllers are quite small. My projects (LED dance props like staffs and hula hoops) are extremely tight for space.
Anyone have any experience with this? Talk me into it or out of it please
