Results 1 to 9 of 9
Thread: Serial_install not working
    Hi
    I had to start from scratch with all my dev stuff as I had my laptop liberated. Now I am having all kinds of issues that was never a problem before.
    My USB Serial port is not recognized when I plug my Teensy3.0 in. I then tried to oload the drivers with the serial_install program but that gives the attached error. All the other serial configs work with the Teensy3.0, just the USB Serial is broken.
    Oh and I am using Windows 8.0 now
    21,320
    You need to reboot to the special Windows 8 mode that temporarily allows unsigned driver install.
    http://www.makeuseof.com/tag/how-can...-in-windows-8/
    Hi Paul,
    I did that before. Does it only last for one reboot?
    21,320
    Correct. It only allows unsigned driver install for that 1 boot. As soon as you reboot normally, you're back to the normal settings that don't permit unsigned driver install.
    OK that sorted it out. Now the question is why did I loose it in the first place? Did I do something stupid somewhere?
    21,320
    Oh if only I knew why things mysterously work, then don't work, then work again on Windows....
    Paul,
    I gather that this wont be a problem on Linux then. I will not need a driver am I right?
    3,485
    Under Linux, you will need to update the udev rules to tell the udev device manager when you plug in a Teensy 3.0 what type of device it is:
    sudo cp 49-teensy.rules /etc/udev/rules.d/
    There are also these tips in the install page: http://www.pjrc.com/teensy/td_downlo...l#linux_issues
    21,320
    Yes, what Michael said.
    The udev rules are needed because the default for unknown devices is root-only permission. The Gnome Modem Manager also needs to be told to leave Teensy alone, so even if you run everything as root, you still need the udev rules.
