sd-adaptor for teensy 3.*
As Headroom pointed out, the Teensy 3 already operates at 3.3V voltage levels, so it needs no voltage translation like 5V-based MCUs. In the link provided, Paul also pointed out that the voltage regulator inside the Teensy 3 can handle the power requirements of a SD card without issues. So, enjoy hooking up that SD card.
thanks!
Thanks!!!, in the link don't specify if the 10k resistor is needed, and the final question is... is the pullup 10k resistor (in the MISO pin) needed for some reason???
