Results 1 to 9 of 9
Thread: Serial_install not working
    Nov 2013
    18
    Hi
    I had to start from scratch with all my dev stuff as I had my laptop liberated. Now I am having all kinds of issues that was never a problem before.
    My USB Serial port is not recognized when I plug my Teensy3.0 in. I then tried to oload the drivers with the serial_install program but that gives the attached error. All the other serial configs work with the Teensy3.0, just the USB Serial is broken.
    Oh and I am using Windows 8.0 now
    21,097
    You need to reboot to the special Windows 8 mode that temporarily allows unsigned driver install.
    http://www.makeuseof.com/tag/how-can...-in-windows-8/
    Nov 2013
    18
    Hi Paul,
    I did that before. Does it only last for one reboot?
    21,097
    Correct. It only allows unsigned driver install for that 1 boot. As soon as you reboot normally, you're back to the normal settings that don't permit unsigned driver install.
    Nov 2013
    18
    OK that sorted it out. Now the question is why did I loose it in the first place? Did I do something stupid somewhere?
    21,097
    Oh if only I knew why things mysterously work, then don't work, then work again on Windows....
    Nov 2013
    18
    Paul,
    I gather that this wont be a problem on Linux then. I will not need a driver am I right?
    3,454
    Under Linux, you will need to update the udev rules to tell the udev device manager when you plug in a Teensy 3.0 what type of device it is:
    sudo cp 49-teensy.rules /etc/udev/rules.d/
    There are also these tips in the install page: http://www.pjrc.com/teensy/td_downlo...l#linux_issues
    21,097
    Yes, what Michael said.
    The udev rules are needed because the default for unknown devices is root-only permission. The Gnome Modem Manager also needs to be told to leave Teensy alone, so even if you run everything as root, you still need the udev rules.
