Tuetensosse
Dear PJRC Community,
since a few days, i changed from a Teensy 3.0 to a Teensy 3.1. Both are wired directly with a WS2801 (Data on Pin 11 and Clock on Pin 13) LED Matrix (50 LEDs in a row).
When I now want to use the "old" Teensy 3.0 code with the new Teensy 3.1 I get the following error messages:
In file included from C:\Program Files (x86)\Arduino\libraries\FastSPI_LED21/fastspi.h:6:0,
from C:\Program Files (x86)\Arduino\libraries\FastSPI_LED21/FastSPI_LED2.h:6,
from sk_FastSPI2FXv051_POST.ino:41:
C:\Program Files (x86)\Arduino\libraries\FastSPI_LED21/delay.h: In function 'void _delaycycles_AVR() [with int LOOP = 15; int PAD = 2]':
C:\Program Files (x86)\Arduino\libraries\FastSPI_LED21/delay.h:36:4: error: unknown register name 'r16' in 'asm'
OS: Windows 7; Arduino IDE 1.0.5. ; Teensyduino -> 1.18-rc1
These errors also appear, when I want to test the examples of the FastSpi_Led2, FastSpi_Led and FastLed libraries. Would be perfect if someone could help!
Thank you very much!
#----- FASTSPI2 EFFECTS EXAMPLES -----#
#-------------- v0.51 ----------------#
#------------ teldredge --------------#
#-------- www.funkboxing.com ---------#
#------ teldredge1979@gmail.com ------#
### THESE EFFECTS ARE MOSTLY DESIGNED FOR A LOOP/RING OF LEDS
### BUT PLENTY USEFUL FOR OTHER CONFIGURATIONS
### RECENT CHANGES v0.51
-ADDED SOFTWARE SERIAL FOR BLUETOOTH CONTROL
-ADDED (z) SHOW LED COMMAND (FOR BETTER SERIAL CONTROL)
-ADDED SET (a)ll LEDS TO COLOR HSV (0-255)
-ADDED (c)lear FUNCTION
-ADDED (v) SET INDIVIDUAL LED HSV FUNCTION
-ADDED (Q)UERY VERSION NUMBER FUNCTION
### NOTES
-MAKE SURE YOU ARE USING FAST_SPI RC3 OR LATER
-THIS IS AN EXAMPLE LIBRARY SO YOU'LL PRABALY WANT TO EDIT TO DO ANYTHING USEFUL WITH IT
-GOTO FUNKBOXING FAST_SPI2 COMMENTS PAGE FOR HELP
-DEMO MODE BLOCKS SERIAL COMMANDS
### LICENSE:::USE FOR WHATEVER YOU WANT, WHENEVER YOU WANT, HOWEVER YOU WANT, WHYEVER YOU WANT
### BUT YOU MUST YODEL ONCE FOR FREEDOM AND MAYBE DONATE TO SOMETHING WORTHWHILE
| FROM THE FAST_SPI2 EXAMPLE FILE |
// Uncomment this line if you have any interrupts that are changing pins - this causes the library to be a little bit more cautious
// #define FAST_SPI_INTERRUPTS_WRITE_PINS 1
// Uncomment this line to force always using software, instead of hardware, SPI (why?)
// #define FORCE_SOFTWARE_SPI 1
// Uncomment this line if you want to talk to DMX controllers
// #define FASTSPI_USE_DMX_SIMPLE 1
#include <SoftwareSerial.h>
#include <FastSPI_LED2.h>
#define VERSION_NUMBER 0.51
//---LED SETUP STUFF
#define LED_COUNT 75 //FOR TESTING w/ SIGN
#define LED_DT 11 //SERIAL DATA PIN
#define LED_CK 13 //SERIAL CLOCK PIN
int BOTTOM_INDEX = 0;
int TOP_INDEX = int(LED_COUNT/2);
int EVENODD = LED_COUNT%2;
struct CRGB leds[LED_COUNT];
int ledsX[LED_COUNT][3]; //-ARRAY FOR COPYING WHATS IN THE LED STRIP CURRENTLY (FOR CELL-AUTOMATA, MARCH, ETC)
//int ledMode = 3; //-START IN RAINBOW LOOP
int ledMode = 888; //-START IN DEMO MODE
//int ledMode = 6; //-MODE TESTING
int thisdelay = 20; //-FX LOOPS DELAY VAR
int thisstep = 10; //-FX LOOPS DELAY VAR
int thishue = 0; //-FX LOOPS DELAY VAR
int thissat = 255; //-FX LOOPS DELAY VAR
int max_bright = 64; //-SET MAX BRIGHTNESS TO 1/4
int thisindex = 0; //-SET SINGLE LED VAR
int thisRED = 0;
int thisGRN = 0;
int thisBLU = 0;
//---SERIAL/SOFTWARE SERIAL SETUP STUFF
//#define SERIAL_BAUDRATE 9600
#define SERIAL_BAUDRATE 57600
//#define SERIAL_BAUDRATE 115200
#define SERIAL_TIMEOUT 5
#define SOFT_RX_PIN 2 // BTCHIP-TX -> NANO-SOFT-RX (2)
#define SOFT_TX_PIN 3 // BTCHIP-RX -> NANO-SOFT-TX (3)
SoftwareSerial btSerial(SOFT_RX_PIN, SOFT_TX_PIN);
int btBOOL = 0; //-ACTIVATE BLUETOOTH OR NOT
byte inbyte; //-SERIAL INPUT BYTE
int thisarg; //-SERIAL INPUT ARG
//---LED FX VARS
int idex = 0; //-LED INDEX (0 to LED_COUNT-1
int ihue = 0; //-HUE (0-255)
int ibright = 0; //-BRIGHTNESS (0-255)
int isat = 0; //-SATURATION (0-255)
int bouncedirection = 0; //-SWITCH FOR COLOR BOUNCE (0-1)
float tcount = 0.0; //-INC VAR FOR SIN LOOPS
int lcount = 0; //-ANOTHER COUNTING VAR
//------------------------------------- UTILITY FXNS --------------------------------------
//---SET THE COLOR OF A SINGLE RGB LED
void set_color_led(int adex, int cred, int cgrn, int cblu) {
leds[adex].setRGB( cred, cgrn, cblu);
//---FIND INDEX OF HORIZONAL OPPOSITE LED
int horizontal_index(int i) {
//-ONLY WORKS WITH INDEX < TOPINDEX
if (i == BOTTOM_INDEX) {return BOTTOM_INDEX;}
if (i == TOP_INDEX && EVENODD == 1) {return TOP_INDEX + 1;}
if (i == TOP_INDEX && EVENODD == 0) {return TOP_INDEX;}
return LED_COUNT - i;
//---FIND INDEX OF ANTIPODAL OPPOSITE LED
int antipodal_index(int i) {
int iN = i + TOP_INDEX;
if (i >= TOP_INDEX) {iN = ( i + TOP_INDEX ) % LED_COUNT; }
return iN;
//---FIND ADJACENT INDEX CLOCKWISE
int adjacent_cw(int i) {
int r;
if (i < LED_COUNT - 1) {r = i + 1;}
else {r = 0;}
return r;
//---FIND ADJACENT INDEX COUNTER-CLOCKWISE
int adjacent_ccw(int i) {
int r;
if (i > 0) {r = i - 1;}
else {r = LED_COUNT - 1;}
return r;
void copy_led_array(){
for(int i = 0; i < LED_COUNT; i++ ) {
ledsX[i][0] = leds[i].r;
ledsX[i][1] = leds[i].g;
ledsX[i][2] = leds[i].b;
//------------------------LED EFFECT FUNCTIONS------------------------
void one_color_all(int cred, int cgrn, int cblu) { //-SET ALL LEDS TO ONE COLOR
for(int i = 0 ; i < LED_COUNT; i++ ) {
leds[i].setRGB( cred, cgrn, cblu);
void one_color_allHSV(int ahue) { //-SET ALL LEDS TO ONE COLOR (HSV)
leds[i] = CHSV(ahue, thissat, 255);
void rainbow_fade() { //-m2-FADE ALL LEDS THROUGH HSV RAINBOW
ihue++;
if (ihue > 255) {ihue = 0;}
for(int idex = 0 ; idex < LED_COUNT; idex++ ) {
leds[idex] = CHSV(ihue, thissat, 255);
LEDS.show();
delay(thisdelay);
void rainbow_loop() { //-m3-LOOP HSV RAINBOW
idex++;
ihue = ihue + thisstep;
if (idex >= LED_COUNT) {idex = 0;}
LEDS.show();
delay(thisdelay);
void random_burst() { //-m4-RANDOM INDEX/COLOR
idex = random(0, LED_COUNT);
ihue = random(0, 255);
LEDS.show();
delay(thisdelay);
void color_bounce() { //-m5-BOUNCE COLOR (SINGLE LED)
if (bouncedirection == 0) {
idex = idex + 1;
if (idex == LED_COUNT) {
bouncedirection = 1;
idex = idex - 1;
if (bouncedirection == 1) {
idex = idex - 1;
if (idex == 0) {
if (i == idex) {leds[i] = CHSV(thishue, thissat, 255);}
else {leds[i] = CHSV(0, 0, 0);}
LEDS.show();
delay(thisdelay);
void color_bounceFADE() { //-m6-BOUNCE COLOR (SIMPLE MULTI-LED FADE)
idex = idex + 1;
idex = idex - 1;
idex = idex - 1;
if (idex == 0) {
int iL1 = adjacent_cw(idex);
int iL2 = adjacent_cw(iL1);
int iL3 = adjacent_cw(iL2);
int iR1 = adjacent_ccw(idex);
int iR2 = adjacent_ccw(iR1);
int iR3 = adjacent_ccw(iR2);
else if (i == iL1) {leds[i] = CHSV(thishue, thissat, 150);}
else if (i == iL2) {leds[i] = CHSV(thishue, thissat, 80);}
else if (i == iL3) {leds[i] = CHSV(thishue, thissat, 20);}
else if (i == iR1) {leds[i] = CHSV(thishue, thissat, 150);}
else if (i == iR2) {leds[i] = CHSV(thishue, thissat, 80);}
else if (i == iR3) {leds[i] = CHSV(thishue, thissat, 20);}
LEDS.show();
delay(thisdelay);
void ems_lightsONE() { //-m7-EMERGENCY LIGHTS (TWO COLOR SINGLE LED)
idex++;
int idexR = idex;
int idexB = antipodal_index(idexR);
int thathue = (thishue + 160) % 255;
if (i == idexR) {leds[i] = CHSV(thishue, thissat, 255);}
else if (i == idexB) {leds[i] = CHSV(thathue, thissat, 255);}
LEDS.show();
delay(thisdelay);
void ems_lightsALL() { //-m8-EMERGENCY LIGHTS (TWO COLOR SOLID)
idex++;
int idexR = idex;
leds[idexR] = CHSV(thishue, thissat, 255);
leds[idexB] = CHSV(thathue, thissat, 255);
LEDS.show();
delay(thisdelay);
void flicker() { //-m9-FLICKER EFFECT
int random_bright = random(0,255);
int random_delay = random(10,100);
int random_bool = random(0,random_bright);
if (random_bool < 10) {
leds[i] = CHSV(thishue, thissat, random_bright);
LEDS.show();
delay(random_delay);
void pulse_one_color_all() { //-m10-PULSE BRIGHTNESS ON ALL LEDS TO ONE COLOR
ibright++;
if (ibright >= 255) {bouncedirection = 1;}
ibright = ibright - 1;
if (ibright <= 1) {bouncedirection = 0;}
leds[idex] = CHSV(thishue, thissat, ibright);
LEDS.show();
delay(thisdelay);
void pulse_one_color_all_rev() { //-m11-PULSE SATURATION ON ALL LEDS TO ONE COLOR
isat++;
if (isat >= 255) {bouncedirection = 1;}
isat = isat - 1;
if (isat <= 1) {bouncedirection = 0;}
leds[idex] = CHSV(thishue, isat, 255);
LEDS.show();
delay(thisdelay);
void fade_vertical() { //-m12-FADE 'UP' THE LOOP
idex++;
if (idex > TOP_INDEX) {idex = 0;}
int idexA = idex;
int idexB = horizontal_index(idexA);
ibright = ibright + 10;
if (ibright > 255) {ibright = 0;}
leds[idexA] = CHSV(thishue, thissat, ibright);
leds[idexB] = CHSV(thishue, thissat, ibright);
LEDS.show();
delay(thisdelay);
void random_red() { //QUICK 'N DIRTY RANDOMIZE TO GET CELL AUTOMATA STARTED
int temprand;
temprand = random(0,100);
if (temprand > 50) {leds[i].r = 255;}
if (temprand <= 50) {leds[i].r = 0;}
leds[i].b = 0; leds[i].g = 0;
LEDS.show();
void rule30() { //-m13-1D CELLULAR AUTOMATA - RULE 30 (RED FOR NOW)
random_red();
copy_led_array();
int iCW;
int iCCW;
int y = 100;
iCW = adjacent_cw(i);
iCCW = adjacent_ccw(i);
if (ledsX[iCCW][0] > y && ledsX[i][0] > y && ledsX[iCW][0] > y) {leds[i].r = 0;}
if (ledsX[iCCW][0] > y && ledsX[i][0] > y && ledsX[iCW][0] <= y) {leds[i].r = 0;}
if (ledsX[iCCW][0] > y && ledsX[i][0] <= y && ledsX[iCW][0] > y) {leds[i].r = 0;}
if (ledsX[iCCW][0] > y && ledsX[i][0] <= y && ledsX[iCW][0] <= y) {leds[i].r = 255;}
if (ledsX[iCCW][0] <= y && ledsX[i][0] > y && ledsX[iCW][0] > y) {leds[i].r = 255;}
if (ledsX[iCCW][0] <= y && ledsX[i][0] > y && ledsX[iCW][0] <= y) {leds[i].r = 255;}
if (ledsX[iCCW][0] <= y && ledsX[i][0] <= y && ledsX[iCW][0] > y) {leds[i].r = 255;}
if (ledsX[iCCW][0] <= y && ledsX[i][0] <= y && ledsX[iCW][0] <= y) {leds[i].r = 0;}
LEDS.show();
delay(thisdelay);
void random_march() { //-m14-RANDOM MARCH CCW
copy_led_array();
int iCCW;
leds[0] = CHSV(random(0,255), 255, 255);
for(int idex = 1; idex < LED_COUNT ; idex++ ) {
iCCW = adjacent_ccw(idex);
leds[idex].r = ledsX[iCCW][0];
leds[idex].g = ledsX[iCCW][1];
leds[idex].b = ledsX[iCCW][2];
LEDS.show();
delay(thisdelay);
void rwb_march() { //-m15-R,W,B MARCH CCW
copy_led_array();
int iCCW;
idex++;
if (idex > 2) {idex = 0;}
switch (idex) {
case 0:
leds[0].r = 255;
leds[0].g = 0;
leds[0].b = 0;
case 1:
leds[0].r = 255;
leds[0].g = 255;
leds[0].b = 255;
case 2:
leds[0].r = 0;
leds[0].g = 0;
leds[0].b = 255;
for(int i = 1; i < LED_COUNT; i++ ) {
leds[i].r = ledsX[iCCW][0];
leds[i].g = ledsX[iCCW][1];
leds[i].b = ledsX[iCCW][2];
LEDS.show();
delay(thisdelay);
void radiation() { //-m16-SORT OF RADIATION SYMBOLISH-
int N3 = int(LED_COUNT/3);
int N6 = int(LED_COUNT/6);
int N12 = int(LED_COUNT/12);
for(int i = 0; i < N6; i++ ) { //-HACKY, I KNOW...
tcount = tcount + .02;
if (tcount > 3.14) {tcount = 0.0;}
ibright = int(sin(tcount)*255);
int j0 = (i + LED_COUNT - N12) % LED_COUNT;
int j1 = (j0+N3) % LED_COUNT;
int j2 = (j1+N3) % LED_COUNT;
leds[j0] = CHSV(thishue, thissat, ibright);
leds[j1] = CHSV(thishue, thissat, ibright);
leds[j2] = CHSV(thishue, thissat, ibright);
LEDS.show();
delay(thisdelay);
void color_loop_vardelay() { //-m17-COLOR LOOP (SINGLE LED) w/ VARIABLE DELAY
idex++;
if (idex > LED_COUNT) {idex = 0;}
int di = abs(TOP_INDEX - idex);
int t = constrain((10/di)*10, 10, 500);
if (i == idex) {
leds[i] = CHSV(0, thissat, 255);
else {
leds[i].r = 0; leds[i].g = 0; leds[i].b = 0;
LEDS.show();
delay(t);
void white_temps() { //-m18-SHOW A SAMPLE OF BLACK BODY RADIATION COLOR TEMPERATURES
int N9 = int(LED_COUNT/9);
for (int i = 0; i < LED_COUNT; i++ ) {
if (i >= 0 && i < N9) {leds[i].r = 255; leds[i].g = 147; leds[i].b = 41;} //-CANDLE - 1900
if (i >= N9 && i < N9*2) {leds[i].r = 255; leds[i].g = 197; leds[i].b = 143;} //-40W TUNG - 2600
if (i >= N9*2 && i < N9*3) {leds[i].r = 255; leds[i].g = 214; leds[i].b = 170;} //-100W TUNG - 2850
if (i >= N9*3 && i < N9*4) {leds[i].r = 255; leds[i].g = 241; leds[i].b = 224;} //-HALOGEN - 3200
if (i >= N9*4 && i < N9*5) {leds[i].r = 255; leds[i].g = 250; leds[i].b = 244;} //-CARBON ARC - 5200
if (i >= N9*5 && i < N9*6) {leds[i].r = 255; leds[i].g = 255; leds[i].b = 251;} //-HIGH NOON SUN - 5400
if (i >= N9*6 && i < N9*7) {leds[i].r = 255; leds[i].g = 255; leds[i].b = 255;} //-DIRECT SUN - 6000
if (i >= N9*7 && i < N9*8) {leds[i].r = 201; leds[i].g = 226; leds[i].b = 255;} //-OVERCAST SKY - 7000
if (i >= N9*8 && i < LED_COUNT) {leds[i].r = 64; leds[i].g = 156; leds[i].b = 255;}//-CLEAR BLUE SKY - 20000
LEDS.show();
void sin_bright_wave() { //-m19-BRIGHTNESS SINE WAVE
tcount = tcount + .1;
leds[i] = CHSV(thishue, thissat, ibright);
LEDS.show();
delay(thisdelay);
void pop_horizontal() { //-m20-POP FROM LEFT TO RIGHT UP THE RING
int ix;
ix = idex;
else if (bouncedirection == 1) {
ix = horizontal_index(idex);
idex++;
if (i == ix) {
else {
LEDS.show();
delay(thisdelay);
void quad_bright_curve() { //-m21-QUADRATIC BRIGHTNESS CURVER
int ax;
for(int x = 0; x < LED_COUNT; x++ ) {
if (x <= TOP_INDEX) {ax = x;}
else if (x > TOP_INDEX) {ax = LED_COUNT-x;}
int a = 1; int b = 1; int c = 0;
int iquad = -(ax*ax*a)+(ax*b)+c; //-ax2+bx+c
int hquad = -(TOP_INDEX*TOP_INDEX*a)+(TOP_INDEX*b)+c;
ibright = int((float(iquad)/float(hquad))*255);
leds[x] = CHSV(thishue, thissat, ibright);
LEDS.show();
delay(thisdelay);
void flame() { //-m22-FLAMEISH EFFECT
int idelay = random(0,35);
float hmin = 0.1; float hmax = 45.0;
float hdif = hmax-hmin;
int randtemp = random(0,3);
float hinc = (hdif/float(TOP_INDEX))+randtemp;
int ihue = hmin;
for(int i = 0; i <= TOP_INDEX; i++ ) {
ihue = ihue + hinc;
leds[i] = CHSV(ihue, thissat, 255);
int ih = horizontal_index(i);
leds[ih] = CHSV(ihue, thissat, 255);
leds[TOP_INDEX].r = 255; leds[TOP_INDEX].g = 255; leds[TOP_INDEX].b = 255;
LEDS.show();
delay(idelay);
void rainbow_vertical() { //-m23-RAINBOW 'UP' THE LOOP
idex++;
int idexA = idex;
leds[idexA] = CHSV(ihue, thissat, 255);
leds[idexB] = CHSV(ihue, thissat, 255);
LEDS.show();
delay(thisdelay);
void pacman() { //-m24-REALLY TERRIBLE PACMAN CHOMPING EFFECT
int s = int(LED_COUNT/4);
lcount++;
if (lcount > 5) {lcount = 0;}
if (lcount == 0) {
for(int i = 0 ; i < LED_COUNT; i++ ) {set_color_led(i, 255, 255, 0);}
if (lcount == 1 || lcount == 5) {
leds[s].r = 0; leds[s].g = 0; leds[s].b = 0;}
if (lcount == 2 || lcount == 4) {
leds[s-1].r = 0; leds[s-1].g = 0; leds[s-1].b = 0;
leds[s+1].r = 0; leds[s+1].g = 0; leds[s+1].b = 0;}
if (lcount == 3) {
leds[s-2].r = 0; leds[s-2].g = 0; leds[s-2].b = 0;
leds[s+2].r = 0; leds[s+2].g = 0; leds[s+2].b = 0;}
LEDS.show();
delay(thisdelay);
void random_color_pop() { //-m25-RANDOM COLOR POP
one_color_all(0, 0, 0);
LEDS.show();
delay(thisdelay);
void ems_lightsSTROBE() { //-m26-EMERGENCY LIGHTS (STROBE LEFT/RIGHT)
int thishue = 0;
for(int x = 0 ; x < 5; x++ ) {
for(int i = 0 ; i < TOP_INDEX; i++ ) {
LEDS.show(); delay(thisdelay);
for(int i = TOP_INDEX ; i < LED_COUNT; i++ ) {
void rgb_propeller() { //-m27-RGB PROPELLER
idex++;
int ghue = (thishue + 80) % 255;
int bhue = (thishue + 160) % 255;
for(int i = 0; i < N3; i++ ) {
int j0 = (idex + i + LED_COUNT - N12) % LED_COUNT;
leds[j0] = CHSV(thishue, thissat, 255);
leds[j1] = CHSV(ghue, thissat, 255);
leds[j2] = CHSV(bhue, thissat, 255);
LEDS.show();
delay(thisdelay);
void kitt() { //-m28-KNIGHT INDUSTIES 2000
int rand = random(0, TOP_INDEX);
for(int i = 0; i < rand; i++ ) {
leds[TOP_INDEX+i] = CHSV(thishue, thissat, 255);
leds[TOP_INDEX-i] = CHSV(thishue, thissat, 255);
LEDS.show();
delay(thisdelay/rand);
for(int i = rand; i > 0; i-- ) {
leds[TOP_INDEX+i] = CHSV(thishue, thissat, 0);
leds[TOP_INDEX-i] = CHSV(thishue, thissat, 0);
LEDS.show();
void matrix() { //-m29-ONE LINE MATRIX
int rand = random(0, 100);
if (rand > 90) {
leds[0] = CHSV(thishue, thissat, 255);
else {leds[0] = CHSV(thishue, thissat, 0);}
copy_led_array();
leds[i].r = ledsX[i-1][0];
leds[i].g = ledsX[i-1][1];
leds[i].b = ledsX[i-1][2];
LEDS.show();
delay(thisdelay);
void strip_march_cw() { //-m50-MARCH STRIP CW
copy_led_array();
int iCW;
leds[i].r = ledsX[iCW][0];
leds[i].g = ledsX[iCW][1];
leds[i].b = ledsX[iCW][2];
LEDS.show();
delay(thisdelay);
void strip_march_ccw() { //-m51-MARCH STRIP CCW
copy_led_array();
int iCCW;
LEDS.show();
delay(thisdelay);
void new_rainbow_loop(){ //-m88-RAINBOW FADE FROM FAST_SPI2
ihue -= 1;
fill_rainbow( leds, LED_COUNT, ihue );
LEDS.show();
delay(thisdelay);
void demo_modeA(){
int r = 10;
thisdelay = 20; thisstep = 10; thishue = 00; thissat = 255;
for(int i=0; i<r*50; i++) {pulse_one_color_all();}
thisdelay = 20;
//for(int i=0; i<r*40; i++) {flicker();}
//one_color_all(0,0,0); LEDS.show();
//thisdelay = 15; thishue = 0; thissat = 255;
//for(int i=0; i<r*15; i++) {color_loop_vardelay();}
for(int i=0; i<r; i++) {sin_bright_wave();}
thisdelay = 200;
//thisdelay = 100; thishue = 0;
//demo_modeB();
//thisdelay = 5;
for(int i=0; i<r*3; i++) {flame();}
thisdelay = 500;
for(int i=0; i<r*25; i++) {rainbow_fade();}
thisdelay = 300; thishue = 240;
for(int i=0; i<r*5; i++) {fade_vertical();}
random_red();
thisdelay = 100;
//for(int i=0; i<r*120; i++) {new_rainbow_loop();}
//thisdelay = 200;
/*one_color_all(255,0,0); LEDS.show(); delay(1200);
one_color_all(0,255,0); LEDS.show(); delay(1200);
one_color_all(0,0,255); LEDS.show(); delay(1200);
one_color_all(255,255,0); LEDS.show(); delay(1200);
one_color_all(0,255,255); LEDS.show(); delay(1200);
one_color_all(255,0,255); LEDS.show(); delay(1200); */
void demo_modeB(){
int r = 10;
thisdelay = 35;
//for(int i=0; i<r*3; i++) {kitt();}
//thisdelay = 30; thishue = 95;
//for(int i=0; i<r*25; i++) {matrix();}
void change_mode(int newmode){
thissat = 255;
switch (newmode) {
case 0: one_color_all(0,0,0); LEDS.show(); break; //---ALL OFF
case 1: one_color_all(255,255,255); LEDS.show(); break; //---ALL ON
case 2: thisdelay = 20; break; //---STRIP RAINBOW FADE
case 3: thisdelay = 20; thisstep = 10; break; //---RAINBOW LOOP
case 4: thisdelay = 20; break; //---RANDOM BURST
case 5: thisdelay = 20; thishue = 0; break; //---CYLON v1
case 6: thisdelay = 40; thishue = 0; break; //---CYLON v2
case 7: thisdelay = 40; thishue = 0; break; //---POLICE LIGHTS SINGLE
case 8: thisdelay = 40; thishue = 0; break; //---POLICE LIGHTS SOLID
case 9: thishue = 160; thissat = 50; break; //---STRIP FLICKER
case 10: thisdelay = 15; thishue = 0; break; //---PULSE COLOR BRIGHTNESS
case 11: thisdelay = 15; thishue = 0; break; //---PULSE COLOR SATURATION
case 12: thisdelay = 60; thishue = 180; break; //---VERTICAL SOMETHING
case 13: thisdelay = 100; break; //---CELL AUTO - RULE 30 (RED)
case 14: thisdelay = 40; break; //---MARCH RANDOM COLORS
case 15: thisdelay = 80; break; //---MARCH RWB COLORS
case 16: thisdelay = 60; thishue = 95; break; //---RADIATION SYMBOL
//---PLACEHOLDER FOR COLOR LOOP VAR DELAY VARS
case 19: thisdelay = 35; thishue = 180; break; //---SIN WAVE BRIGHTNESS
case 20: thisdelay = 100; thishue = 0; break; //---POP LEFT/RIGHT
case 21: thisdelay = 100; thishue = 180; break; //---QUADRATIC BRIGHTNESS CURVE
//---PLACEHOLDER FOR FLAME VARS
case 23: thisdelay = 50; thisstep = 15; break; //---VERITCAL RAINBOW
case 24: thisdelay = 50; break; //---PACMAN
case 25: thisdelay = 35; break; //---RANDOM COLOR POP
case 26: thisdelay = 25; thishue = 0; break; //---EMERGECNY STROBE
case 27: thisdelay = 25; thishue = 0; break; //---RGB PROPELLER
case 28: thisdelay = 100; thishue = 0; break; //---KITT
case 29: thisdelay = 50; thishue = 95; break; //---MATRIX RAIN
case 50: thisdelay = 100; break; //---MARCH STRIP NOW CCW
case 51: thisdelay = 100; break; //---MARCH STRIP NOW CCW
case 88: thisdelay = 5; break; //---NEW RAINBOW LOOP
case 101: one_color_all(255,0,0); LEDS.show(); break; //---ALL RED
case 102: one_color_all(0,255,0); LEDS.show(); break; //---ALL GREEN
case 103: one_color_all(0,0,255); LEDS.show(); break; //---ALL BLUE
case 104: one_color_all(255,255,0); LEDS.show(); break; //---ALL COLOR X
case 105: one_color_all(0,255,255); LEDS.show(); break; //---ALL COLOR Y
case 106: one_color_all(255,0,255); LEDS.show(); break; //---ALL COLOR Z
ledMode = newmode;
//------------------SETUP------------------
Serial.begin(SERIAL_BAUDRATE); // SETUP HARDWARE SERIAL (USB)
Serial.setTimeout(SERIAL_TIMEOUT);
btSerial.begin(SERIAL_BAUDRATE); // SETUP SOFTWARE SERIAL (USB)
btSerial.setTimeout(SERIAL_TIMEOUT);
LEDS.setBrightness(max_bright);
//LEDS.addLeds<SM16716>(leds, LED_COUNT);
//LEDS.addLeds<UCS1903, 13>(leds, LED_COUNT);
//LEDS.addLeds<LPD8806, 10, 11 BGR>(leds, LED_COUNT);
//LEDS.addLeds<TM1809, 13>(leds, LED_COUNT);
LEDS.addLeds<WS2801, LED_CK, LED_DT, RBG, DATA_RATE_MHZ(1)>(leds, LED_COUNT);
//LEDS.addLeds<WS2811, LED_DT, GRB>(leds, LED_COUNT);
one_color_all(0,0,0); //-CLEAR STRIP
LEDS.show();
Serial.println("---SETUP COMPLETE---");
//------------------MAIN LOOP------------------
switch (ledMode) {
case 999: break;
case 2: rainbow_fade(); break;
case 3: rainbow_loop(); break;
case 4: random_burst(); break;
case 5: color_bounce(); break;
case 6: color_bounceFADE(); break;
case 7: ems_lightsONE(); break;
case 8: ems_lightsALL(); break;
case 9: flicker(); break;
case 10: pulse_one_color_all(); break;
case 11: pulse_one_color_all_rev(); break;
case 12: fade_vertical(); break;
case 13: rule30(); break;
case 14: random_march(); break;
case 15: rwb_march(); break;
case 16: radiation(); break;
case 17: color_loop_vardelay(); break;
case 18: white_temps(); break;
case 19: sin_bright_wave(); break;
case 20: pop_horizontal(); break;
case 21: quad_bright_curve(); break;
case 22: flame(); break;
case 23: rainbow_vertical(); break;
case 24: pacman(); break;
case 25: random_color_pop(); break;
case 26: ems_lightsSTROBE(); break;
case 27: rgb_propeller(); break;
case 28: kitt(); break;
case 29: matrix(); break;
case 50: strip_march_ccw(); break;
case 51: strip_march_cw(); break;
case 88: new_rainbow_loop(); break;
case 888: demo_modeA(); break;
case 889: demo_modeB(); break;
//---PROCESS HARDWARE SERIAL COMMANDS AND ARGS
while (Serial.available() > 0) {inbyte = Serial.read();
switch(inbyte) {
case 59: break; //---BREAK IF INBYTE = ';'
case 108: //---"l" - SET SINGLE LED VALUE RGB
thisindex = Serial.parseInt();
thisRED = Serial.parseInt();
thisGRN = Serial.parseInt();
thisBLU = Serial.parseInt();
if (ledMode != 999) {
ledMode = 999;
one_color_all(0,0,0);}
leds[thisindex].setRGB( thisRED, thisGRN, thisBLU);
case 118: //---"v" - SET SINGLE LED VALUE HSV
thishue = Serial.parseInt();
thissat = Serial.parseInt();
//thisVAL = Serial.parseInt();
ledMode = 999;
leds[thisindex] = CHSV(thishue, thissat, 255);
case 100: //---"d" - SET DELAY VAR
thisarg = Serial.parseInt();
thisdelay = thisarg;
case 115: //---"s" - SET STEP VAR
thisstep = thisarg;
case 104: //---"h" - SET HUE VAR
thishue = thisarg;
case 116: //---"t" - SET SATURATION VAR
thissat = thisarg;
case 98: //---"b" - SET MAX BRIGHTNESS
max_bright = Serial.parseInt();
case 109: //---"m" - SET MODE
change_mode(thisarg);
case 99: //---"c" - CLEAR STRIP
case 97: //---"a" - SET ALL TO ONE COLOR BY HSV 0-255
one_color_allHSV(thisarg);
case 122: //---"z" - COMMAND TO 'SHOW' LEDS
LEDS.show();
case 81: //---"Q" - COMMAND RETURN VERSION NUMBER
Serial.print(VERSION_NUMBER);
//---PROCESS SOFTWARE SERIAL COMMANDS AND ARGS
while (btSerial.available() > 0) {
inbyte = btSerial.read();
if (btSerial.overflow()){Serial.println("SoftwareSerial overflow!");}
switch(inbyte) {
thisindex = btSerial.parseInt();
thisRED = btSerial.parseInt();
thisGRN = btSerial.parseInt();
thisBLU = btSerial.parseInt();
ledMode = 999;
thisarg = btSerial.parseInt();
thisstep = thisarg;
thishue = thisarg;
thissat = thisarg;
max_bright = btSerial.parseInt();
LEDS.show();
