question about bench power supply
nlecaude
I'd like to get a bench power supply but I'm confused about the specs.
When they say 30V at 3 amps, does it mean it's capped at 3a at every voltage or lower voltages will allow higher current ? (if the power supply is rated at 90w, I assume I could go at 18a at 5v ?)
sorry for the newbie question....
send us a link... no general answer.
My guess: if it is $100 or so, it;'s probably 3A at any voltage up to x.
a PC/ATX power supply, wired to convenient connections, and a on/off on the digital control pin, is convenient if not variable.
Usually a 30V, 3A lab bench power supply is capped to those specs, so you don't get 10A at 9V.
However, some of them do have 2 or 3 or more configurable ranges. Each range works like the normal way. For example, a 90W supply might have a 30V, 3A range and a 15V, 6A range. When set to the 15V range, you can get up to 6A, but you don't magically get 9A at 10V. The limit is still 6A when in that mode.
PC power supplies are essentially free and can provide tremendous amounts of power, but should only be used with great caution. Many are designed with an assumption of substantial current from the 12V line. Some will lose regulation and output terrible noise or 7+ volts on the 5V line if the 12V lines are unloaded. Beware! Several people have killed their Teensy 3.0 using a PC power supply 5V output with the 12V line unloaded. You may need to mount a 20 or 10 ohm, high power resistor in the fan's air flow, connected to the 12V power. Check the 5V and 3.3V lines for correct voltage and low noise before using them for Teensy!
The main advantage to lab bench power supplies is the adjustable current limit. You simply don't get that from a PC or any other normal power supply. If you set the current limit low, it will often save your parts from destruction if you make a mistake. For example, while working with a Teensy and perhaps a few LEDs, you might set the current to 50 mA max. Even though the power supply could be set to 3000 mA, if you accidentally connect the 3.3V power backwards to your Teensy 3.3V, the maximum 50 mA will flow through the P-N junction that forms the body of the chip. The power supply will automatically reduce its output voltage, so no more than the current limit can flow. Normally Teensy can survive 50 mA of reverse power current. 3 amps would be a "magic smoke" situation. Likewise for connecting transistors and other parts, the adjustable current limit, if you set it only slightly above the current you really need, will spare you from burning parts by flowing the full 10 to 20 amps or more a PC power supply would output.
But a decent lab bench power supply is at least $100, which is a lot of money if you're doing electronics on a student or hobby budget. Still, after a decent temperature regulated soldering iron, a quality power supply with working current limit is one of the best buys to make fiddling with electronics much easier. Everybody makes mistakes, no matter how experienced, and especially when you're just starting, a current limit set relatively low will save you many times from accidentally destroying parts.
Thanks a lot for this very detailed answer !
I was thinking about going the PC power supply route but since I work a lot with LEDs I think it's best if I get a power supply where I can limit the current.
The model I was looking at is this : http://www.bkprecision.com/products...upply-with-usb-charger-output-1-36v-0-3a.html
From what I understand thanks to your explanations is that this model will always output a maximum of 3 amps.
I often test LED strips of different varieties (ws2811 being the most power hungry) and would like to find something that could output 5a but at higher currents (10a seems reasonable)
Or will something that needs more than 3a still work but I won't be able to adjust the power supply higher than 3a if I want constant current ?
My budget is around 200$
Thanks a lot this is really helpful !
I use power supplies from this company: http://www.circuitspecialists.com/csi-power-supplies At this cost level, different manufacturers products are nearly all the same w.r.t. accuracy, ripple, stability etc. They have 30 V/ 5 A for $60. At a higher cost, they have ones with a 2nd auxiliary 5 V/1A supply. Some of their dual supplies can be connected in series or parallel to get e.g. Parallel Mode: 0-30Volts; 0-6Amps, or Series Mode: 0-60Volts; 0-3Amps
