https://codebender.cc/
Browser based Arduino code editing and compile with their compiler, then it pulls down the .hex and pushes to the Arduino via COMn or Ethernet.
I tried to use it, but it required I have an Arduino/bootloader connected, which I don't have.
I wanted to use it, and see if they let you set the compiler options so I could target a Teensy 3, or get it to save or push the .hex to a Teensy 2.
I did use mbed's on-line (Keil) compiler. It was OK, not great for the advanced user.
But Code Bender would be great for students, aspiring geeks, etc, as there's no IDE to install.
If Code Bender works for Teensy 2's loader, and could work for Teensy 3, it could enlarge the user base by eliminating the need for the IDE on the user's PC (windows, Linux are supported by their browser plugin for Firefox, Chrome, IE). Not sure how Teensyduino could integrate with the server-side compiler.
