Results 1 to 3 of 3
Thread: deal alert: SP-320-5 PSU's for $40 + $9.99 shipping (active PFC, variable fan, etc)
    Oct 2013
    116
    I'm not affiliated w/ the seller in any way. I just came across the deal and thought I'd share w/ the community. They're new and the seller has great feedback:
    http://www.ebay.com/itm/MEAN-WELL-27...p2054897.l4275
    55A @ 5V, auto-switching, active PFC, load-based fan speed (sooo much quieter than the S-600-5's I tried, even with the fans at max speed), etc.
    Jun 2013
    So. Calif
    2,828
    5V @ 55A.
    How many Teensys can that support?
    Oct 2013
    116
    5V @ 55A.
    Well if you're ONLY powering teensies... um... a metric crap-ton If you're also powering WS2812b LEDs, then quite a few! I keep forgetting to order a fuse for my DMM to measure actual current draw on my strips; according to Ray Wu, the WS2812b strips need around 7.2 amps (36W @ 5V) per 5-meter (150LED) strip, but Paul's numbers indicate the current demands are a bit higher. Anyway, about 1000-1100 LED's per PSU.
    Last edited by tetsuo; 12-09-2013 at 03:45 PM. Reason: snagged actual amps/watts from Ray Wu'd listing, fixed typos
