I acquired a TC Flashback X4, which is a nice looper/delay in that you can utilize the looper and delay simultaneously, i.e. loop a "delayed" signal, change the delay time/feedback, overdub that signal, etc. All good. Except for one detail: The delay Tap Tempo button becomes inoperative (re-purposed) when the looper is active. Bad. The saving factor may be that the device can respond to MIDI clock from its DIN MIDI input.
I'd like to construct a dedicated DIN MIDI clock generator stomp-box, with a momentary contact Tap Tempo button, and, ideally, a 3 digit tempo display and a pot to direct-dial a tempo (with Tap override). I've built a few Teensy MIDI devices, switch/button to MIDI Note/CC, and MIDI CC to LED, but nothing "clocked" per se. Is this idea too ambitious re: the stability of the clock, having to deal w/ interrupts, etc? I've searched a fair bit trying to find any similar code to learn from, but no joy. Anyone have any thoughts on this?
Thanks so much.
Thanks so much.
