Results 1 to 3 of 3
Thread: Problem with ADC on Teensy 3.0
    Junior Member JeremyW's Avatar
    Dec 2013
    1
    I am working on building a ADC conversion board to read a voltage from a photodiode to an input pin on the teensy 3.0 and send it out over serial connection to an output.
    My goal is that the value it sends out is as close of a reading as the voltmeter reads. The voltmeter has been extremely accurate so far R2 of .9998. but the teensy is still giving me problems.
    void TwoSixtynmP0()
    digitalWrite(redPin, HIGH); // turn on the red LED
    double rSum0 = 0;
    double rlSum0 = 0;
    int RVoltage0 = 0;
    for (int r = 0; r < 5; r++)
    for (int rl = 0; rl < 10; rl++)
    delay(50);
    int RsensorValue = analogRead(A0);
    double RVoltage0 = RsensorValue * (3.3 / 1023.0); // is this conversion correct?
    if (RVoltage0<0)
    RVoltage0 = 0;
    rlSum0 += RVoltage0;
    delay(10);
    double rAvg0 = rlSum0 / 50;
    Serial.print("R0:");Serial.println(rAvg0, 5); //Serial.println(rAvg, 5);
    BLEMini.print("R:");BLEMini.println(rAvg0, 5); // BLEMini.println(rAvg, 5);
    dimAll();
    rAvg0=0;
    return;
    Here is what I'm working with:
    External LEDs that are controlled via switch and external battery power. I only have two photodiodes connected to the board. in pins 14 (A0) and 15(A1)
    I also have a bluetooth board connected to pins 0,1
    and a single LED to pin 2 to let me know the board is turned on.
    Teensy Voltage Volt meter Difference % Error
    0.17839 0.155 0.02339 0.1311172151
    0.16194 0.145 0.01694 0.1046066444
    0.13445 0.123 0.01145 0.0851617702
    0.09058 0.043 0.04758 0.5252815191
    0.06413 0.018 0.04613 0.719320131
    I've got much more sample data if needed. I'm at a loss as to where I'm going wrong. Any help is appreciated! if you need more information just ask.
    the setup
    #include*<stdio.h>
    #include*<Arduino.h>*
    #include*<SoftwareSerial.h>
    #include*<Firmata.h>
    //BLE*Mini*is*connected*to*pin*0*and*1
    SoftwareSerial*BLEMini(0,*1);**//RX, TX
    int redPin = 2; //red LED to come on when the UV lights are on.
    int TwoSixtynmDetect = A0; //260nm detector pin 14
    int TwoSixtynmLED = 3; // 260nm UV LED
    int TwoEightynmDetect = A1; //280nm detector pin 15
    int TwoEightynmLED = 4;//280nm UV LED
    byte incomingByte = 0; //incoming data from iPad
    //*Initialize*all*unused*pins*to*output,*for*minimum*battery*useage.
    int emptyoutPin1 = 5;
    int emptyoutPin2 = 6;
    int emptyoutPin3 = 7;
    int emptyoutPin4 = 8;
    int emptyoutPin5 = 9;
    int emptyoutPin6 = 10;
    int emptyoutPin7 = 11;
    int emptyoutPin8 = 12;
    int emptyoutPin9 = 13;
    int emptyoutPin10 = 17;
    int emptyoutPin11 = 18;
    int emptyoutPin12 = 19;
    int emptyoutPin13 = 20;
    int emptyoutPin14 = 21;
    int emptyoutPin15 = 22;
    int emptyoutPin16 = 23;
    BLEMini.begin(57600);
    Serial.begin(57600); //setting the serial speed
    pinMode(redPin, OUTPUT);// configuring the LED pins for output
    pinMode(TwoSixtynmLED, OUTPUT);
    pinMode(TwoEightynmLED, OUTPUT);
    pinMode(TwoSixtynmDetect, INPUT); //initialize the three detectors
    pinMode(TwoEightynmDetect, INPUT); //initialize the three detectors
    //**pinMode(blueDetect,*INPUT);*//initialize*the*three*detectors
    pinMode(emptyoutPin1, OUTPUT); //Set all empty pins as output to save battery power
    pinMode(emptyoutPin2, OUTPUT);
    pinMode(emptyoutPin3, OUTPUT);
    pinMode(emptyoutPin4, OUTPUT);
    pinMode(emptyoutPin5, OUTPUT);
    pinMode(emptyoutPin6, OUTPUT);
    pinMode(emptyoutPin7, OUTPUT);
    pinMode(emptyoutPin8, OUTPUT);
    pinMode(emptyoutPin9, OUTPUT);
    pinMode(emptyoutPin10, OUTPUT);
    pinMode(emptyoutPin11, OUTPUT);
    pinMode(emptyoutPin12, OUTPUT);
    pinMode(emptyoutPin13, OUTPUT);
    pinMode(emptyoutPin14, OUTPUT);
    pinMode(emptyoutPin15, OUTPUT);
    pinMode(emptyoutPin16, OUTPUT);
    digitalWrite(redPin, HIGH); // turn off all LEDS to reset them from any earlier configuration
    digitalWrite(TwoSixtynmLED, HIGH);
    digitalWrite(TwoEightynmLED, HIGH);
    Here is the code for my ADC:
      void TwoSixtynmP0()
             double rSum0 = 0;
             double rlSum0 = 0;
            int RVoltage0 = 0;
             delay(100); // give time for stray light and signal to steady.
                      delay(50);
                         if (RVoltage0<0)
                              RVoltage0 = 0;
             delay(10);
            dimAll();
            rAvg0=0;
            return;
    17,481
    Try using analogReference(INTERNAL) and set the conversion for 1.2 volts. The internal reference should be much more stable.
    Senior Member Jp3141's Avatar
    455
    Also, if you look at your (limited) data, the Teensy has an error of ~ 28 % and there is an offset of ~ -65 mV. You should check your ground connections also.
Tags for this Thread
