Hi Robin,
We have purchased a few Teensy 3.0 to use as a power control / watchdog to our system. We made two sets of prototype and put them in sealed enclosuers. The maximum air temperature logged was 76C / 168F and the teensy failed to boot up after power cycle. The failed chip while powered on generated excess amount of heat and the measuring between 3V and GND is near to 0 Ohm resistance.
We did not use much of the Teensy, we only read a few digital input and operate on digital output and control the power using P-MOSFET. The two samples behave exactly the same, so we'd willing to know if we did something wrong.
We made pretty sure all input never exceeded 3.3V, actually most of them are coming from other ARM boards, which is 3.3V rated.
Very much appreciated if you can give us some hint about what went wrong.
Many Thanks,
Bai Shi.
Many Thanks,
Bai Shi.
