I'm still trying to get the RFM69HW to work with the Teensy 3.1.
I have the RFM69HW wired to the Teensy 3.1 as follows.
RFM69HW......Teensy
NSS..........D8
SCK..........D13
MISO.........D12
MOSI.........D11
D0...........D0
GND..........GND..........GND
3.3V......................Regulated 3.3v Supply
ANT.......................Antenna
I downloaded the driver from GitHub, Low Power Labs, https://github.com/LowPowerLab/RFM69
I tested the Node & Gateway example using Moteino's, R4 and verified they work.
I commented out the line,
SPI.setDataMode(SPI_MODE0);
in the library file RFM69.cpp (this line would cause the Teensy 3.1 to hang, Mode 0 is the default anyways)
I removed the SPI Flash from the example, and added conditional compile (#if defined) so that the Teensy 3.1 uses CS pin 8, and Interrupt pin 0 and the Moteino uses the default (CS pin 10, interrupt pin 2).
I tested the modified project with the Moteinos and verified that it still works.
I tested using the Teensy 3.1 with the gateway sketch, and a Moteino using the node sketch. The Teensy initializes without error, but never receives any transmissions. If i type 't', it will report the RFM temperature.
Below is a picture of the Teensy connected to the RFM69HW.
Here is the modified version of the Node example
// Sample RFM69 sender/node sketch, with ACK and optional encryption
// Sends periodic messages of increasing length to gateway (id=1)
// It also looks for an onboard FLASH chip, if present
// Library and code by Felix Rusu - felix@lowpowerlab.com
// Get the RFM69 and SPIFlash library at: https://github.com/LowPowerLab/
#include <RFM69.h>
#define NODEID 2 //unique for each node on same network
#define NETWORKID 100 //the same on all nodes that talk to each other
#define GATEWAYID 1
//Match frequency to the hardware version of the radio on your Moteino (uncomment one):
#define FREQUENCY RF69_433MHZ
//#define FREQUENCY RF69_868MH
//#define FREQUENCY RF69_915MHZ
#define ENCRYPTKEY "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
#define IS_RFM69HW //uncomment only for RFM69HW! Leave out if you have RFM69W!
#define ACK_TIME 30 // max # of ms to wait for an ack
#define LED 2 // Moteinos have LEDs on D9
#define SERIAL_BAUD 115200
int TRANSMITPERIOD = 300; //transmit a packet to gateway so often (in ms)
char payload[] = "123 ABCDEFGHIJKLMNOPQRSTUVWXYZ";
char buff[20];
byte sendSize=0;
boolean requestACK = false;
#if defined( __MK20DX256__ ) || defined( __MK20DX128__ )
#define TEENSY_CPU 1
RFM69 radio(8,0);
#else
#define TEENSY_CPU 0
RFM69 radio;
Serial.begin(SERIAL_BAUD);
delay(3000);
radio.initialize(FREQUENCY,NODEID,NETWORKID);
#ifdef IS_RFM69HW
radio.setHighPower(); //uncomment only for RFM69HW!
radio.encrypt(ENCRYPTKEY);
char buff[50];
if( TEENSY_CPU )
Serial.print( "\nTeensy" );
Serial.print( "\nMoteino" );
sprintf(buff, " transmitting at %d Mhz...", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
Serial.println(buff);
long lastPeriod = -1;
//process any serial input
if (Serial.available() > 0)
char input = Serial.read();
if (input >= 48 && input <= 57) //[0,9]
TRANSMITPERIOD = 100 * (input-48);
if (TRANSMITPERIOD == 0) TRANSMITPERIOD = 1000;
Serial.print("\nChanging delay to ");
Serial.print(TRANSMITPERIOD);
Serial.println("ms\n");
if (input == 'r') //d=dump register values
radio.readAllRegs();
//if (input == 'E') //E=enable encryption
// radio.encrypt(KEY);
//if (input == 'e') //e=disable encryption
// radio.encrypt(null);
//check for any received packets
if (radio.receiveDone())
Serial.print('[');Serial.print(radio.SENDERID, DEC);Serial.print("] ");
for (byte i = 0; i < radio.DATALEN; i++)
Serial.print((char)radio.DATA[i]);
Serial.print(" [RX_RSSI:");Serial.print(radio.RSSI);Serial.print("]");
if (radio.ACK_REQUESTED)
radio.sendACK();
Serial.print(" - ACK sent");
delay(10);
Blink(LED,5);
int currPeriod = millis()/TRANSMITPERIOD;
if (currPeriod != lastPeriod)
lastPeriod=currPeriod;
Serial.print("Sending[");
Serial.print(sendSize);
Serial.print("]: ");
for(byte i = 0; i < sendSize; i++)
Serial.print((char)payload[i]);
if (radio.sendWithRetry(GATEWAYID, payload, sendSize))
Serial.print(" ok!");
else Serial.print(" nothing...");
sendSize = (sendSize + 1) % 31;
Blink(LED,3);
void Blink(byte PIN, int DELAY_MS)
pinMode(PIN, OUTPUT);
digitalWrite(PIN,HIGH);
delay(DELAY_MS);
digitalWrite(PIN,LOW);
And this is the modified version of the Gateway example
// Sample RFM69 receiver/gateway sketch, with ACK and optional encryption
// Passes through any wireless received messages to the serial port & responds to ACKs
#include <RFM69.h>
#define NODEID 1 //unique for each node on same network
//#define FREQUENCY RF69_868MHZ
#define LED 13 // Moteinos have LEDs on D9
RFM69 radio(8,0);
#else
RFM69 radio;
bool promiscuousMode = false; //set to 'true' to sniff all packets on the same network
delay(3000);
#ifdef IS_RFM69HW
radio.promiscuous(promiscuousMode);
char buff[50];
if( TEENSY_CPU )
Serial.print( "\nTeensy " );
Serial.print( "\nMoteino " );
sprintf(buff, "Listening at %d Mhz...", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
byte ackCount=0;
if (input == 'r') //d=dump all register values
if (input == 'p')
promiscuousMode = !promiscuousMode;
Serial.print("Promiscuous mode ");Serial.println(promiscuousMode ? "on" : "off");
if (input == 't')
byte temperature = radio.readTemperature(-1); // -1 = user cal factor, adjust for correct ambient
byte fTemp = 1.8 * temperature + 32; // 9/5=1.8
Serial.print( "Radio Temp is ");
Serial.print(temperature);
Serial.print("C, ");
Serial.print(fTemp); //converting to F loses some resolution, obvious when C is on edge between 2 values (ie 26C=78F, 27C=80F)
Serial.println('F');
if (promiscuousMode)
Serial.print("to [");Serial.print(radio.TARGETID, DEC);Serial.print("] ");
byte theNodeID = radio.SENDERID;
radio.sendACK();
Serial.print(" - ACK sent.");
// When a node requests an ACK, respond to the ACK
// and also send a packet requesting an ACK (every 3rd one only)
// This way both TX/RX NODE functions are tested on 1 end at the GATEWAY
if (ackCount++%3==0)
Serial.print(" Pinging node ");
Serial.print(theNodeID);
Serial.print(" - ACK...");
delay(3); //need this when sending right after reception .. ?
if (radio.sendWithRetry(theNodeID, "ACK TEST", 8, 0)) // 0 = only 1 attempt, no retries
Serial.print("ok!");
else Serial.print("nothing");
// Blink(LED,3);
// pinMode(PIN, OUTPUT);
delay(DELAY_MS);
I also tried adding
radio.send( 2, "Test", 4 );
which would run on the Gateway whenever 't' is pressed, after displaying the temperature. When I press 't' on the Gateway serial terminal, both the gateway and the node would hangup. The node would recover after unplugging the USB cable from the Gateway.
Does anyone have any ideas why this is not working?
Thanks,
Eric
