Results 1 to 6 of 6
Thread: Teensyduino 1.18 Release Candidate #3 Available
    Administrator Paul's Avatar
    Oct 2012
    390
    Here is a third release candidate for Teensyduino 1.18.
    Old beta download links removed. Please use the latest version:
    Please give this a try and report any bugs. Try to include a sample program that reproduces the problem!
    Here's a list of the changes since Teensyduino 1.18-rc2:
    • Update Windows driver, fix Serial+Keyboard on Windows 8
    • Fix __cxa_guard errors on Teensy 2.0
    • Add missing DMA & PGA register definitions for Teensy 3.1
    Austin, Texas
    57
    Typo in Teensyduino 1.18rc3?
    arm-none-eabi-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mcpu=cortex-m4 -DF_CPU=96000000 -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -mthumb -nostdlib -D__MK20DX256__ -DTEENSYDUINO=117
    <see also>
    http://forum.pjrc.com/threads/25055-...ll=1#post41523
    23,958
    My intention was to change that #define from 117 to 118 on the official release, not these release candidates.
    Then again, I had intended to wrap up 1.18, but I got pretty distracted by the audio library. My hope is to finish up 1.18 this week and then make a 1.0 release on the audio library next week. Small but important changes are in 1.18 that the audio library needs.
    Austin, Texas
    57
    Being a newb, figured I'd ask. Thanks for the explanation.
    Mar 2013
    Austin TX
    429
    Lacking a better place to post such things - I2C patch for mk20dx128.h:
    EDIT: Also, I don't know if you want to add it to your paper card, but I2C1 has an alternate pinout on 26(SCL1) / 31(SDA1).
    // Chapter 44: Inter-Integrated Circuit (I2C)
    #define I2C_C1_IICEN    (uint8_t)0x80            // I2C Enable
    #define I2C_C1_IICIE    (uint8_t)0x40            // I2C Interrupt Enable
    #define I2C_C1_MST      (uint8_t)0x20            // Master Mode Select
    #define I2C_C1_TX       (uint8_t)0x10            // Transmit Mode Select
    #define I2C_C1_TXAK     (uint8_t)0x08            // Transmit Acknowledge Enable
    #define I2C_C1_RSTA     (uint8_t)0x04            // Repeat START
    #define I2C_C1_WUEN     (uint8_t)0x02            // Wakeup Enable
    #define I2C_C1_DMAEN    (uint8_t)0x01            // DMA Enable
    #define I2C_S_TCF       (uint8_t)0x80            // Transfer Complete Flag
    #define I2C_S_IAAS      (uint8_t)0x40            // Addressed As A Slave
    #define I2C_S_BUSY      (uint8_t)0x20            // Bus Busy
    #define I2C_S_ARBL      (uint8_t)0x10            // Arbitration Lost
    #define I2C_S_RAM       (uint8_t)0x08            // Range Address Match
    #define I2C_S_SRW       (uint8_t)0x04            // Slave Read/Write
    #define I2C_S_IICIF     (uint8_t)0x02            // Interrupt Flag
    #define I2C_S_RXAK      (uint8_t)0x01            // Receive Acknowledge
    #define I2C_C2_GCAEN    (uint8_t)0x80            // General Call Address Enable
    #define I2C_C2_ADEXT    (uint8_t)0x40            // Address Extension
    #define I2C_C2_HDRS     (uint8_t)0x20            // High Drive Select
    #define I2C_C2_SBRC     (uint8_t)0x10            // Slave Baud Rate Control
    #define I2C_C2_RMEN     (uint8_t)0x08            // Range Address Matching Enable
    #define I2C_C2_AD(n)    ((n) & 7)                // Slave Address, upper 3 bits
    #define I2C0_A1         *(volatile uint8_t  *)0x40066000 // I2C0 Address Register 1
    #define I2C0_F          *(volatile uint8_t  *)0x40066001 // I2C0 Frequency Divider register
    #define I2C0_C1         *(volatile uint8_t  *)0x40066002 // I2C0 Control Register 1
    #define I2C0_S          *(volatile uint8_t  *)0x40066003 // I2C0 Status register
    #define I2C0_D          *(volatile uint8_t  *)0x40066004 // I2C0 Data I/O register
    #define I2C0_C2         *(volatile uint8_t  *)0x40066005 // I2C0 Control Register 2
    #define I2C0_FLT        *(volatile uint8_t  *)0x40066006 // I2C0 Programmable Input Glitch Filter register
    #define I2C0_RA         *(volatile uint8_t  *)0x40066007 // I2C0 Range Address register
    #define I2C0_SMB        *(volatile uint8_t  *)0x40066008 // I2C0 SMBus Control and Status register
    #define I2C0_A2         *(volatile uint8_t  *)0x40066009 // I2C0 Address Register 2
    #define I2C0_SLTH       *(volatile uint8_t  *)0x4006600A // I2C0 SCL Low Timeout Register High
    #define I2C0_SLTL       *(volatile uint8_t  *)0x4006600B // I2C0 SCL Low Timeout Register Low
    #if defined(__MK20DX256__)
    #define I2C1_A1         *(volatile uint8_t  *)0x40067000 // I2C1 Address Register 1
    #define I2C1_F          *(volatile uint8_t  *)0x40067001 // I2C1 Frequency Divider register
    #define I2C1_C1         *(volatile uint8_t  *)0x40067002 // I2C1 Control Register 1
    #define I2C1_S          *(volatile uint8_t  *)0x40067003 // I2C1 Status register
    #define I2C1_D          *(volatile uint8_t  *)0x40067004 // I2C1 Data I/O register
    #define I2C1_C2         *(volatile uint8_t  *)0x40067005 // I2C1 Control Register 2
    #define I2C1_FLT        *(volatile uint8_t  *)0x40067006 // I2C1 Programmable Input Glitch Filter register
    #define I2C1_RA         *(volatile uint8_t  *)0x40067007 // I2C1 Range Address register
    #define I2C1_SMB        *(volatile uint8_t  *)0x40067008 // I2C1 SMBus Control and Status register
    #define I2C1_A2         *(volatile uint8_t  *)0x40067009 // I2C1 Address Register 2
    #define I2C1_SLTH       *(volatile uint8_t  *)0x4006700A // I2C1 SCL Low Timeout Register High
    #define I2C1_SLTL       *(volatile uint8_t  *)0x4006700B // I2C1 SCL Low Timeout Register Low
    23,958
    Quote Originally Posted by nox771 View Post
    Thanks. I've added this. It will be in the next release.
