OctoWS2811 POV reading BMP from SD card
The BMP only displays once and the variable changes the speed at which it displays once. To clarify :) Thats what i got so far....
Ok so I got the BMP issues resolved. I used a different work around for it but is working nicely now. Only thing is I cant display more then 85 leds. 86 or more make the stripe freeze. Lights come on most of the leds but just frozen not moving. I want to try some light painting!!! Any help would be great :) Im sure its just a setting I need to change.
Well, could be power or code. How are you powering the LEDs and teensy? Also, are you using a bigger BMP with the longer length if LEDs? There may be a buffer issue. Also did you try the count loop approach instead for the repeating BMP as an alternative ?
USB 5v
BMP is 150x600 pixels and code set to 150leds
I just stacked the images in the BMP instead if messing with the code :)
If set to 150led and I put a BMP of 85pixels or smaller it will display BMP on 85pixels and patterns on all 150 leds.
Yep, sounds more like a coding or buffer issue. What part of the code did you change as I have 147 LEDs working no problem in the original code
Only changed
const int ledsPerStrip = 150;//60;
#define BUF_SIZE 10240//180//10240
#define BUFFPIXEL 150//20//147
and added BMP
I think that buf_size needs to be put back to the three time led size value. For the original sketch it was 441 for three lots of 147 LEDs. So, set it to 450 or 512 and see if this resolves it. I am away at the moment, so can't test the issue.
Still unable to display more than 85 pixels changed buffer size to 450. Did you have a chance to test settings?
TekJunky, been away, hopefully I can get to revisit it this evening, but time is very limited right now.
@TekJunky, in the drawBMP routine try changing povidx line to "uint16_t povidx = 0;" I think that it was a simple overrun of the uint8_t. You can set the BUFF_SIZE to 512. BUFFPIXEL should be set to the same size as your number of pixels (strip length).
here is a picture of 147 led pixel staff I just took displaying two bmp from the sd card:
Has anyone been able to get this to pick a file at random off the SD card? Ive been trying to modify the sketch todo so but it's failed horribly.
The following change is confirmed to work for using longer led strips for light painting or pov:
was -- uint8_t buffidx = sizeof(sdbuffer);
Changed to -- uint16_t buffidx = sizeof(sdbuffer);
Fixed Display issues all 150 leds working properly now
If you are storing the result of sizeof, the correct type to use is size_t. If you need a signed type instead of unsigned that is the same size use the type ssize_t. Those types are guaranteed to be big enough to hold the size of the maximum object in the system.
Hi all
Hope im not bringing up an old post just got a couple of questions about the lightwand by mortonkopf has anyone had any luck with the APA102 led strip ? does the code work on teensy 3.1 ?
Cheers
@lumberg. I have not tried it with APA102. I have some ordered, and hope to get round to sorting out the two. Both the SD card and the APA102 will need to work together, and I have not tried this setup yet. I see from the latest FastLed (3), you can set the clock and data lines like so:
      FastLED.addLeds<APA102, DATA_PIN, CLOCK_PIN>(leds, NUM_LEDS);
so it should be reasonably straight forward from a pin access point of view, but I have not tried the two together yet. The light wand was originally a test as the ws2811 leds were too slow for spinning poi POV.
yes, I saw that softspi and I asked Zackees for some fuller usage examples but none were put in the repository. I did not follow the sd card route further as i was not convinced of the card read rate being high enough. It states 14m of 144leds at 30 updates a sec, this = 60,480 led point per sec, so for my 60led pov baton this lib will provide 1000 lines per sec. I spin at approx 2 rotations a sec (120bpm), so this method would only give me 500 line updates per full rotation, and that is not enough to give the dense detail that I want.
POV with APA102
Hi
I've been working on adapting this for APA102 strips. This code works but only displays 2 of the 3 RGB colors. Anyone have any luck getting this to work with APA102 strips?
Nick
//#include <OctoWS2811.h>// ensure you are on PIN 2 + PINS 15 and 16 bridge
#include <SdFat.h>
#include "FastLED.h"
//OCtoWS2811 library from the good folk at PJRC http://forum.pjrc.com/forum.php
//SDfat library from this brilliant person http://code.google.com/p/sdfatlib/
// most of the code for the buffer workings come from ZTik.nl (many thanks)
//for SD card wiring
//MOSI goes to pin 11
//MISO goes to pin 12
//SCLK goes to pin 13
//SS goes to pin 10
#define NUM_LEDS 45
#define DATA_PIN 4
// Clock pin only needed for SPI based chipsets when not using hardware SPI
#define CLOCK_PIN 3
//fixed values for octoWS2811
CRGB leds[NUM_LEDS];
//for SD_Fat
SdFile myFile;
#define SD_CS SS // Set the chip select line to whatever you use (10 doesnt conflict with the library)
SdFat sd; // set filesystem
SdFile bmpFile; // set filesystem
//for image processing
#define BUF_SIZE 441//180//10240
#define BUFFPIXEL 50//20//147
int bmpLength = 45;//these two need filling in first
int paintTime =40;//these two need filling in first
int time = paintTime/bmpLength;
// because the BMP is read from the bottom first, and we are displaying this using a POV wand,
// the BMP needs to be saved on its side to display correctly when the POV is waved, that is
// turned by 90 degrees, then saved as a 24bit bmp to the SD card
// BMP needs to be NUM_LEDS high when saving a version to the BMP.
// In the SD card, place 24 bit color BMP files (be sure they are 24-bit!)
ArduinoOutStream cout(Serial);
// store error strings in flash to save RAM
#define error(s) sd.errorHalt_P(PSTR(s))
  FastLED.addLeds<APA102, DATA_PIN, CLOCK_PIN, BGR>(leds, NUM_LEDS);
//  Serial.begin(9600); //for bug testing and speed checking using serial
//while(!Serial){};
//  delay(100);
  progmemPrint(PSTR("Initializing SD card..."));
  if (!sd.begin(SD_CS, SPI_FULL_SPEED)) {
    progmemPrintln(PSTR("failed!"));
    return;
  progmemPrintln(PSTR("OK!"));
  delay(200);
//  upDown(5000); //this is a test pattern
//Chaser(2000,1); //this is a test pattern
//Blue_flower(5000,2); //this is a test pattern
 bmpDraw("red.bmp");
 bmpDraw("green.bmp");
 bmpDraw("blue.bmp");
 bmpDraw("rgbVertical.bmp");
 bmpDraw("rgbHori.bmp");
 bmpDraw("Bulge02b.bmp");
//  bmpDraw("diam.bmp",1000);
//  bmpDraw("wing.bmp",1000);
 //   bmpDraw("ball.bmp",1000);//filename and time in ms to keep displaying
//    for(int a=0;a<NUM_LEDS;a++){
//    leds[a].setRGB(0,0,100);}//b,r,g - tested with single colour here
//    FastLED.show();
//delay (10000);
//some patterns
 void upDown(unsigned long time){
   unsigned long currentTime = millis();
 while (millis()< currentTime + (time)) {
   for (int i=0;i<NUM_LEDS;i++) {
  leds[i].setRGB(255,0,0);
  FastLED.show();
   delay(1);
  leds[i].setRGB(0,0,0);
    for (int i=NUM_LEDS-1;i>0;i--) {
  FastLED.show();
   delay(1);
// ////////////////////////////////Chaser
//void Chaser(long time, int frame){
//unsigned long currentTime = millis();
//unsigned int Colour2 = setRGB(255,0,0);//brg
//unsigned int Colour =setRGB(0,0,0);
//unsigned int Colour1 =setRGB(0,255,255);
//int Led1 =0;
//int Led2 =NUM_LEDS-1;
//int increment =1;
//int increment2=1;
//while (millis()< currentTime + (time)) {
//leds[Led1]=leds[Colour1];
//leds[Led2]=leds[Colour2];
//FastLED.show(); delay(1);
//for(int x = 0 ; x < NUM_LEDS ; x++)
//leds[x]=leds[Colour];
//FastLED.show();
//if(Led1>NUM_LEDS-1){increment=-1;}
//else if(Led1<0){increment=1;}
//Led1 = Led1+increment;
//if(Led2<0){increment2=1;}
//else if(Led2>NUM_LEDS-1){increment2=-1;}
//Led2 = Led2+increment2;
//Led1 =0;
//Led2 =NUM_LEDS-1;
//increment =1;
//increment2=1;
 ///////////////////////////////////////////blue flower
 void Blue_flower(long time, int frame){
 byte Counter;
 for(Counter=0;Counter < NUM_LEDS; Counter++)
   leds[Counter].setRGB(0,0,0);
   leds[Counter].setRGB(0,0,255);
FastLED.show();
//delayMicroseconds(100);
delay(1);
// Show a colour bar going down from 9 to 0
byte Counter2;
for(Counter2=NUM_LEDS;Counter2 > 0; Counter2--)
leds[Counter2-1].setRGB(255,0,0);
if(Counter2>3){
leds[Counter2-3].setRGB(0,255,0);}
FastLED.show();
delay(1);
void bmpDraw(char* filename){
// unsigned long currentTime = millis();
 //so that the image continues to be displayed again for a set time
//   while (millis()< currentTime + (time)) {
  SdFile   bmpFile;
  int      bmpWidth, bmpHeight;   // W+H in pixels
  uint8_t  bmpDepth;              // Bit depth (currently must be 24)
  uint32_t bmpImageoffset;        // Start of image data in file
  uint32_t rowSize;               // Not always = bmpWidth; may have padding
  uint8_t  sdbuffer[3*BUFFPIXEL]; // pixel in buffer (R+G+B per pixel)
  /*uint16_t*/uint32_t povbuffer[BUFFPIXEL];  // pixel out buffer (16-bit per pixel)//////mg/////this needs to be 24bit per pixel////////
  uint8_t  buffidx = sizeof(sdbuffer); // Current position in sdbuffer
  boolean  goodBmp = false;       // Set to true on valid header parse
  boolean  flip    = true;        // BMP is stored bottom-to-top
  int      w, h, row, col;
  /*uint8_t*/int  r, g, b;
  uint32_t pos = 0, startTime = millis();
  uint8_t  povidx = 0;
  boolean  first = true;
  // Open requested file on SD card
  bmpFile.open(filename, O_READ);
//progmemPrint(PSTR(filename));
  // Parse BMP header
  if(read16(bmpFile) == 0x4D42) { // BMP signature
    progmemPrint(PSTR("File size: "));
    Serial.println(read32(bmpFile));
    (void)read32(bmpFile); // Read & ignore creator bytes
    bmpImageoffset = read32(bmpFile); // Start of image data
    progmemPrint(PSTR("Image Offset: "));
    Serial.println(bmpImageoffset, DEC);
    // Read DIB header
    progmemPrint(PSTR("Header size: "));
    bmpWidth  = read32(bmpFile);
    bmpHeight = read32(bmpFile);
    if(read16(bmpFile) == 1) { // # planes -- must be '1'
      bmpDepth = read16(bmpFile); // bits per pixel
      progmemPrint(PSTR("Bit Depth: ")); //Serial.println(bmpDepth);
      if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
        goodBmp = true; // Supported BMP format -- proceed!
        // BMP rows are padded (if needed) to 4-byte boundary
       rowSize = (bmpWidth * 3 + 3) & ~3;
        // If bmpHeight is negative, image is in top-down order.
        // This is not canon but has been observed in the wild.
        if(bmpHeight < 0) {
          bmpHeight = -bmpHeight;
          flip      = false;
        w = bmpWidth;
        h = bmpHeight;
     for (row=0; row<h; row++) {
         if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
            pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
          else     // Bitmap is stored top-to-bottom
            pos = bmpImageoffset + row * rowSize;
          if(bmpFile.curPosition() != pos) { // Need seek?
            bmpFile.seekSet(pos);
            buffidx = sizeof(sdbuffer); // Force buffer reload
          for (col=0; col<w; col++) { // For each column...
            // read more pixel data
           if (buffidx >= sizeof(sdbuffer)) {
             povidx = 0;
              bmpFile.read(sdbuffer, sizeof(sdbuffer));
              buffidx = 0; // Set index to beginning
            // set pixel
            r = sdbuffer[buffidx++];
            g = sdbuffer[buffidx++];
            b = sdbuffer[buffidx++];
//we need to output BRG 24bit colour//
            povbuffer[povidx++] =((unsigned int)b & 0x1F <<16 | ((unsigned int)r & 0x1F)<<8 | ((unsigned int)g & 0x1F));
            //Color(b,r,g);//octo colour, but you might need to change this
        for(int i=0;i<NUM_LEDS;i++){
   leds[i]=povbuffer[i]; }
        FastLED.show();
        delay(time);// change the delay time depending effect required
       //   delayMicroseconds(220);
    } // end scanline
//        progmemPrint(PSTR("Loaded in ")); //for bug testing using serial output
//        Serial.print(millis() - startTime);
//        Serial.println(" ms");
      } // end goodBmp
//  Serial.println(read16(bmpFile), HEX);
  bmpFile.close();
//------- HELPER FUNCTION------//
// Create a 24 bit color value from R,G,B ////these strips are BRG, but you might need to change this
unsigned int Color(byte b/*r*/, byte g, byte /*b*/r)
  //Take the lowest 8 bits of each value and append them end to end
return( ((unsigned int)g & 0x1F )<<16 | ((unsigned int)r & 0x1F)<<8 | (unsigned int)b & 0x1F);
//end of helper function
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(SdFile& f) {
  uint16_t result;
  ((uint8_t *)&result)[0] = f.read(); // LSB
  ((uint8_t *)&result)[1] = f.read(); // MSB
  return result;
uint32_t read32(SdFile& f) {
  uint32_t result;
  ((uint8_t *)&result)[2] = f.read();
  ((uint8_t *)&result)[3] = f.read(); // MSB
  return result;
// Copy string from flash to serial port
// Source string MUST be inside a PSTR() declaration!
void progmemPrint(const char *str) {
  char c;
  while(c = pgm_read_byte(str++)) Serial.print(c);
// Same as above, with trailing newline
void progmemPrintln(const char *str) {
  progmemPrint(str);
Hello, im trying to make your design. Using a teensy 3.2. I have a problem with the code: 'Color' was not declared in this scope .
I think it could be a problem with libraries meaby... But im too new on programming to know, could you help me, please?
Thanks.
the Colour function is a helper function. It should be declared in your sketch. Do you have the below code:
if you already have this code, try putting this line just below your includes:
unsigned int Color(byte b, byte g, byte r)
