This the the first time I have done much with serial monitor in a couple of months. Arduino 1.05, TeensyDuino 1.15, Win7 Pro 64, Teensy3. I'd like to log output (captured with RealTerm 2.0.0.57) from Teensy and import into a spreadsheet. This worked fine a couple of months ago. I output some data every second or less.
Now what I see with a couple of different Teensy3 is that after 2000-3000 seconds there seems to be no more serial output from Teensy3 USB. Nothing shows on Arduino's Serial Monitor, and if I turn that off and try RealTerm there's nothing for it to show either. I have not tried to probe the serial signals on Teensy3. Teensy3 is still running: I can see I2C signals and a status LED is getting updated when it turns a heater on and off.
Since Teensy is running I suspect the PC USB connection, but what can I do to debug further? Since it works for several minutes, clearly all the links in the chain are OK for that time. I don't have a theory why it would stop after a while.
Is anyone else seeing this?
Bruce
Bruce
