I have an Teensy2++ application (plain C) in HID-mode to extend my very recent DIY RC-transmitter with a USB interface. I want to transmit data from and to the transmitter when plugged into a PC (Mac). In addition, the Teensy does other work in the transmitter. - This works fine on the breadboard, but I want to let it run with USB disabled for reducing power consumption and of course without the PC while using the transmitter outside. On the Teensy I have the pads cut apart and the 2 schottky's plugged in between and to the external (battery) power as explained on the Teensy site.
When started from the external power, the T2 does not work. I think this is the meaning of your annotation '... this will wait forever' in the example code.
Question 1:
Does the teensy loader work if I have not initiated the USB with usb_init() at startup? I couldn't find an answer in the docs for that specific issue.
My intention is to cut the red USB wire of the Mount adaptor inside the transmitter and to use the USB power for a relay to switch off the battery when USB is plugged in. So I could initiate the USB part with an pin change interrupt. Should that work?
Question 2:
How do I deactivate the USB part to reduce power when the USB is detached? Is clearing the USBE and setting the FRZCLK bit sufficent?
heimi
Question 1:
Question 2:
heimi
