Mneventh
What is the correct way to safely disconnect teensy from your computer?
On the page http://www.pjrc.com/teensy/first_use.html it says that nothing is being run while the push button is held down. So I think that you should hold down the push button, disconnect the USB cable from the computer so the power goes out and then release it. Is that correct? Are there other ways to safely disconnect it?
