Hi have the ws2811 strips hooked up as so: PSU1- strips 1-11, PSU2- strips 11-20, PSU3- strips 21-32 with 2 teensys, each controlling half. I am running basic test to check for flickering and found that the colors are going through the strips well until it hits the other next psu. The strips are a different color than the other and there is flickering. I have the teensy grounded to both the psu's powering the set of strips along with the 220ohm resistors close to teensys.
Is my wiring incorrect? Also, what type of wire should be used for signal? I am using 18awg for 5v and grnd wires, 22awg for signal.
