Results 1 to 6 of 6
Thread: FreqMeasure oddities with Adafruit_VS1053.h playing music
    Dec 2016
    3
    Hey,
    I am working on a (for me) rather complex Arduino Uno R3 (328) project with the intent to sync up mp3/aac playback to a running Super 8 projector. Since most of these projectors are really old and don't keep their frequency very well, lip sync is impossible to achieve. I started with the VS1053 part and got Adafruits BoB running fine. I managed to load VLSI patches and can adjust the sampling rate registers on the fly without cracks or pops or other perceivable artifacts. So far, so good!
    To measure the projector's running speed, I have wired up a fast photo diode via a TIA Opamp and get a nice, clean square signal from there (these projectors have a 3-segment rotary blade, so at 18 fps I get 54 Hz square signal on Pin 8.
    I copied the guts from the Example Sketch to my sketch and get perfectly plausible (and valid) results -- you can see the projector warming up
    Here are measured values (averaging taken out to make the effect more visible):
    54.98112
    54.95751
    54.83583
    54.92280
    54.94166
    54.86423
    54.92337
    54.96129
    54.83771
    54.93524
    54.96676
    54.87175
    54.97602
    54.99075
    54.84655
    54.93072
    54.99794
    54.90188
    55.01212
    55.02555
    54.91488
    55.03710
    55.08011
    55.01363
    55.07954
    55.08542
    54.97507
    55.07461
    55.13781
    So far so good -- but now I have a problem: As soon as I start playback on the Adafruit VS1053 BoB via musicPlayer.startPlayingFile("test.m4a"); I get very weird results from FreqMeasure:
    55.08068
    54.98168
    55.02574
    55.01590
    54.94071
    72.06201
    5270.09228
    44.95898
    70.75420
    55.06020
    55.03615
    70.96886
    inf
    55.03218
    55.01439
    54.89491
    71.94860
    233.05609
    55.06267
    70.84317
    71.06090
    55.07252
    54.95619
    55.11901
    71.23236
    71.09658
    55.14085
    55.19182
    71.00256
    55.19716
    The measured freqs are higher, vary much more and there are occasional weird values in.
    Since it is 100% reproducible by starting VS1053 playback, I guess there is some conflict with interrupts. The question is – is there a way to make this work at all simultaneously?
    Regarding the VS1053 playback part, my code is basically derived from the examples, with two changes:
    a) I replaced SD.h with SdFat.h
    b) I changed BREAKOUT_DCS (The VS1053 Data/command select pin (output) form Pin 8 to Pin 2, since FreqMeasure needs Pin 8. Playback was not affected by this.
    So this is the resulting setup:
    #include <Adafruit_VS1053.h>
    #include <FreqMeasure.h>
    #include <SdFat.h>
    SdFat SD;
    #define BREAKOUT_RESET  9      // VS1053 reset pin (output)
    #define BREAKOUT_CS     10     // VS1053 chip select pin (output)
    #define BREAKOUT_DCS    2      // VS1053 Data/command select pin (output)
    #define CARDCS 4     // Card chip select pin
    // DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
    #define DREQ 3       // VS1053 Data request, ideally an Interrupt pin
    const byte eyePin = 8; // amplified Photo Diode on Digital Pin
    My suspicion is that DREQ can be blocking rather long, causing the wrong measurements -- but it is a wild guess since I am not savvy yet with Interrupts and Timers on AVR. Is there any hope that another pin config might help here? Or any hint how I can find out what causes these weird measurements?
    Germany NRW
    6,886
    Quote Originally Posted by peaceman View Post
    Hey,
    Hm, i guess it is better to ask in a forum that supports your Uno.
    21,830
    That'd be my guess too.
    It's too bad Uno doesn't have priority nested interrupts like ARM. FreqMeasure defaults its interrupt to a fairly high priority level, so it automatically works even when other lower priority interrupts take a long time.
    On Uno, perhaps with a *lot* of work you could redesign Adafruit's library to allow other interrupts while it spends so much time using the VS1053.
    Dec 2016
    3
    Thanks, Paul.
    Moving to (or: learning) ARM is unfortunately out of scope for this project (I only got a few days off) but on my agenda for 2017
    I consider now to use two UNOs, one for pitched mp3 playback and one for freq measurement -- connected via I2C. Do you foresee interrupt problems with FreqMeasure and I2C too? Or might this be a viable path?
    21,830
    On Uno, the Wire library also uses interrupts. Probably less time, so perhaps it will work better for low frequencies, but still a possible problem.
    ARM isn't hard to learn. Just use Arduino like you do now. But a lot of things that fail on Uno work great on Teensy 3.2.
    If using Teensy 3.2, you can also use the audio lib and Frank's MP3 lib to do all the MP3 decoding without any VS1053.
    Dec 2016
    3
    Okay, that sounds tempting indeed. Will look around for a Teensy distributor in Germany (and keep trying to proceed on the UNO until it's shipped...)
    Thanks, Paul.
