Results 1 to 3 of 3
Thread: How can I get a stable and accurate sample rate?
    Jane
    Guest
    Hi I'm new to teensy and I'm using a teensy3.2 and I want to get the data from teensy to my laptop with a stable and accurate sample rate(I don't need very high, higher than 16k is enough).
    I have tried the function adc->setSamplingSpeed(SPEED) in the ADC library to set the sample speed,but the result I got is not good. I don't know the actual sample rate and I got about 272000 data for two seconds, and got 460650 data for four seconds when I set the same sample rate.
    So is there any simple way for me to set an accurate sample rate? Thanks for your help!
    Dec 2014
    310
    Quote Originally Posted by Jane View Post
    Can you post your sketch? Could be a number of things up.
    Jane
    Guest
    /* Example for analogContinuousRead
    * It measures continuously the voltage on pin A9,
    * Write v and press enter on the serial console to get the value
    * Write c and press enter on the serial console to check that the conversion is taking place,
    * Write t to check if the voltage agrees with the comparison in the setup()
    * Write s to stop the conversion, you can restart it writing r.
    #include <ADC.h>
    const int readPin = A0; // ADC0 A0
    //const int readPin2 = A3; // ADC1
    //const int readPin3 = A2; // ADC0 or ADC1
    ADC *adc = new ADC(); // adc object
    pinMode(LED_BUILTIN, OUTPUT);
    pinMode(readPin, INPUT);
    ///// ADC0 ////
    // reference can be ADC_REF_3V3, ADC_REF_1V2 (not for Teensy LC) or ADC_REF_EXT.
    //adc->setReference(ADC_REF_1V2, ADC_0); // change all 3.3 to 1.2 if you change the reference to 1V2
    adc->setAveraging(1); // set number of averages
    adc->setResolution(16); // set bits of resolution
    // it can be ADC_VERY_LOW_SPEED, ADC_LOW_SPEED, ADC_MED_SPEED, ADC_HIGH_SPEED_16BITS, ADC_HIGH_SPEED or ADC_VERY_HIGH_SPEED
    // see the documentation for more information
    // additionally the conversion speed can also be ADC_ADACK_2_4, ADC_ADACK_4_0, ADC_ADACK_5_2 and ADC_ADACK_6_2,
    // where the numbers are the frequency of the ADC clock in MHz and are independent on the bus speed.
    adc->setConversionSpeed(ADC_VERY_LOW_SPEED); // change the conversion speed
    // it can be ADC_VERY_LOW_SPEED, ADC_LOW_SPEED, ADC_MED_SPEED, ADC_HIGH_SPEED or ADC_VERY_HIGH_SPEED
    adc->setSamplingSpeed(ADC_VERY_LOW_SPEED); // change the sampling speed
    // always call the compare functions after changing the resolution!
    //adc->enableCompare(1.0/3.3*adc->getMaxValue(ADC_0), 0, ADC_0); // measurement will be ready if value < 1.0V
    //adc->enableCompareRange(1.0*adc->getMaxValue(ADC_0)/3.3, 2.0*adc->getMaxValue(ADC_0)/3.3, 0, 1, ADC_0); // ready if value lies out of [1.0,2.0] V
    // If you enable interrupts, notice that the isr will read the result, so that isComplete() will return false (most of the time)
    //adc->enableInterrupts(ADC_0);
    adc->startContinuous(readPin, ADC_0);
    // ////// ADC1 /////
    // #if ADC_NUM_ADCS>1
    // adc->setAveraging(32, ADC_1); // set number of averages
    // adc->setResolution(12, ADC_1); // set bits of resolution
    // adc->setConversionSpeed(ADC_VERY_LOW_SPEED, ADC_1); // change the conversion speed
    // adc->setSamplingSpeed(ADC_VERY_LOW_SPEED, ADC_1); // change the sampling speed
    // // always call the compare functions after changing the resolution!
    // //adc->enableCompare(1.0/3.3*adc->getMaxValue(ADC_1), 0, ADC_1); // measurement will be ready if value < 1.0V
    // //adc->enableCompareRange(1.0*adc->getMaxValue(ADC_1)/3.3, 2.0*adc->getMaxValue(ADC_1)/3.3, 0, 1, ADC_1); // ready if value lies out of [1.0,2.0] V
    // // If you enable interrupts, notice that the isr will read the result, so that isComplete() will return false (most of the time)
    // //adc->enableInterrupts(ADC_1);
    // adc->startContinuous(readPin2, ADC_1);
    // #endif
    int value = 0;
    int value2 = 0;
    char c=0;
    value = (uint16_t)adc->analogReadContinuous(ADC_0); // the unsigned is necessary for 16 bits, otherwise values larger than 3.3/2 V are negative!
    Serial.println(value, DEC);
    if (Serial.available()) {
    c = Serial.read();
    if(c=='c') { // conversion active?
    Serial.print("Converting? ADC0: ");
    Serial.println(adc->isConverting(ADC_0));
    } else if(c=='s') { // stop conversion
    adc->stopContinuous(ADC_0);
    Serial.println("Stopped");
    } else if(c=='t') { // conversion successful?
    Serial.print("Conversion successful? ADC0: ");
    Serial.println(adc->isComplete(ADC_0));
    } else if(c=='r') { // restart conversion
    Serial.println("Restarting conversions ");
    } else if(c=='v') { // value
    Serial.print("Value ADC0: ");
    Serial.println(value*3.3/adc->getMaxValue(ADC_0), DEC);
    } else if(c=='n') { // new single conversion on readPin3
    // this shows how even when both ADCs are busy with continuous measurements
    // you can still call analogRead, it will pause the conversion, get the value and resume the continuous conversion automatically.
    // Serial.print("Single read on readPin3: ");
    // Serial.println(adc->analogRead(readPin3)*3.3/adc->getMaxValue(ADC_0), DEC);
    /* fail_flag contains all possible errors,
    They are defined in ADC_Module.h as
    ADC_ERROR_OTHER
    ADC_ERROR_CALIB
    ADC_ERROR_WRONG_PIN
    ADC_ERROR_ANALOG_READ
    ADC_ERROR_COMPARISON
    ADC_ERROR_ANALOG_DIFF_READ
    ADC_ERROR_CONT
    ADC_ERROR_CONT_DIFF
    ADC_ERROR_WRONG_ADC
    ADC_ERROR_SYNCH
    You can compare the value of the flag with those masks to know what's the error.
    if(adc->adc0->fail_flag) {
    Serial.print("ADC0 error flags: 0x");
    Serial.println(adc->adc0->fail_flag, HEX);
    digitalWriteFast(LED_BUILTIN, !digitalReadFast(LED_BUILTIN));
    // delay(100);
    void adc0_isr(void) {
    digitalWriteFast(LED_BUILTIN, !digitalReadFast(LED_BUILTIN)); // Toggle the led
    // RESULTS OF THE TEST Teesny 3.x
    // Measure continuously a voltage divider.
    // Measurement pin A9 (23). Clock speed 96 Mhz, bus speed 48 MHz.
    // Using ADC_LOW_SPEED (same as ADC_VERY_LOW_SPEED) for sampling and conversion speeds
    // ADC resolution Measurement frequency Num. averages
    // 16 bits 81 kHz 1
    // 12 bits 94 kHz 1
    // 10 bits 94 kHz 1
    // 8 bits 103 kHz 1
    // 16 bits 2.5 kHz 32
    // 12 bits 2.9 kHz 32
    // 10 bits 2.9 kHz 32
    // 8 bits 3.2 kHz 32
    // Using ADC_MED_SPEED for sampling and conversion speeds
    // 16 bits 193 kHz 1
    // 12 bits 231 kHz 1
    // 10 bits 231 kHz 1
    // 8 bits 261 kHz 1
    // 10 bits 58 kHz 4 (default settings) corresponds to about 17.24 us
    // Using ADC_HIGH_SPEED (same as ADC_HIGH_SPEED_16BITS) for sampling and conversion speeds
    // 16 bits 414 kHz 1
    // 12 bits 500 kHz 1
    // 10 bits 500 kHz 1
    // 8 bits 571 kHz 1
    // 8 bits 308 kHz 1 ADC_VERY_LOW_SPEED sampling
    // 8 bits 387 kHz 1 ADC_LOW_SPEED sampling
    // 8 bits 480 kHz 1 ADC_MED_SPEED sampling
    // 8 bits 632 kHz 1 ADC_VERY_HIGH_SPEED sampling
    // Using ADC_VERY_HIGH_SPEED for sampling and conversion speeds
    // This conversion speed is over the limit of the specs! (speed=24MHz, limit = 18 MHz for res<16 and 12 for res=16)
    // 16 bits 888 kHz 1
    // 12 bits 1090 kHz 1
    // 10 bits 1090 kHz 1
    // 8 bits 1262 kHz 1
    // At 96 Mhz (bus at 48 MHz), 632 KHz is the fastest we can do within the specs, and only if the sample's impedance is low enough.
    // RESULTS OF THE TEST Teensy LC
    // Measurement pin A9 (23). Clock speed 48 Mhz, bus speed 24 MHz.
    // Using ADC_VERY_LOW_SPEED for sampling and conversion speeds
    // 16 bits 33.3 kHz 1
    // 12 bits 37.5 kHz 1
    // 10 bits 37.5 kHz 1
    // 8 bits 40.5 kHz 1
    // 16 bits 1.04 kHz 32
    // 12 bits 1.2 kHz 32
    // 10 bits 1.2 kHz 32
    // 8 bits 1.3 kHz 32
    // ADC_LOW_SPEED, ADC_MED_SPEED, ADC_HIGH_SPEED_16BITS, ADC_HIGH_SPEED and ADC_VERY_HIGH_SPEED are the same for Teensy 3.x and LC,
    // except for a very small ammount that depends on the bus speed and not on the ADC clock (which is the same for those speeds).
    // This difference corresponds to 5 bus clock cycles, which is about 0.1 us.
    // For 8 bits resolution, 1 average, ADC_MED_SPEED sampling speed the measurement frequencies for the different ADACK are:
    // ADC_ADACK_2_4 106.8 kHz
    // ADC_ADACK_4_0 162.6 kHz
    // ADC_ADACK_5_2 235.1 kHz
    // ADC_ADACK_6_2 263.3 kHz
    // For Teensy 3.x the results are similar but not identical for two reasons: the bus clock plays a small role in the total time and
    // the frequency of this ADACK clock is acually quite variable, the values are the typical ones, but in the electrical datasheet
    // it says that they can range from +-50% their values aproximately, so every Teensy can have different frequencies.
    I use the example code on github and change some lines, but it didn't work well, maybe there is something wrong. Thanks a lot!
