Page 3 of 3 FirstFirst 1 2 3
Results 51 to 55 of 55
Thread: OctoWS2811 POV reading BMP from SD card
  1. #51
    2,992
    Quote Originally Posted by mortonkopf View Post
    if you already have this code, try putting this line just below your includes:
    unsigned int Color(byte b, byte g, byte r)
    That line is missing the ending semicolon. That line should be:
    unsigned int Color(byte b, byte g, byte r);
  2. #52
    Senior Member mortonkopf's Avatar
    Apr 2013
    London, uk
    898
    Good Catch MM
  3. #53
    can OctoWS2811 Lib run APA102 Leds or do we have to convert it, Id like to have the code running on those type of LEDs sofar. been using the Teensy 3.5 ant wanting to know what alteration to the code have to be done
    https://forum.pjrc.com/threads/24535...P-from-SD-card
  4. #54
    2,992
    Cool
    Quote Originally Posted by synersignart View Post
    The OctoWS2811 library only handles WS2812 (aka what Adafruit calls neopixel) LEDs.
    If you wanted to use APA102 LEDs, you could use the Octows2811 board to provide the infrastructure, but you would need to use something else to drive the LEDs. I believe the FastLed library might be able to drive the APA102's in parallel, but I've never used it.
    You would need to use 4 parallel sets of APA102 LEDs since WS2812 LEDs only have one data pin and the clock is done at fixed intervals, APA102 LEDs have both a data and a clock pin, so you would need to use two wires for each strand, hence only 4 parallel rows instead of 8.
  5. #55
    Apr 2013
    London, uk
    898
    hi, have a read of Po Ting work using APA102 reading from SD Card for POV. its at the end of the thread here: https://forum.pjrc.com/threads/53088...-POV-v2-0-80HD
