Results 1 to 5 of 5
Thread: Teensy Blink on Teensy 1.0
    Apr 2013
    163
    on my own I'm a huge fan of the Blink example. So I did my part on it and make it more comfortable for me, code below.
    /* LED Blink, Teensyduino Tutorial #1
       http://www.pjrc.com/teensy/tutorial.html
    // Teensy 2.0 has the LED on pin 11
    // Teensy++ 2.0 has the LED on pin 6
    // Teensy 3.0 has the LED on pin 13
    #if defined(__MK20DX128__) || defined(__MK20DX256__)
             //  Teensy 3.0                Teensy 3.1
      #define ledPin 13
    #elif defined (__AVR_ATmega32U4__)
             //     Teensy 2.0
      #define ledPin 11
    #elif defined(__AVR_AT90USB162__) || defined(__AVR_AT90USB646__) || defined(__AVR_AT90USB1286__)
             //    Teensy 1.0                     Teensy 1.0++                   Teensy 2.0++
      #define ledPin  6
    #else
      #define ledPin 13
    //const int ledPin = Pin;
    int timing = 125;
    // the setup() method runs once, when the sketch starts
      // initialize the digital pin as an output.
      pinMode(ledPin, OUTPUT);
    // the loop() methor runs over and over again,
    // as long as the board has power
      digitalWrite(ledPin, HIGH);   // set the LED on
      delay(timing);                  // wait for a second
      digitalWrite(ledPin, LOW);    // set the LED off
    So I tested it on Arduino IDE 1.0.5 with Teensyduino 1.18RC all works fine except for Teensy 1.0 there I get this:
    enabled in File > Preferences.
    Arduino: 1.0.5 (Windows 7), Board: "Teensy 1.0"
    C:\Users\HP\AppData\Local\Temp/ccPO5Vzc.s: Assembler messages:
    C:\Users\HP\AppData\Local\Temp/ccPO5Vzc.s:198: Error: illegal opcode mul for mcu at90usb162
    C:\Users\HP\AppData\Local\Temp/ccPO5Vzc.s:203: Error: illegal opcode mul for mcu at90usb162
    C:\Users\HP\AppData\Local\Temp/ccPO5Vzc.s:207: Error: illegal opcode mul for mcu at90usb162
    C:\Users\HP\AppData\Local\Temp/ccPO5Vzc.s:211: Error: illegal opcode mul for mcu at90usb162
    C:\Users\HP\AppData\Local\Temp/ccPO5Vzc.s:237: Error: illegal opcode mul for mcu at90usb162
    On Arduino IDE 1.0.4 with Teensy 1.14RC2 it compiled fine. So what did I do wrong?
    Attached Files Attached Files
    1,609
    I don't know where the error messages came from but you can remove all the ifdef stuff and replace it with:
    #define ledPin LED_BUILTIN
    Pete
    Apr 2013
    163
    Pete
    Jepp less code, nice to know but same error...
    24,122
    The Teensy 1.0 code is no longer maintained. I'll probably drop Teensy 1.0 support completely in 1.18 or 1.19.
    Apr 2013
    163
    Ah ok, since Version 1.18 or befor, I don't have an Teensy 1.0 but maybe for other it's interesting.
    Happy new Year, Paul.
