Results 1 to 5 of 5
Thread: Trying to write an event listener with Teensyduino 2.0
    3
    Question Trying to write an event listener with Teensyduino 2.0
    I'm trying to listen to triggers from hall effect sensors on my teensyduino 2.0 board, and I'm having a lot of trouble coding this correctly. As it stands right now, my key press event isn't actually releasing. My thought is that there must be a way to actually trigger the board rather than run an infinite loop?
    Here is the code I've written
    int laneOnePin = 5;
    int laneTwoPin = 6;
    int laneThreePin = 7;
    int laneFourPin = 8;
    int redPin =  12;
    int greenPin =  15;
    int bluePin =  14;
    int laneOneTrigger;
    int laneTwoTrigger;
    int laneThreeTrigger;
    int laneFourTrigger;
    void setup()   {
      Serial.begin(38400);
      pinMode(laneOneTrigger, INPUT);
      pinMode(laneTwoTrigger, INPUT);
      pinMode(laneThreeTrigger, INPUT);
      pinMode(laneFourTrigger, INPUT);
      pinMode(redPin, OUTPUT);
      pinMode(greenPin, OUTPUT);
      pinMode(bluePin, OUTPUT);
       // initialize control over the keyboard:
      Keyboard.begin();
      laneOneTrigger = digitalRead(laneOnePin);
      laneTwoTrigger = digitalRead(laneTwoPin);
      laneThreeTrigger = digitalRead(laneThreePin);
      laneFourTrigger = digitalRead(laneFourPin);
      Serial.print("magnet is: ");
      if (laneOneTrigger == 0) {
        Serial.println("near lane one");
        // Turn USB red
        analogWrite(redPin, 255);
        analogWrite(greenPin, 0);
        analogWrite(bluePin, 0);
        Keyboard.press(KEY_LEFT_CTRL);
        Keyboard.press(KEY_LEFT_ALT);
        Keyboard.press(KEY_F1);
        delay(200);
        Keyboard.releaseAll();
      } else if (laneTwoTrigger == 0) {
        Serial.println("near lane two");
        // Turn USB yellow
        analogWrite(greenPin, 255);
        Keyboard.press(KEY_F2);
        delay(200);
      } else if (laneThreeTrigger == 0) {
        Serial.println("near lane three");
        // Turn USB green
        analogWrite(redPin, 0);
        Keyboard.press(KEY_F3);
        delay(200);
      } else if (laneFourTrigger == 0) {
        Serial.println("near lane four");
        // Turn USB blue
        analogWrite(bluePin, 255);
        Keyboard.press(KEY_F4);
        delay(200);
        Serial.println("not near any lane");
        delay(200);
      delay(10);
    Any suggestions would be fantastic!! Thank you.
    1,417
    Those should be the pin numbers.
    Pete
    3
    Good observation, I corrected that, however I'm still having issue with the program. It actually flashes the LED by itself between green and blue, but it seems totally random. Is there a way to do this without a loop and just have board listening for the trigger from the hall effect sensor?
    3
    Good news, I figured out that my issue was related to some of the pins not being connected yet. I used "INPUT_PULLUP" as the type, and now it works perfectly. I still feel like this is the sloppiest code I've ever written...but it does the job I guess
    22,497
    I highly recommend using the Bounce library for reading pushbuttons.
    There's an example in File > Examples > Teensy > USB_Keyboard > Buttons.
Tags for this Thread
